Fitting MBC and gauge
Post 629595 by Cov_Rob on 2013-07-27 14:12:43
Ive finally got round to fitting my MBC and boost gauge today, havnt been out to adjust it and set it yet, but i will soon. Quick question, for my boost gauge i just tapped into the vac line under the steering column (for standard gauge), will this affect the reading or is that fine? Thats the only issue i can really think off, i'll be back in a bit to let you all know how it goes :)
Post 629598 by T5frankie on 2013-07-27 14:34:52
mbc's wreck t5 engines btw
Post 629599 by V70 Graham on 2013-07-27 14:42:40
[QUOTE=T5frankie;629598]mbc's wreck t5 engines btw[/QUOTE] The correct mathematical formula is MBC + T5frankie = wrecked T5 engine
Post 629602 by volvokid on 2013-07-27 14:48:17
Also known as frankies law.
Post 629604 by Cov_Rob on 2013-07-27 15:06:28
Don't worry, I shan't be venturing over 10psi
Post 629605 by claymore on 2013-07-27 15:22:28
to answer the original question, yes that will be fine :)
Post 629607 by Cov_Rob on 2013-07-27 15:45:48
ok, so theres a problem. of course there is, there always f###### is! lol No matter how i adjust the boost controller the boost flies straight past 10psi and beyond! Ive screwed it almost all the way out and back in over half way and no difference. My MBC is the screw with lock nut and spring inside it type jobby. It does have a small hole in the top, should it?
Post 629639 by M-R-P on 2013-07-27 17:14:42
Wind it in mate, not out. Winding it out will give you more boost. Strat from all the way in and adjust it out from there.
Post 629647 by Cov_Rob on 2013-07-27 17:33:30
The instructions for it say to wind it anti-clockwise (out) and start from there, i assumed winding it in makes the cylinder smaller thus increasing the pressure. Correct me if im wrong, i've never had experience with MBC's before.
Post 629651 by Cov_Rob on 2013-07-27 17:45:30
10000 Dumb points to me! I have connected it backwards! HAHA What an complete knob lol I'll sort it out tomorrow and report back :)
Post 629655 by stribo on 2013-07-27 18:02:45
[QUOTE=Cov_Rob;629651]10000 Dumb points to me! I have connected it backwards! HAHA What an complete knob lol I'll sort it out tomorrow and report back :)[/QUOTE] At least you've found the problem.
Post 629666 by phil850t5 on 2013-07-27 18:34:04
[QUOTE=T5frankie;629598]mbc's wreck t5 engines btw[/QUOTE] fitting a MBC will wreck your car m8 my t5 runs at 15psi all day long with out one I did have one on its in the bin now
Post 629670 by Jamest5r on 2013-07-27 18:39:38
Ive run an unos mbc for over 3yrs with no problems, with an un forged engine and 18t 20 psi was fine as long as you dont batter it till after 3.5k, with a forged block im hitting 26psi and can floor it anytime but it's made me a slower driver lol
Post 629693 by T5frankie on 2013-07-27 19:05:44
[QUOTE=phil850t5;629666]fitting a MBC will wreck your car m8 my t5 runs at 15psi all day long with out one I did have one on its in the bin now[/QUOTE] if all you're gonna run is 15psi which is the same as what a map runs, whats the point?
Post 629694 by T5frankie on 2013-07-27 19:06:25
[QUOTE=Jamest5r;629670]Ive run an unos mbc for over 3yrs with no problems, with an un forged engine and 18t 20 psi was fine as long as you dont batter it till after 3.5k, with a forged block im hitting 26psi and can floor it anytime but it's made me a slower driver lol[/QUOTE] i suppose with my modded 19t its pushing alot more air than a standard turbo
Post 629718 by 850 T5s on 2013-07-27 19:25:01
I've been running an mbc for 3 and a half years at 1 bar with a different chip never had any problems
Post 629721 by p fandango on 2013-07-27 19:26:31
an MBC goes alot more of an aggressive boost than any mapped T-5 i've driven & used one for many years with no issues, only reason i ditched it because of going for the Apexi boost controller
Post 629724 by merc85 on 2013-07-27 19:28:28
im not gonna say it lol but Unos is has bin fine for me for around 4 years lol
Post 629744 by T5frankie on 2013-07-27 19:43:31
must be my super dooper turbo then that breaks the engines
Post 629747 by stribo on 2013-07-27 19:44:34
[QUOTE=T5frankie;629744]must be my super dooper turbo then that breaks the engines[/QUOTE] Or the driver. ;)
Post 629748 by T5frankie on 2013-07-27 19:45:28
[QUOTE=stribo;629747]Or the driver. ;)[/QUOTE] maybe that too
Post 629757 by Jamest5r on 2013-07-27 19:51:00
[QUOTE=T5frankie;629744]must be my super dooper turbo then that breaks the engines[/QUOTE] Nope it's your super dooper lead right foot mate :)
Post 629775 by volvokid on 2013-07-27 20:10:29
My dads old T5 got a chip and mbc fitted back in 98 and it was fine, brilliant car
Post 629776 by T5frankie on 2013-07-27 20:11:21
:blahblah:
Post 629835 by smithy on 2013-07-27 21:32:49
Quick question what car are we talking about here that's been fitted with the mbc
Post 629858 by volvokid on 2013-07-27 21:55:45
[QUOTE=T5frankie;629776]:blahblah:[/QUOTE] Your just jealous because it was done rite ;)
Post 629901 by MoleT-5R on 2013-07-27 23:27:55
[QUOTE=phil850t5;629666]fitting a MBC will wreck your car m8 my t5 runs at 15psi all day long with out one I did have one on its in the bin now[/QUOTE] my cheapo mbc is in the bin and the car is so much faster on the standard bcs, should have bought a couple of packets of fags, least I would have enjoyed wasting £15 and I gave up smoking 16 years ago....lol
Post 629906 by stribo on 2013-07-27 23:39:57
I've just got a bleed valve, which is universally said to be crap, and have the second fastest C70 on the forum, so either the bleed valve works better than people say, or I'm an amazing driver, I'll let you all decide. :D
Post 629909 by LiamT4 on 2013-07-27 23:47:18
[QUOTE=stribo;629906]I've just got a bleed valve, which is universally said to be crap, and have the second fastest C70 on the forum, so either the bleed valve works better than people say, or I'm an amazing driver, I'll let you all decide. :D[/QUOTE] or its just luck ;-)
Post 629913 by stribo on 2013-07-28 00:03:28
I had the fastest Cougar 0-60 time on the Cougar forum, so maybe I'm the luckiest driver. ;)
Post 629914 by LiamT4 on 2013-07-28 00:07:43
[QUOTE=stribo;629913]I had the fastest Cougar 0-60 time on the Cougar forum, so maybe I'm the luckiest driver. ;)[/QUOTE] Maybe you are............is that why they banned you........being the luckiest driver on the forum ;-)?
Post 629920 by Cov_Rob on 2013-07-28 00:47:32
Its a 940 2.0 by the way, just thought i should tell you :p
Post 629923 by smithy on 2013-07-28 00:54:07
[QUOTE=Cov_Rob;629920]Its a 940 2.0 by the way, just thought i should tell you :p[/QUOTE] Don't need to worry about bending rods in that engine .are you hitting boost cut or is it chipped .and what turbo are you using .also the has been a few pics of mine posted under car chat thread
Post 629924 by smithy on 2013-07-28 00:55:23
The thread is called for all the doubters
Post 629932 by stribo on 2013-07-28 08:13:47
[QUOTE=LiamT4;629914]Maybe you are............is that why they banned you........being the luckiest driver on the forum ;-)?[/QUOTE] No I got banned after one of the mods started spouting tripe about how to drive on a track, even though he'd never done it himself, and I told him he was talking utter bollix.;)
Post 629941 by T5frankie on 2013-07-28 09:18:31
[QUOTE=stribo;629913]I had the fastest Cougar 0-60 time on the Cougar forum, so maybe I'm the luckiest driver. ;)[/QUOTE] so you were on a forum for sexy older women?
Post 629946 by stribo on 2013-07-28 10:01:08
[QUOTE=T5frankie;629941]so you were on a forum for sexy older women?[/QUOTE] Um, no. :P
Post 629947 by claymore on 2013-07-28 10:02:13
[QUOTE=stribo;629906]I've just got a bleed valve, which is universally said to be crap, and have the second fastest C70 on the forum, so either the bleed valve works better than people say, or I'm an amazing driver, I'll let you all decide. :D[/QUOTE] I've always used a bleed valve and use one now to control boost, I find it much less prone to boost spike.
Post 629976 by 960kg on 2013-07-28 12:31:20
[QUOTE=Cov_Rob;629920]Its a 940 2.0 by the way, just thought i should tell you :p[/QUOTE] Is this the type of motor?......this was mine about 10yrs ago had a new engine fitted at Volvo. Red block single OHC 1998cc the piston skirts are short on this engine and it had piston slap even when hot like ££££££y hence the new engine which was £1500 + £500 fitting and bits and pieces, done at Taunton Volvo. I used a Bleed Valve opened 1 1/4 turns and it went like a rocket, they are 160bhp as standard You will have a cut out at 14psi. standard i ran 13psi
Post 629988 by Cov_Rob on 2013-07-28 13:47:05
I've read that the boost you can safely run depends on different things like the rods and ecu type. I'm not sure on either in my car so I'm going to set it at 10psi to be safe, but from what ive heard It seems the red block is a pretty strong engine
Post 629991 by JUDGENINJA on 2013-07-28 13:55:56
I'm not saying my MBC ruined my car.... It was probably the driver!
Post 630001 by phil850t5 on 2013-07-28 15:04:21
[QUOTE=T5frankie;629693]if all you're gonna run is 15psi which is the same as what a map runs, whats the point?[/QUOTE] I have run it at 17 and 19 psi but am happy with 15 psi I have more if I need it
Post 630081 by smithy on 2013-07-28 19:19:59
[QUOTE=Cov_Rob;629988]I've read that the boost you can safely run depends on different things like the rods and ecu type. I'm not sure on either in my car so I'm going to set it at 10psi to be safe, but from what ive heard It seems the red block is a pretty strong engine[/QUOTE] Your car has 13 mm rods so no need to worry but you will hit boost cut at around 14 psi so I would run your car at 13 psi and enjoy .
Post 630124 by Cov_Rob on 2013-07-28 20:45:31
I ran it at 10psi an gave it the beans on a test drive, all was well until one of coolant hoses popped. The hose that goes from the back passenger side of the cylinder head round the back of the engine and through the firewall (presumably for the heater). It's seemed odd for the increased boost pressure to make a coolant hose pop, could it just be because it was old?
Post 630126 by smithy on 2013-07-28 21:00:09
[QUOTE=Cov_Rob;630124]I ran it at 10psi an gave it the beans on a test drive, all was well until one of coolant hoses popped. The hose that goes from the back passenger side of the cylinder head round the back of the engine and through the firewall (presumably for the heater). It's seemed odd for the increased boost pressure to make a coolant hose pop, could it just be because it was old?[/QUOTE] More pressure always finds a weak spot mate .but I think the 2litre runs 10 psi standard or might be wrong .i know the hpt 2.3 runs 6.5 psi at 165 bhp and the lpt I have runs 4 psi at 135 bhp but I have a couple of mods so I'm at 140 bhp .
Post 630130 by Cov_Rob on 2013-07-28 21:07:16
Well it's running 10-11psi now and it's definitely more than it was running before, quite wary of it now though with my quick fix coolant hose (slid some copper pipe to the hole and clamped it)
Post 630132 by Cov_Rob on 2013-07-28 21:10:28
I just hope I havnt blown the head gasket :/
Post 630158 by smithy on 2013-07-28 22:00:50
[QUOTE=Cov_Rob;630132]I just hope I havnt blown the head gasket :/[/QUOTE] Is the car running alright and not missing
Post 630162 by Cov_Rob on 2013-07-28 22:06:18
The car seems to be running fine, no smoke or anything. Its just that it could be an explanation for a popped water hose. I might be worrying over nothing though
Post 630165 by Nealevo on 2013-07-28 22:09:39
It should be fine, just enjoy, and smithy get back to work!!!
Post 630170 by smithy on 2013-07-28 22:25:11
[QUOTE=Nealevo;630165]It should be fine, just enjoy, and smithy get back to work!!![/QUOTE] Sitting in the van waiting for my next drop thankyou lol
Post 630177 by Cov_Rob on 2013-07-28 22:33:09
Thats a suspicious sounding job at 10.30pm on a Sunday night lol :p
Post 630190 by smithy on 2013-07-28 23:06:58
[QUOTE=Cov_Rob;630177]Thats a suspicious sounding job at 10.30pm on a Sunday night lol :p[/QUOTE] No it's a silly job delivering stuff to jlr lol
Post 630201 by Cov_Rob on 2013-07-28 23:48:14
Everyone needs a good cover story ;)
Post 630233 by 960kg on 2013-07-29 08:03:41
If I remember correctly that hose at the back of the engine is shortish and if old with the xtra torque you now have and booting it the engine will rock more so the hose came off Rock the engine by hand to see if the engines mounts are ok or not The standard boost is 8.7psi for the B200FT or ET giving 155/160bhp
