Post 624860 by Nicka on 2013-07-12 21:18:33
Hey all, just need some help from you pro's.
I noticed a sort of clicking noise coming from my 1998 S70 when i turn the steering wheel. I sounds like it's coming from the drivers side wheel area.
I have read that it could be something called CV joints which are probably gone, but I am far from an expert.
Hoping someone could shed some light on what it could be. Also if it's an expensive fix if it is this problem.
Many thanks
Post 624868 by T5frankie on 2013-07-12 21:31:28
iif it clicks on full lock it will be the cv joints, not too expensive to fix
Post 624873 by stribo on 2013-07-12 21:50:33
[QUOTE=T5frankie;624868]iif it clicks on full lock it will be the cv joints, not too expensive to fix[/QUOTE]
As the man says, CV joint is shot. Change as soon as possible, as if it goes, as happened to me in my Saab 900, you have no drive.
Post 624926 by Nicka on 2013-07-12 23:25:29
Thanks fellas, will get them replaced asap.
