Post 602212 by polak t5r on 2013-05-02 19:04:41
can someone point me to a write up on changing rear window mech on my s70 r i've took door panel off and its like a armored tank behind there cheers
Whats wrong with it in the 1st place?
went down then wont come back up with both switches theres no noise from the motor at all
I`ll have a look how it comes off and if u need the motor U can have 1 for postage cost
oh brilliant thanks for that
i got lucky with the radio code i phoned volvo and they gave me the wrong one then i noticed it scratched into the top of the unit so thats sorted now
[QUOTE=polak t5r;602327]i got lucky with the radio code i phoned volvo and they gave me the wrong one then i noticed it scratched into the top of the unit so thats sorted now[/QUOTE] I didn`t notice that,but tbh as wasn`t driving it didn`t bother much anyway.Thats 1 job sorted then.:B_thumb:
This is a BMW type connection.2 locking clips like on pic 1,access by removing a white plastic that covers the door lock,u`ll need a hook to pull the clips out from both sides,2nd clip is deeper in from the access,once the clips removed pop the runners out of the window connectors,undo all the 10mm bolts etc.
cheers i popped the clips but have no access to the runners as the window is stuck half way down lolo
You might have to make a tool up and access from the top as on the pic 2 if that makes sence.Something flatish so u can put in and twist to pop it off.
i've done it thanks i'll test the motor 2moz and let you know if i need one thanks for your help mate
[QUOTE=polak t5r;602549]i've done it thanks i'll test the motor 2moz and let you know if i need one thanks for your help mate[/QUOTE] no probs.
