Post 594856 by claymore on 2013-04-09 17:52:07
I'm about to fit an external 300lph fuel pump to the car, any sugestions as to how big a swirl pot I'll need, I've got a 1ltr one, but I'm concerned it might be to small.
Mines 2 litre, but I didn't do any calculations purely because it was in stock by the supplier
Do you want to buy my bosch 044 with all the fittings?
[QUOTE=Wobbly Dave;594967]Do you want to buy my bosch 044 with all the fittings?[/QUOTE] Cheers mate, but I have the Swirl pot pre-filter and pump all ready to fit tomorrow.
how much for the 044? Sorry claymore a bit of thread hijacking in progress here
I run the standard pump to fill up my 1.5 ltr swirl pot, then use a cossie pump, which I think is 300lph?, to pump it to the front.:)
[QUOTE=JT;595152]I run the standard pump to fill up my 1.5 ltr swirl pot, then use a cossie pump, which I think is 300lph?, to pump it to the front.:)[/QUOTE] So, the only difference between yours and mine will be .5ltr swirl pot.
sounds like it mate:)
[QUOTE=redbaron;595146]how much for the 044? Sorry claymore a bit of thread hijacking in progress here[/QUOTE] £165 inc. delivery - which includes a 20 quid mounting clamp (BNIB), & an additional inlet adaptor (12mm I/D), plus all the outlet fittings that came with the pump. If you want the loom to plug into a volvo phase 1 - you can have that FOC.
