Gearbox problems, some advice requierd chaps
Post 584151 by kfc on 2013-03-14 19:27:21
Hi guys Just been informed that box is about to die. Something to do with Crown gear. right my main question is, can i get replacment parts or is it possible to use parts from any of the other boxes? or do i need to try and sorce a replacment. its a M59. thanks guys :worried:
Post 584154 by Kingsford G on 2013-03-14 19:29:21
It can be fixed as anything else mate but sometimes the cost of parts doesn`t make it worthwhile and its cheaper to get e diff box.M56 r stronger and much cheaper.
Post 584157 by T5frankie on 2013-03-14 19:31:44
[QUOTE=kfc;584151]Hi guys Just been informed that box is about to die. Something to do with Crown gear. right my main question is, can i get replacment parts or is it possible to use parts from any of the other boxes? or do i need to try and sorce a replacment. its a M59. thanks guys :worried:[/QUOTE] best just stick an m56 in there mate, cheaper and stronger, and any m59 you do find will be half worn out anyway ive broke 2 m59's myself
Post 584158 by p fandango on 2013-03-14 19:32:14
the bad news is no, you can't buy new replacement parts. But yes as the ratios are exactly the same as the T-5 M56H (with 4.00FDR) chances are they'll be interchangeable from a good secondhand box. The main difference is the M59 has a special casing for the viscous coupling to lock into thats on the longer driveshaft
Post 584159 by T5frankie on 2013-03-14 19:32:14
[QUOTE=Kingsford G;584154]It can be fixed as anything else mate but sometimes the cost of parts doesn`t make it worthwhile and its cheaper to get e diff box.M56 r stronger and much cheaper.[/QUOTE] beat me to it lol
Post 584177 by Kingsford G on 2013-03-14 19:44:56
[QUOTE=T5frankie;584159]beat me to it lol[/QUOTE] U r getting slow lol The drive shafts r diff for m56,aren`t they?
Post 584267 by Wobbly Dave on 2013-03-14 21:47:30
Sorry to hear of your woes.
Post 584300 by T5frankie on 2013-03-15 00:34:57
[QUOTE=Kingsford G;584177]U r getting slow lol The drive shafts r diff for m56,aren`t they?[/QUOTE] Only one of them
Post 584636 by kfc on 2013-03-15 22:43:25
[QUOTE=T5frankie;584157]best just stick an m56 in there mate, cheaper and stronger, and any m59 you do find will be half worn out anyway ive broke 2 m59's myself[/QUOTE] but if i put 56 on the car ill loss the lsd. or is there an aftermaket lsd availible at sensible that can be used on the M56 box?
Post 584638 by T5frankie on 2013-03-15 22:45:45
[QUOTE=kfc;584636]but if i put 56 on the car ill loss the lsd. or is there an aftermaket lsd availible at sensible that can be used on the M56 box?[/QUOTE] yeah you will, but so what? it doesnt make alot of difference in real world driving, the aftermarket ones are 700 quid plus fitting i put a 2.0 litre 20 valve m56 in my s70r because it had lower gear ratios for better acceleration
Post 584685 by p fandango on 2013-03-15 23:30:48
thinking about it, i've got the full internals from a M56H (except diff) gathering cobwebs if you want them Image
