Volvo 760 TD-R :)
Post 576485 by ian2000t on 2013-02-21 14:58:51
Hi guys, promised to put pics up a while ago after I bought a set of Titans from someone on here, and never got round to it. Well, now I'm hunting for another Titan, as one of mine got smashed when I hit a patch of black ice (luckily at a fairly low speed, so no damage to the car, just cracked the back left wheel), but I thought I'd post some pics of my old oil-burner! It's a UK 1990 760 TD (facelift model) - yes, the old rattly smokey VW 2.4 6-pot engine!! Spec from factory is: - 2.4ltr IDI VW 6 cylinder diesel - Facelift front end (940 style) - ZF22HP4 4 speed auto box - Intercooler - Electric sunroof - Electric Climate Control & Aircon - Tan Leather seats - Electric drivers seat - Nivomat rear shocks - 3.73 non-locking solid axle Here's some pics when I got it: Image Image Image Image Image Since I bought it I've made a few improvements: Engine: - Headgasket went, so fitted an Ajusa MLS 2 notch gasket and new bolts (still TTY bolts) - Timing belt/water pump/idler all replaced - IP timing set to 0.98mm - Injectors rebuilt with Monark 293 nozzles - MBC fitted and adjusted to 16psi - New cold start waxstat - Ground off collar and screwed main screw in a few turns - Reground the fuel pin - N/A inlet manifold - Rear silencer removed Suspension: - Spax rear 40mm lower springs - Front diesel springs chopped to 40mm lower - Bilstein TC shocks all round (getting rid of failed Nivos) - Swapped front 21mm anti roll bar for 22mm - Added rear 19mm anti roll bar - H&R 25mm DRM spacers - 17x7" Volvo Titan wheels - Front 215/45/17 Hankook V12; Rear 225/45/17 Goodyear Eagle; - Poly saucer bushes - Poly bushes on rear of track control arms (where they mount to rear part of inner wheel arch) Here's a few pics of how it looks now, hopefully I'll get some better ones up at some point: Image Image Image Image
Post 576487 by MRTREE on 2013-02-21 15:09:38
[QUOTE=ian2000t;576485]Hi guys, promised to put pics up a while ago after I bought a set of Titans from someone on here, and never got round to it. Well, now I'm hunting for another Titan, as one of mine got smashed when I hit a patch of black ice (luckily at a fairly low speed, so no damage to the car, just cracked the back left wheel), but I thought I'd post some pics of my old oil-burner! It's a UK 1990 760 TD (facelift model) - yes, the old rattly smokey VW 2.4 6-pot engine!! Spec from factory is: - 2.4ltr IDI VW 6 cylinder diesel - Facelift front end (940 style) - ZF22HP4 4 speed auto box - Intercooler - Electric sunroof - Electric Climate Control & Aircon - Tan Leather seats - Electric drivers seat - Nivomat rear shocks - 3.73 non-locking solid axle Here's some pics when I got it: Image Image Image Image Image Since I bought it I've made a few improvements: Engine: - Headgasket went, so fitted an Ajusa MLS 2 notch gasket and new bolts (still TTY bolts) - Timing belt/water pump/idler all replaced - IP timing set to 0.98mm - Injectors rebuilt with Monark 293 nozzles - MBC fitted and adjusted to 16psi - New cold start waxstat - Ground off collar and screwed main screw in a few turns - Reground the fuel pin - N/A inlet manifold - Rear silencer removed Suspension: - Spax rear 40mm lower springs - Front diesel springs chopped to 40mm lower - Bilstein TC shocks all round (getting rid of failed Nivos) - Swapped front 21mm anti roll bar for 22mm - Added rear 19mm anti roll bar - H&R 25mm DRM spacers - 17x7" Volvo Titan wheels - Front 215/45/17 Hankook V12; Rear 225/45/17 Goodyear Eagle; - Poly saucer bushes - Poly bushes on rear of track control arms (where they mount to rear part of inner wheel arch) Here's a few pics of how it looks now, hopefully I'll get some better ones up at some point: Image Image Image Image[/QUOTE] Looks sweet mate id have the clear indicators tint the back windows and paint the wheels in graphite but all in all looks nice
Post 576512 by kfc on 2013-02-21 17:13:07
Looks good guy,
Post 576513 by shepbomb on 2013-02-21 17:15:53
Looks very nice mate,
Post 576574 by smithy on 2013-02-21 19:44:27
Looks nice and its goes well too I've been in this car.
Post 576575 by T5frankie on 2013-02-21 19:49:05
very cool ditch the auto box though
Post 576583 by Nealevo on 2013-02-21 19:57:58
[QUOTE=smithy;576574]Looks nice and its goes well too I've been in this car.[/QUOTE] Probably more than you've been in your own!!! Looks a Sweeeeeeet ride thou
Post 576585 by V70 Graham on 2013-02-21 19:59:57
Does look nice, the wheels suit it imho and make the car look a little younger.
Post 576639 by smithy on 2013-02-21 21:09:13
[QUOTE=Nealevo;576583]Probably more than you've been in your own!!! Looks a Sweeeeeeet ride thou[/QUOTE] Cheeky and various other words lol
Post 576645 by LiamT4 on 2013-02-21 21:18:47
Interior don't look much different to an 850s. But removing a silencer on an old diesel?? Is that a good idea??
Post 576737 by Palmer on 2013-02-21 23:57:59
[QUOTE=LiamT4;576645]Interior don't look much different to an 850s. But removing a silencer on an old diesel?? Is that a good idea??[/QUOTE] They sound awesome!
Post 576793 by ian2000t on 2013-02-22 08:09:45
Thanks guys! Agree with the comment about the autobox - would love to convert it over to a manual box at some point! Removing the silencer on an old diesel doesn't really make much difference as they make a LOT less noise than petrols. As an example my 2.4TD with one silencer (had 2 from factory) makes significantly less exhaust note than my old 2.3 N/A (B230E) with 2 silencers (3 from factory). Also, diesels (especially turbos) don't need to keep certain levels of back pressure like a petrol does. Also, because these are 6 cylinder, rather than the usual 4 cylinder, they actually sound good! Mine's just got a slight burble at idle now with rear silencer removed. If I was to replace the whole system with a 2.5" with a freeflow silencer it would sound more like a Cummins truck - youtube it (D24), you'll find plenty! This is on my list of to-dos, but I was kind of hoping my current exhaust would rot a bit so I could justify it!! :wink: Also, I need to look at modifying the fuel pump with a 12mm head/rotor as I think I'm close to maxing my pump out.
Post 576808 by Doingitsideways on 2013-02-22 09:19:42
Oh, bloody hell Ian, This means I'm gonna have to do a project thread on the 960 now!! :( I do like the look of yours though, it looks good on Titans, and just sits "right" with a 40mm drop ;) Hope you manage to find another wheel, maybe stick some wanted ads up here and on VOC (sorry for swearing guys!!) Steve :)
Post 576927 by ian2000t on 2013-02-22 13:57:33
[QUOTE=Doingitsideways;576808]Oh, bloody hell Ian, This means I'm gonna have to do a project thread on the 960 now!! :( I do like the look of yours though, it looks good on Titans, and just sits "right" with a 40mm drop ;) Hope you manage to find another wheel, maybe stick some wanted ads up here and on VOC (sorry for swearing guys!!) Steve :)[/QUOTE] Haha!! Cheers mate, I was on the fence between Volans and Titans, but definitely made the right choice - the big flat 5 spokes just suit the boxy car! Making an adjustable panhard rod (got all the bits now) so I can centre the back axle properly, and get the tracking setup properly. And I'm hoping when it warms a bit and I can afford a few bushes, and some new rear disks that I'll stick the 3.54 locker in! :) Re: Titans - posted on VOC and no response. Posted on here, and I've found one in Brum already! Gotta pick it up, then get it refurbed same colour and I'll be all sorted!
Post 577000 by the young mechanic on 2013-02-22 17:23:46
very nice
Post 577054 by Doingitsideways on 2013-02-22 19:15:24
Job's a good-un! Yeah, my -40mm springs have arrived for the 480, gonna be interesting to see how much the back axle moves ober!! I'm expecting quite a lot, as 40mm is quite a lot of the suspension travel on a 400!! :s Steve :)
Post 577112 by Volvostorm on 2013-02-22 20:28:32
I like this a lot! :D
Post 577254 by graemewelch on 2013-02-23 12:39:28
how bad is the cracked wheel. should be able to weld it for you. some nice mods on your motor.
Post 577512 by ian2000t on 2013-02-23 23:15:00
[QUOTE=graemewelch;577254]how bad is the cracked wheel. should be able to weld it for you. some nice mods on your motor.[/QUOTE] Not so much cracked as smashed.... Image Don't think you could weld that could you? I've got another now thanks to Big G on here, just gotta get it coated the same colour as the rest! Steve, if it works my DIY adjustable panhard rod will have cost me less than £50 all in - including poly bushes!
Post 577612 by graemewelch on 2013-02-24 10:51:03
aye thats a bit beyond repair. you done a good job with that one
Post 588943 by beavy69 on 2013-03-26 17:57:53
Nice work, that's gone from old man's car to something that can handle its business.
Post 588984 by hillsidesteve on 2013-03-26 19:31:03
Nice job there, those wheels really suit the car. Now you have found another best stay in when its icy! Interesting mods all round. I used to have a 760 turbo intercooler manual around '91-93, an '88 model bought it from a dealer to tow the six-berth caravan as we had kids and their friends. Same colour as yours, really loved it. Then I got this idea about going a bit quicker and got it Superchipped - fantastic!! BHP went up from 182 to 230 and masses more torque. I then had ideas about fitting a LSD to get the power down more 'interestingly' although for whatever reason that never happened. Looking forward to seeing it in the flesh.
Post 601833 by ian2000t on 2013-04-30 16:36:47
[QUOTE=hillsidesteve;588984]Nice job there, those wheels really suit the car. Now you have found another best stay in when its icy![/QUOTE] Haha, yeh - I think next year I'll stop being lazy and switch to the crappy old 15" Omega's with Vredestein Snowtrac2 195/65/15's on, which is what I've been running while sourcing another Titan. They're actually incredible in the snow! But, enough of those...I have another Titan now, refurbed and got the tyre refitted, so I put them back on last night! Transformed the car all over again! :) Also, fitted a lower chassis brace from a 940 turbo which has stiffened up the front end nicely quite cheaply! Saving up to poly bush the rear and drop the new axle (3.54 1041 locker) in now..
Post 613771 by ian2000t on 2013-06-05 13:40:39
Well, the saving up for rear poly bushes didn't go too well.... Was planning on doing discs and pads all round soon, but MOT failed on handbrake with advisory on rear pads. So, bit the bullet and sorted the lot out: - Brembo front discs (287mm) - Mintex front pads - Euro Car parts rear discs - Halfords rear pads - New handbrake shoes - Free off all caliper pistons that were a bit sticky, and free up all of the handbrake mechanism. ...which still didn't fix the handbrake as the cable had stretched badly - was just putting some pressure on and then just stretching further, so... - 2 new handbrake cables Passed MOT now, brakes are LOADS better, and the handbrake works really well - enough to stop the diesel creeping on the handbrake downhill, which it's never been able to do before. Also realised in a recent camping trip that my rear Spax 40mm lower springs are rubbish - FAR too soft. I knew they were softer than the standard front springs chopped down, but didn't realise how bad until we put one mountain bike, BBQ+coals, and some shopping in the boot and it was dragging the arches on the Titans. Had to buy some spring assisters for the camping trip, which worked ok. So, going to try some HD rear springs chopped which should be stiffer.
