Auto box questions.
Post 575818 by jotter22 on 2013-02-20 07:59:26
Can some one answer these questions please? 1. When i select 1,2 or 3 manually i get an orange arrow on the dash is this normal? 2. The sport/overide button does not seem to do anything is there a simple way of checking it is working? Thanks Tony.
Post 575853 by Wobbly Dave on 2013-02-20 10:38:49
The S/E/W buttons only change the point at which the gear change occurs. Auto box has its own ECU. Sports should hang onto the gears for longer. IIRC there is also a kick down switch on the throttle pedal - which is audible when the engine is not running. IIRC the only time you need worry is if the orange arrow is flashing. I remember on my 850R that it also comes on in Winter modes. Read the owners manual if you still have it. Otherwise I will have to go outside & read mine. LOL
Post 575856 by jotter22 on 2013-02-20 10:43:25
Lol no the arrow is solid not flashing...is there not a light or symbol for the sports mode? Tony.
Post 575860 by Nealevo on 2013-02-20 10:50:47
The orange arrow is normal in 1,2,3 only worry if its flashing and this will indicate PNP switch fault. there is no light when you are in sport mode except near the actual switch which turns the green light off and goes orange, drive normal and press sport button if the revs hold until the redline the its working... but dont do this in town as it will make a mess... :-)
Post 575864 by jotter22 on 2013-02-20 10:54:36
[QUOTE=Nealevo;575860]The orange arrow is normal in 1,2,3 only worry if its flashing and this will indicate PNP switch fault. there is no light when you are in sport mode except near the actual switch which turns the green light off and goes orange, drive normal and press sport button if the revs hold until the redline the its working... but dont do this in town as it will make a mess... :-)[/QUOTE] I have not noticed a light will have to look tonight Tony.
Post 575866 by Wobbly Dave on 2013-02-20 10:58:34
Rtfm!
Post 575878 by jotter22 on 2013-02-20 12:00:32
[QUOTE=Wobbly Dave;575866]Rtfm![/QUOTE] ? i dont know what that means.....
Post 575885 by Wobbly Dave on 2013-02-20 12:31:04
http://en.wikipedia.org/wiki/RTFM There are other acronyms available such as GIYF (Google is your friend) or LMJGTFY (Let me just Google that for you). But never mind... [ATTACH=CONFIG]20495[/ATTACH] Some of my other favs include [ATTACH=CONFIG]20496[/ATTACH] and finally [ATTACH=CONFIG]20497[/ATTACH]
Post 575898 by jotter22 on 2013-02-20 13:22:39
[QUOTE=Wobbly Dave;575885]http://en.wikipedia.org/wiki/RTFM There are other acronyms available such as GIYF (Google is your friend) or LMJGTFY (Let me just Google that for you). But never mind... [ATTACH=CONFIG]20495[/ATTACH] Some of my other favs include [ATTACH=CONFIG]20496[/ATTACH] and finally [ATTACH=CONFIG]20497[/ATTACH][/QUOTE] :uglyhamme i consider myself told..... Tony.
Post 578473 by jotter22 on 2013-02-27 13:30:28
[QUOTE=jotter22;575864]I have not noticed a light will have to look tonight Tony.[/QUOTE] Nope i have looked and RTFM but top no avail....can someone point me in the direction of said switch or button please. I can only see the shift lock overide. Tony.
