Boost gauge fitting/vacuum tree.
Post 569398 by sartain87 on 2013-02-04 00:09:23
Looking to fit a boost gauge on a friends V70 T5 and on the vaccum tree does it matter if one port is exposed without being covered by a cap? Or would that cause issues? Was thinking of just plumbing the boost gauge line in there without using any of the others.
Post 569400 by M-R-P on 2013-02-04 00:11:22
Only remove the cap if you're planning to replace it with something i.e. goost gauge hose.
Post 569401 by sartain87 on 2013-02-04 00:12:17
Theres one already exposed without a cap, the car has a slight idle problem would that cause it? I know it sounds silly but is one supposed to be uncovered?
Post 569402 by M-R-P on 2013-02-04 00:14:23
Nope. All supposed to be sealed. This may cause an idle problem but would deffo cause boost problems with the actuator or recirc valve.
Post 569403 by sartain87 on 2013-02-04 00:15:31
Your a star and such a quick response, even at this ungodly hour of the night. I'll use the exposed one for the boost gauge then, thank you.
