Considering S60R as daily driver
Post 567846 by rikcougar on 2013-01-30 14:48:26
As above guys Toying with the idea of an S60R as a daily driver What pitfalls am I likely to encounter, not bothered about mpg, goes with the territory and I know about the transfer box concerns How much quicker than my C70? (stribo has both I think) Anybody selling one? (This does mean that I might not be able to afford a mid 80`s 3dr Fruad with a huge spoiler on the back so please try and convince me of the merits of the R) Many thanks in anticipation
Post 567849 by stribo on 2013-01-30 14:58:20
Hi Rik, yes we have both, and Rachel uses the R as a daily driver, I get to play at weekends. ;) The power delivery I would say is more brutal than the C70, as boost comes in a bit later, but a lot harder, and it's defintely quicker than the C70 as you'd expect with a 60bhp advantage. It's the road holding you'll notice the most, even in the wet you can really throw it into a corner hard, and it'll just grip and go, none of the wheelspin you'll be used to with the C70. I'd definitely recommend one, it may not have the heritage, or looks of the Cossie, but in standard form, it'll run rings around it, and in greater comfort. :D
Post 567856 by M-R-P on 2013-01-30 15:04:52
Just remember the running costs - £250 for one shock, Angle gear, BCU, ECU etc VVT ECU isn't cheap either is it Stribo? But then, when you take on a performance car, you take on everything that goes with it. S60R is a lovely car, with or without a horrible orange interior :D
Post 567857 by Wobbly Dave on 2013-01-30 15:05:18
In standard form you shouldn't have much in the way of problems. 4c suspension can wear out - depends on age & is not cheap to fix. The angle gear is prone to failure. Turning circle as with all S60 p2s is poor.
Post 567859 by stribo on 2013-01-30 15:07:55
[QUOTE=M-R-P;567856]Just remember the running costs - £250 for one shock, Angle gear, BCU, ECU etc [COLOR="#FF0000"]VVT ECU isn't cheap either is it Stribo?[/COLOR] But then, when you take on a performance car, you take on everything that goes with it. S60R is a lovely car, with or without a horrible orange interior :D[/QUOTE] No, but it's cheaper than a DIM.:P As you say any performance car isn't going to be pennies to run, but will be a lot of fun, especially with a lovely orange interior. :D BTW it didn't need the VVT ECU (which is probably all part of the main ECU) just the unit itself which adjusts the cam timing, and AFAIK all ME7 engines have VVT, so are just as at risk of a VVT fault.
Post 567861 by M-R-P on 2013-01-30 15:10:32
[QUOTE=Wobbly Dave;567857] Turning circle as with all S60 p2s is poor.[/QUOTE] Turning circle in ALL P2s is poor, the R models are worse. The R front wheels don't so much turn as lean in the direction of travel. V70 T5 - 11.6M turn V70R - 14.3M turn. Something close to that anyway. Just don't get lost in any tight country roads unless you're good at reversing.
Post 567862 by stribo on 2013-01-30 15:11:04
[QUOTE=Wobbly Dave;567857]In standard form you shouldn't have much in the way of problems. 4c suspension can wear out - depends on age & is not cheap to fix. The angle gear is prone to failure. Turning circle as with all S60 p2s is poor.[/QUOTE] Yeah, how could I forget the turning circle, it's actually worse than the other S60's which in themselves are bad enough.
Post 567866 by rikcougar on 2013-01-30 15:26:46
Not too bothered about running costs, fun is normally expensive and I did consider a Maserati for a brief moment! Have heard about the turning circle but I guess you get used to it There are not many about for sale at the moment and I really want one of the light blue ones (same as Santa`s don`t know the colour) There is a nice low miles one on fleabay in Birmingham, don`t know if anybody knows it Is tyre wear heavy and is the "Dale Winton" interior an option, I do quite like it and does it wear OK Does the 4C suspension make much difference when switched between the various modes (And a million other questions which I will get round to eventually with your permission)
Post 567871 by M-R-P on 2013-01-30 15:52:11
The seats are basically the same frame Volvo have used for years. The R seats have slightly bigger bolsters. The colour doesn't seem to fade on the Dale winton ones. Usual Volvo high quality stuff really.
Post 567883 by Harvey on 2013-01-30 16:51:26
Yes nice motors they do like a bit more TLC than most cars but keep on top of things should be ok. I have had my one 18 months still love it to drive mpg sits at 18 mpg but it does do a lot of short trips.
Post 567885 by oblark on 2013-01-30 16:59:13
[QUOTE=rikcougar;567866]Not too bothered about running costs, fun is normally expensive and I did consider a Maserati for a brief moment! Have heard about the turning circle but I guess you get used to it There are not many about for sale at the moment and I really want one of the light blue ones (same as Santa`s don`t know the colour) There is a nice low miles one on fleabay in Birmingham, don`t know if anybody knows it Is tyre wear heavy and [COLOR="#FF0000"]is the "Dale Winton" interior an option[/COLOR], I do quite like it and does it wear OK Does the 4C suspension make much difference when switched between the various modes (And a million other questions which I will get round to eventually with your permission)[/QUOTE] The "dale winton" interior was a £1000 factory optional extra.
Post 567886 by stribo on 2013-01-30 17:03:08
You do notice a lot of difference between the different suspension settings, ours generally stays in comfort, but I put it in sport on the motorway, because in comfort it's so smooth you can end up going a lot faster than you think you are. Advanced isn't really suitable for our roads as it's just to jiggly, probably better on the track, certainly the choice for the 1/4 mile. Flash Green does look good, but I don't think the Atacama interior goes well with it, they clash IMO, obviously I like the Black/Atacama combo. ;)
Post 567889 by Kingsford G on 2013-01-30 17:24:01
If u not bothered about running costs etc. find a good one and get it mate.Don`t buy 1 with orange interior tho :wink:
Post 567893 by stribo on 2013-01-30 17:28:12
[QUOTE=Kingsford G;567889]If u not bothered about running costs etc. find a good one and get it mate.Don`t buy 1 with orange interior tho :wink:[/QUOTE] You love our 'ginger' interior. :P
Post 567895 by T5frankie on 2013-01-30 17:32:17
[QUOTE=rikcougar;567866]Not too bothered about running costs, fun is normally expensive and I did consider a Maserati for a brief moment! Have heard about the turning circle but I guess you get used to it There are not many about for sale at the moment and I really want one of the light blue ones (same as Santa`s don`t know the colour) There is a nice low miles one on fleabay in Birmingham, don`t know if anybody knows it Is tyre wear heavy and is the "Dale Winton" interior an option, I do quite like it and does it wear OK Does the 4C suspension make much difference when switched between the various modes (And a million other questions which I will get round to eventually with your permission)[/QUOTE] the colour of the light blue you like is flash green lol
Post 567896 by Kingsford G on 2013-01-30 17:40:30
[QUOTE=stribo;567893]You love our 'ginger' interior. :P[/QUOTE] :biggrin: I do.
Post 567944 by Santa on 2013-01-30 20:51:15
[QUOTE=rikcougar;567866] There are not many about for sale at the moment and I really want one of the light blue ones (same as Santa`s don`t know the colour) There is a nice low miles one on fleabay in Birmingham, don`t know if anybody knows it Is tyre wear heavy and is the "Dale Winton" interior an option, I do quite like it and does it wear OK Does the 4C suspension make much difference when switched between the various modes (And a million other questions which I will get round to eventually with your permission)[/QUOTE] Hi Rick, Mines Flash Green I don't know the car but I do know the place. I went there years ago to see a Black S60R and even though the pictures showed a mint car and the description stated the same the car had scrapes on all 4 corners of the bumpers, every alloy was a complete mess. I just walked away and bought the one I have now a week later. (Note I think the garage had a different name back then). S60R's are pretty good with tyres to be honest. You want the dark blue interior, its the best one lol. There is a major difference between the modes, feel free to try mine if you wish.
Post 568012 by LeeT5 on 2013-01-31 04:10:08
[QUOTE=rikcougar;567866]Not too bothered about running costs, fun is normally expensive and I did consider a Maserati for a brief moment! Have heard about the turning circle but I guess you get used to it There are not many about for sale at the moment and I really want one of the light blue ones (same as Santa`s don`t know the colour) There is a nice low miles one on fleabay in Birmingham, don`t know if anybody knows it Is tyre wear heavy and is the "Dale Winton" interior an option, I do quite like it and does it wear OK Does the 4C suspension make much difference when switched between the various modes (And a million other questions which I will get round to eventually with your permission)[/QUOTE] Hi As a daily runner S60R/V70R are fine. Stribo's average 18mpg seems incredibly low considering my average is 22mpg and before anyone says "i drive like a fanny with my grandma in the back", i can assure you i don't. As anyone with an R can confirm its physically impossible to not put your foot down most of the time....a bit like trying not to chew a fruit pastile!! When you first get one i would insist that for the first year you just accept that you will have an open cheque book because if you don't then you'll never get on top of the maintenance whether the cars immaculate or not. unless its lived in a showroom there will be things that need tending to and they might be expensive. Once your on top then its very easy and relatively cheap to stay there. Don't be tight on maintenance, genuine where possible and always, always carry out basic servicing when its due inc rear diffs and angle gear oils. £1000 will see the suspension in mint condition, Proper 4 wheel alignment and good make tires will increase mpg. A couple of trips to the dealer will make sure your car has all the latest software inc SUM calibration and ver.3 software (massively improves the ride of the shocks). Headlamp alignment must be done every year because they gradually creep down due to vibration and bumpy roads. Atacama interior, as said, was a £1000 option so if you can find one, seriously consider it. The leather is slightly more taut and not as soft as the Gobi and Nordkapp. Be careful of the drivers seat bolster as it wears very easy. Be careful wearing jeans as the rivets mark the leather very easily. If your going to be doing 15k or more a year then i would consider a good seat cover, otherwise a few years down the line it will have a huge impact on reasale value and new seats covers are £562 each + vat. clean and nourish the leather every year to maintain its luster. At 100k you'll be changing the clutch if its been driven nicely and that will be £1400 - £1700 all in. At 120k your PCV will need replacing £160. Shocks have come down in price but remember, they must be replaced as a pair!! £500 minimum + top mounts £50ea x 2 + support plates at £56 ea x 2. So that £700 for each axle or £1400 for all 4 corners (not including another SUM calibration and wheel alignment) At 100k, if it hasn't done so already, expect the Angle gear (transfer box) to let go anytime soon.....£700. Exhausts last forever as they are SS as oe, however most ppl change so i recommend custom build as its cheaper than BSR/MTE/Ferrita/etc and IMHO much better, £450. Common faults are MAFs and Fuel pressure sensors, £300 and £50 respectively. Electrically P2 R models are sound. Mechanically their strong. They hardly ever breakdown. Ask yourself this.....when did you last see a P2 on the back of a truck? Try and get one with RTi (makes add on's for future upgrades slightly easier) Climate control is super cold and very powerful, so make sure it works before you buy, else it will hurt your wallet alot. Sound system is bloody fantastic. Finding one with a sunroof is a bonus as most don't have one but all do have Electronic climate control as standard. Performance wise they are absolutely amazing in the wet. They are additively fast and guarantee to put a smile on your face. They are awesome in the snow too (plenty of videos on you tube to prove my point) Remap is a must as it will improve your mpg as well as the performance. Ive pretty much covered all the major points. The only other thing i would say is when you find one, try and get an R owner off the forum to come with you to view the car as they will know all the important things to look out for.
Post 568018 by rikcougar on 2013-01-31 07:24:50
Many thanks for your wise words and advice guys I am lucky that I will be in a position to not worry about what it costs to run What are they like when remapped, I get the distinct impression that they are quite savage as standard and do the engines last as long as the stereotypical Volvo unit? Cossie will go up in value dramatically but cannot be used daily, will the R have lemming like depreciation After that just leaves one question - R or cossie? Answers on a postcard please...................
Post 568025 by graemewelch on 2013-01-31 08:54:00
big fin cossie for me everytime. just love old fords.
Post 568027 by Santa on 2013-01-31 08:57:25
[QUOTE=rikcougar;568018]Many thanks for your wise words and advice guys I am lucky that I will be in a position to not worry about what it costs to run What are they like when remapped, I get the distinct impression that they are quite savage as standard and do the engines last as long as the stereotypical Volvo unit? Cossie will go up in value dramatically but cannot be used daily, will the R have lemming like depreciation After that just leaves one question - R or cossie? Answers on a postcard please...................[/QUOTE] Well your looking for a daily driver and you say the Cossie couldn't be used daily? Plus if the value of the Cossie is set to explode just buy both? Cossie appreciating will offset the R and you have the Cossie for those summer weekends (all 2 of them) and the R for daily work. (Might be able to get the Cossie under SIPPS/SSAS or similar pension scheme for tax relief. Cossie as part of your pension investment portfolio, couldn't think of anything cooler).
Post 568050 by Wobbly Dave on 2013-01-31 11:03:24
Buy Ian Burchi's V70R - it's already tuned & has all of the pitfalls already fixed.
Post 568069 by rikcougar on 2013-01-31 12:44:01
[QUOTE=Wobbly Dave;568050]Buy Ian Burchi's V70R - it's already tuned & has all of the pitfalls already fixed.[/QUOTE] Thanks Dave, not a fan of V70`s mate, much prefer the S, a lot prettier
Post 568104 by stribo on 2013-01-31 15:59:51
[QUOTE=LeeT5;568012]Hi As a daily runner S60R/V70R are fine.[COLOR="#FF0000"] Stribo's average 18mpg seems incredibly low [/COLOR]considering my average is 22mpg and before anyone says "i drive like a fanny with my grandma in the back", i can assure you i don't. As anyone with an R can confirm its physically impossible to not put your foot down most of the time....a bit like trying not to chew a fruit pastile!! When you first get one i would insist that for the first year you just accept that you will have an open cheque book because if you don't then you'll never get on top of the maintenance whether the cars immaculate or not. unless its lived in a showroom there will be things that need tending to and they might be expensive. Once your on top then its very easy and relatively cheap to stay there. Don't be tight on maintenance, genuine where possible and always, always carry out basic servicing when its due inc rear diffs and angle gear oils. £1000 will see the suspension in mint condition, Proper 4 wheel alignment and good make tires will increase mpg. A couple of trips to the dealer will make sure your car has all the latest software inc SUM calibration and ver.3 software (massively improves the ride of the shocks). Headlamp alignment must be done every year because they gradually creep down due to vibration and bumpy roads. Atacama interior, as said, was a £1000 option so if you can find one, seriously consider it. The leather is slightly more taut and not as soft as the Gobi and Nordkapp. Be careful of the drivers seat bolster as it wears very easy. Be careful wearing jeans as the rivets mark the leather very easily. If your going to be doing 15k or more a year then i would consider a good seat cover, otherwise a few years down the line it will have a huge impact on reasale value and new seats covers are £562 each + vat. clean and nourish the leather every year to maintain its luster. At 100k you'll be changing the clutch if its been driven nicely and that will be £1400 - £1700 all in. At 120k your PCV will need replacing £160. Shocks have come down in price but remember, they must be replaced as a pair!! £500 minimum + top mounts £50ea x 2 + support plates at £56 ea x 2. So that £700 for each axle or £1400 for all 4 corners (not including another SUM calibration and wheel alignment) At 100k, if it hasn't done so already, expect the Angle gear (transfer box) to let go anytime soon.....£700. Exhausts last forever as they are SS as oe, however most ppl change so i recommend custom build as its cheaper than BSR/MTE/Ferrita/etc and IMHO much better, £450. Common faults are MAFs and Fuel pressure sensors, £300 and £50 respectively. Electrically P2 R models are sound. Mechanically their strong. They hardly ever breakdown. Ask yourself this.....when did you last see a P2 on the back of a truck? Try and get one with RTi (makes add on's for future upgrades slightly easier) Climate control is super cold and very powerful, so make sure it works before you buy, else it will hurt your wallet alot. Sound system is bloody fantastic. Finding one with a sunroof is a bonus as most don't have one but all do have Electronic climate control as standard. Performance wise they are absolutely amazing in the wet. They are additively fast and guarantee to put a smile on your face. They are awesome in the snow too (plenty of videos on you tube to prove my point) Remap is a must as it will improve your mpg as well as the performance. Ive pretty much covered all the major points. The only other thing i would say is when you find one, try and get an R owner off the forum to come with you to view the car as they will know all the important things to look out for.[/QUOTE] We get 24mpg day to day, or 35 if following V70Graham. ;)_
Post 568158 by Al115 on 2013-01-31 18:28:15
24 seems pretty typical for a manual R - mine is about the same.
Post 568497 by Sharkey R on 2013-02-01 18:01:33
[QUOTE=rikcougar;568018]Many thanks for your wise words and advice guys I am lucky that I will be in a position to not worry about what it costs to run What are they like when remapped, I get the distinct impression that they are quite savage as standard and do the engines last as long as the stereotypical Volvo unit? Cossie will go up in value dramatically but cannot be used daily, will the R have lemming like depreciation After that just leaves one question - R or cossie? Answers on a postcard please...................[/QUOTE] I love Cossies but for one simple reason I'd go for the 'R' every time! Everyone expects a Cossies to go like stink. 99% of people don't realise what the 'R's are like. Nothing more satisfying than surprising someone that thinks the 'R' is an old mans car ;-p
Post 568503 by T5frankie on 2013-02-01 18:05:50
[QUOTE=Al115;568158]24 seems pretty typical for a manual R - mine is about the same.[/QUOTE] just checked my s4's mpg average since i set it 14.8 lol
Post 568505 by V70 Graham on 2013-02-01 18:15:11
[QUOTE=t5frankie;568503]just checked my s4's mpg average since i set it 14.8 lol[/QUOTE] I'd easily double that.....and some !
Post 568517 by T5frankie on 2013-02-01 18:50:55
[QUOTE=V70 Graham;568505]I'd easily double that.....and some ![/QUOTE] yeah but i'm having more fun
Post 572008 by rikcougar on 2013-02-11 13:18:46
[ATTACH=CONFIG]20247[/ATTACH] I seem to have bought this
Post 572010 by danny-R on 2013-02-11 13:22:22
Wow! Best cosworth on the forum so far. (sorry lee if you see this lol)
Post 572011 by M-R-P on 2013-02-11 13:23:50
Funny looking S60.... Is that an aurotec body kit? ;)
Post 572013 by rikcougar on 2013-02-11 13:28:16
Sorry guys, I know I have let you all down but the cossie is a three box of Kleenex car whereas the R only merited two. R is a great drive but compared with the cossie it is too sanitised and lacking in feel, the cossie feels like it has the potential to kill you at any moment and the thing is alive
Post 572028 by stribo on 2013-02-11 14:21:18
Beautiful car mate.
Post 572032 by V70 Graham on 2013-02-11 14:45:44
That does look nice.
Post 572034 by graemewelch on 2013-02-11 14:48:56
my fav car of all time. lets see some more pics of the beast
Post 572039 by jotter22 on 2013-02-11 15:29:37
[QUOTE=graemewelch;572034]my fav car of all time. lets see some more pics of the beast[/QUOTE] +1. Tony.
Post 572145 by smithy on 2013-02-11 19:06:53
That's gorgous mate my fab is te rs500 but 50 grand no thanks .are you going to take it on the strip and what mods has it got
Post 572150 by Jamest5r on 2013-02-11 19:15:59
Me like a lot :)
Post 572154 by T5frankie on 2013-02-11 19:31:35
wow mate ive just spunked myself lol
Post 572186 by rikcougar on 2013-02-11 20:37:27
[ATTACH=CONFIG]20263[/ATTACH] [ATTACH=CONFIG]20264[/ATTACH] [ATTACH=CONFIG]20265[/ATTACH] [ATTACH=CONFIG]20266[/ATTACH] [ATTACH=CONFIG]20267[/ATTACH]
Post 572191 by stribo on 2013-02-11 20:39:56
It's an absolutely stunning example Rik, if it was mine I'd be scared to drive it in case some tw@t bumped it.
Post 572195 by T5frankie on 2013-02-11 20:43:37
did you get it from miltok keynes?
Post 572211 by rikcougar on 2013-02-11 20:57:18
[QUOTE=t5frankie;572195]did you get it from miltok keynes?[/QUOTE] Spalding Frankie Haven`t collected it yet, have left a deposit and she is having an mot tomorrow, collect on Saturday if it`s dry all being well and then the fun begins Car is pretty standard apart from wheels and stage 1 tune (270ish) even has standard exhaust on it, goes well - about half the weight of my C70 It`s gonna be a long week!
Post 572213 by T5frankie on 2013-02-11 20:59:33
[QUOTE=rikcougar;572211]Spalding Frankie Haven`t collected it yet, have left a deposit and she is having an mot tomorrow, collect on Saturday if it`s dry all being well and then the fun begins Car is pretty standard apart from wheels and stage 1 tune (270ish) even has standard exhaust on it, goes well - about half the weight of my C70 It`s gonna be a long week![/QUOTE] looks sweet mate, its a proper summer sunday car, what are you gonna use it for?
Post 572222 by rikcougar on 2013-02-11 21:14:11
[QUOTE=t5frankie;572213]looks sweet mate, its a proper summer sunday car, what are you gonna use it for?[/QUOTE] Sundays mate! Dry days and lots of shows, my eight year old is a proper petrolhead so no doubt he will have a say as well Going to Spa for the F1 and Festival of Speed at Goodwood this year so might take the Cossie Track days are always an option :rolleyes2
Post 572226 by smithy on 2013-02-11 21:17:12
[QUOTE=rikcougar;572211]Spalding Frankie Haven`t collected it yet, have left a deposit and she is having an mot tomorrow, collect on Saturday if it`s dry all being well and then the fun begins Car is pretty standard apart from wheels and stage 1 tune (270ish) even has standard exhaust on it, goes well - about half the weight of my C70 It`s gonna be a long week![/QUOTE] I would keep it pretty stock too be honest to keep its value and use for summer use only .or stuff it and mod the §§§§ out of it with a nice t38 lol
Post 572227 by T5frankie on 2013-02-11 21:18:51
[QUOTE=rikcougar;572222]Sundays mate! Dry days and lots of shows, my eight year old is a proper petrolhead so no doubt he will have a say as well Going to Spa for the F1 and Festival of Speed at Goodwood this year so might take the Cossie Track days are always an option :rolleyes2[/QUOTE] see you at the classic ford show and ford fair then?, cheap to insure too lol
Post 572230 by rikcougar on 2013-02-11 21:22:26
[QUOTE=smithy;572226]I would keep it pretty stock too be honest to keep its value and use for summer use only .or stuff it and mod the §§§§ out of it with a nice t38 lol[/QUOTE] I won`t do anything that can`t be returned to standard, first job will be to remove the standard exhaust and fit a stainless and find some standard wheels, it needs to be reliable above all else Just the pleasure of driving it and watching the heads turn will do until the novelty wears off!
Post 572233 by rikcougar on 2013-02-11 21:25:33
[QUOTE=t5frankie;572227]see you at the classic ford show and ford fair then?, cheap to insure too lol[/QUOTE] Deffo be at those two, probably do Central and National Ford days as well and we always do Blackpool Ford day for the weekend, insurance is a steal, cheaper than C70!
Post 572302 by silverhorse on 2013-02-12 05:20:22
[QUOTE=rikcougar;572222] Track days are always an option :rolleyes2[/QUOTE] Noooooooooooooooo!! some tw4t in an Audi A3 diesel WILL hit you
Post 573223 by rikcougar on 2013-02-14 07:55:58
Update MOT passed with no advisories, she is paid for so I just need to pick her up on Saturday morning :banana::banana::banana: Two sleeps to go
