HU-803 CD Changer Unit Swap - You CAN do it if needed, and heres an easy how to
Post 563593 by Liddo on 2013-01-18 16:58:03
I had to do this as the replacement unit i bought off Ebay wouldnt light up and the steering wheel buttons didnt work. Some of you may need to do this in the very near future :( Start off with your HU 803 Image Remove the cup holder and mounting bracket Remove top cover, only 4 screws, the one on the left rear is the long one Top Image Rear Image Now take off both side panels, lots of screws, a few long ones, so note where they go Image Image Image Unhook the CD unit from the rubber dampers at the rear Image Lift the CD unit at the rear and pull out, and disconnect the ribbon cable (no need to remove the front fascia) Image This is what your left with Image Take your working CD unit rebuild in reverse order, just make sure that the CD unit is mounted on the rear dampers and the earth strap on the CD unit is screwed in with a long screw on the left rear of the stereo Image The hardest bit is getting the DAMN stereo back in the dash (well it was for me) Enjoy :)
Post 563600 by V70 Graham on 2013-01-18 17:21:24
Nice walkthrough, with good pictures, I'm sure this will come in handy for someone.
Post 563613 by stephenevans99 on 2013-01-18 17:41:58
Superb....worthy of being made a 'Sticky' I reckon.
