uprated drop-links
Post 551587 by claymore on 2012-12-01 19:16:47
So,can you list the parts up and a link to the web site?
Post 551589 by Harvey on 2012-12-01 19:21:44
Look good,will be interesting how they last as the brass will wear (as its alot softer than the stock ones ) you will need to fit the boots,I thing you will have to use some studlock on the threads as they will take a pounding on our roads
What is the weight diffrance from the stock items,
Post 551605 by p fandango on 2012-12-01 20:09:18
[QUOTE=claymore;551587]So,can you list the parts up and a link to the web site?[/QUOTE]
2 x lhd M10 rose joints LINK
2 x rhd M10 rose joints LINK
1 x pack of 10 lhd locknut LINK
1 x pack of 10 rhd locknut LINK
2 x 300mm turnbuckle LINK
4 x weather boot LINK
you'll also need 4 x M10 nut & bolt to fit them, & a small spacer on the top mount between the droplink & shock to sit it right
Post 551607 by p fandango on 2012-12-01 20:12:07
[QUOTE=Harvey;551589]Look good,will be interesting how they last as the brass will wear (as its alot softer than the stock ones ) you will need to fit the boots,I thing you will have to use some studlock on the threads as they will take a pounding on our roads
What is the weight diffrance from the stock items,[/QUOTE]
i haven't got a standard one off the car to weigh it, but i'll weigh these later
Post 551609 by Wobbly Dave on 2012-12-01 20:15:20
Without the weather proof boots - they will fail like my QBM ones did. I suppose it depends on how often you intend to use the car.
Post 551613 by p fandango on 2012-12-01 20:22:28
[QUOTE=Wobbly Dave;551609]Without the weather proof boots - they will fail like my QBM ones did. I suppose it depends on how often you intend to use the car.[/QUOTE]
i've bought the boots, but a bitch to get on so for the price just replace them every year if need be
Post 551627 by p fandango on 2012-12-01 21:04:45
[QUOTE=Harvey;551589]What is the weight diffrance from the stock items,[/QUOTE]
these weigh 0.5kg each, that seems a bit heavy lol
Post 551678 by Harvey on 2012-12-01 22:28:25
[QUOTE=p fandango;551627]these weigh 0.5kg each, that seems a bit heavy lol[/QUOTE]
What are the advantage of these over stock ones,have you seen or bent the link rod.
That is a fair bit of weight to add to the sprung mass of the suspension.
I know the volvo ones are quite expensive,but there are some good quality pattern parts around.
At £15 each.
Post 551707 by PHIL V70R on 2012-12-01 23:25:32
nice.....
Post 551743 by p fandango on 2012-12-02 03:21:55
[QUOTE=Harvey;551678]What are the advantage of these over stock ones,have you seen or bent the link rod.
At £15 each.[/QUOTE]
Hopefully it'll improve the efficiency of the anti roll bar, having a bar 20-23mm thick connected at each end by a 8mm drop link can't be passing all the lateral movement to it
Post 552798 by woz on 2012-12-08 00:05:05
..At £15 each.[/QUOTE]
There is no benefit whatsoever - its the word "uprated " which makes people do it, but its not uprated anymore than putting a steel bumper instead of plastic.
Fatandheavy would be a better decription. Now using 8mm tube instead with low friction ball joints might count - IF it was lighter than standard. Whatabout an alloy rod, or even carbon fibre. That might cocunt buit bet you would never notice the difference> Better off turning a few mm off the inside of the wheels to reduce the unsprung weight AND rotarional inertia at the same stime.
Waste of time and money. I guess if its a full race car and you have bent one I could understand it - but hands up anyone who has had one of these ACTUALLY fail??
Thought not.
How many times have I posted this?
p.s. you could get the same effect on your handling by just putting a load of lead on your lower arm. Cheaper too!
Post 552799 by woz on 2012-12-08 00:10:32
[QUOTE=p fandango;551743]Hopefully it'll improve the efficiency of the anti roll bar, having a bar 20-23mm thick connected at each end by a 8mm drop link can't be passing all the lateral movement to it[/QUOTE]
Sorry Pedro - it wont. In any case the A/R bar doesn't resist lateral movement at all - only roll motion. The ball joints see to that - the link rod can only be in direct tension or compression unless the B/j is seized. Thats whole the point of it.
To resist lateral motion, you need stiffer TCA bushes.
Woz:>) Grabted they may look nice though.
Post 552817 by JT on 2012-12-08 09:06:10
[QUOTE=woz;552798]There is no benefit whatsoever - its the word "uprated " which makes people do it, but its not uprated anymore than putting a steel bumper instead of plastic.
Waste of time and money. I guess if its a[COLOR="#FF0000"] full race car [/COLOR]and you have bent one I could understand it - but hands up anyone who has had one of these ACTUALLY fail??
Thought not.
p.s. you could get the same effect on your handling by just putting a load of lead on your lower arm. Cheaper too![/QUOTE]
well they will be put to the test on my car, so we'll find out:)
Post 552819 by Harvey on 2012-12-08 09:32:19
Just to add seen a Renault with plastic drop links,and they were very small items as well.
Post 552822 by p fandango on 2012-12-08 09:58:53
[QUOTE=Harvey;552819]Just to add seen a Renault with plastic drop links,and they were very small items as well.[/QUOTE]
Their French, so there technology doesn't count for anything lol
Post 552876 by p fandango on 2012-12-08 17:20:59
[QUOTE=woz;552798]Fatandheavy would be a better decription. Now using 8mm tube instead with low friction ball joints might count - IF it was lighter than standard. Whatabout an alloy rod, or even carbon fibre. That might cocunt buit bet you would never notice the difference> Better off turning a few mm off the inside of the wheels to reduce the unsprung weight AND rotarional inertia at the same stime.[/quote]
compared to the overall weight of the components that are already unsprung, especially as you say the rotational parts "uprating" the droplinks is going to make no noticable difference at all
[quote]Waste of time and money. I guess if its a full race car and you have bent one I could understand it - but hands up anyone who has had one of these ACTUALLY fail??
Thought not.[/quote]
even steel has some elasticity, so once the cornering load has been removed they'll return to the original form. Another Volvo forum is having an issue with poor design of the droplink mounts on some coilovers, all that have failed have had "uprated" droplinks. Perhaps flex in the standard links is saving the tabs from snapping on others?
wouldn't really know, & tbh even if i had read it before i'd still be doing exactly the same
Post 552877 by p fandango on 2012-12-08 17:32:33
[QUOTE=woz;552799]Sorry Pedro - it wont. In any case the A/R bar doesn't resist lateral movement at all - only roll motion. The ball joints see to that - the link rod can only be in direct tension or compression unless the B/j is seized. Thats whole the point of it.[/QUOTE]
i'd agree with you, if the droplinks were in a perfect linear position on all axis, & compression was perfectly verticle but its not (otherwise their'd be no need for need for ball joints). With the G force's pushing a 1.6tonne car on an 8mm bar at an offset angle its going to try & get rid of that energy in the easiest fashion, which with a bar that thin is going to be outwards at the weakest point (the middle)
Post 552893 by FIREBOLT on 2012-12-08 19:01:41
You can see where the top ball joint of the droplink has been hitting the inner wing & bending the tab on the strut on all three of the above pics. Obviously slammed their cars & still think they can drive on full lock.
I have adjustable drop links for my V40 as it will sit so low, with standard length droplinks the angles are so extreme they would fail in no time. Aong with the issue the cars above are having.
The shortest droplinks are for the front, as they now attach to the lower arm. I can if I want use the longer ones to attach to the struts instead. Depends what feels better when driving. They also weigh about half that of the oem links.
Post 552900 by p fandango on 2012-12-08 19:23:34
[QUOTE=FIREBOLT;552893]You can see where the top ball joint of the droplink has been hitting the inner wing & bending the tab on the strut on all three of the above pics. Obviously slammed their cars & still think they can drive on full lock.[/QUOTE]
as you can see on the coil-over thread, only 1 of them is what i would call "slammed". The first pic (who has the highest ride height) has gone thru 2 sets now
Post 552901 by Harvey on 2012-12-08 19:38:20
Looking at this photo they have also changed the anti roll bar I would guess it thicker stronger so the next weakest link to go was the tabs welded on strut.
[/QUOTE]
Are they that much bigger to hit the bodywork on lock.
Post 552902 by FIREBOLT on 2012-12-08 19:53:40
[QUOTE=p fandango;552900]as you can see on the coil-over thread, only 1 of them is what i would call "slammed". The first pic (who has the highest ride height) has gone thru 2 sets now[/QUOTE]
Ok then, lower than standard, either way they are still hitting in the same place on all 3 pics. Could be a mixture of things from extra camber (they look like D2 coilovers so probably have adjustable top mounts?) moving the strut closer to the inner arch. Or maybe the ball joints do not have the same amount of movement as oem drop link. Causing them to bind at full lock & bending the strut tabs instead. The tabs look to have been worked back & forth.
I certainly wouldn't have fitted a second set without finding the cause of the fault first.
Post 552903 by p fandango on 2012-12-08 20:07:40
[QUOTE=FIREBOLT;552902]Ok then, lower than standard, either way they are still hitting in the same place on all 3 pics. Could be a mixture of things from extra camber (they look like D2 coilovers so probably have adjustable top mounts?) moving the strut closer to the inner arch. Or maybe the ball joints do not have the same amount of movement as oem drop link. Causing them to bind at full lock & bending the strut tabs instead. The tabs look to have been worked back & forth.[/quote]
they have had contact of some sort, but going by the marks wouldn't say its been repeatative. As you can see the droplinks are different manufacturers, what are the chances of them all having limited movement
the first failed after 4 days so was put down to a manufacturing fault i believe
its a shame i've binned my lining, i wouldn't be surprised if there are others with contact marks on the inner wing with different suspension manufactures
Post 552904 by JT on 2012-12-08 20:09:13
I have 3.5 degree of camber on the front and the struts don't rub the inner wing, but then again, I very rarely use full lock.
Maybe as mentioned before, what some of us use on a track, won't work on the road
Post 552905 by p fandango on 2012-12-08 20:11:20
[QUOTE=Harvey;552901]Looking at this photo they have also changed the anti roll bar I would guess it thicker stronger so the next weakest link to go was the tabs welded on strut.[/quote]
i'm not sure if they are all running IPD bars. Tabs would be the next weakest if the links weren't absorbing/flexing ;)
Post 552906 by FIREBOLT on 2012-12-08 20:12:03
[QUOTE=Harvey;552901]Looking at this photo they have also changed the anti roll bar I would guess it thicker stronger so the next weakest link to go was the tabs welded on strut.[/QUOTE]
The tabs should only have an up & down load applied to them, these have been bent back & fourth. The ball joints should allow for this movent & not bend the tabs.
Post 552908 by p fandango on 2012-12-08 20:31:30
[QUOTE=FIREBOLT;552906]The tabs should only have an up & down load applied to them, these have been bent back & fourth. The ball joints should allow for this movent & not bend the tabs.[/QUOTE]
here's a pick of mine on full left & full right lock, as you can see the angle movement of the droplink really isn't that much. You can also see that on full right lock it would make contact with the arch lining if i'd got them, but again really wouldn't be enough to bend a tab back & forth enough to snap it
Post 552909 by FIREBOLT on 2012-12-08 20:38:58
Just thinking when I last saw this! The anti roll bar was moving left to right rather than twisting, causing the drop links to hit the body. These were with aftermarket bars & were sliding in the bushes. Think they re-made the bars with collars either side of the arb mounts to hold them in place.
Post 552919 by JT on 2012-12-08 20:59:19
