OBD1 Gearbox speed sensor to OBD2 Please help!
Post 548772 by merc85 on 2012-11-18 22:16:22
As above, Will be fitting the later m56h box to my to my early 850. The Early box's sensor takes the ready off the drive shaft in the box. My later box doesnt have this, I have bin told you have to wire it to the n/s cv joint. Has anyone posted a definitive guide to doing this please, Would really appreciate the advice. Will be fitting the engine and box next saturday, im guessing i have to splice into the abs wires to the cv joint and all should be ok?? Kind regards Gav/merc85
Post 548773 by M-R-P on 2012-11-18 22:18:30
Pedro knows about this... he'll probably be here soon...
Post 548778 by p fandango on 2012-11-18 22:30:58
simply wire it to the ABS wheel speed sensor on the hub, not tried it myself but been told it works
Post 548780 by M-R-P on 2012-11-18 22:31:27
Tadaaa!
Post 548783 by p fandango on 2012-11-18 22:35:53
[QUOTE=M-R-P;548780]Tadaaa![/QUOTE] if it wasn't for the F1 being on so late i'd be asleep by now lol
Post 548787 by merc85 on 2012-11-18 22:38:14
[QUOTE=p fandango;548778]simply wire it to the ABS wheel speed sensor on the hub, not tried it myself but been told it works[/QUOTE] Do you still keep the abs wire connected to that cv joint? or do you just wire/plug the speed sensor to it and leave the abs wire un conected?
Post 548788 by M-R-P on 2012-11-18 22:39:29
Gotta splice it in mate, keeping it all connected, just pigg-back-ing off what's there.
Post 548791 by merc85 on 2012-11-18 22:55:40
Thanks for the replies, Be good to here from someone who has done this, just to confirm the matter, Really apreciate the replies tho :)
Post 548793 by Volvostorm on 2012-11-18 22:57:03
Yeah, it works, done it to mine Knew I had a picture somewhere! Image Image
Post 548796 by M-R-P on 2012-11-18 23:02:57
How come you have a Left track rod on the right hand side? lol :D
Post 548797 by Volvostorm on 2012-11-18 23:06:29
They have been changed since then, but a good point! Its been like that for years, must have bought it like that!
Post 548798 by merc85 on 2012-11-18 23:08:01
[QUOTE=Pault5estate;548793]Yeah, it works, done it to mine Knew I had a picture somewhere! Image Image[/QUOTE] Your a Star! thankyou very much buddy, And M P, That pic is correct LH stamped on the Track rod end and it is the LH side as you can see the gearbox. Ta peeps very happy now :)
Post 548799 by M-R-P on 2012-11-18 23:08:16
lol
Post 548800 by M-R-P on 2012-11-18 23:11:08
[QUOTE=merc85;548798]Your a Star! thankyou very much buddy, And M P, That pic is correct LH stamped on the Track rod end and it is the LH side as you can see the gearbox. Ta peeps very happy now :)[/QUOTE] Aaahhh yep, that is the left hand side lol (track rods go behind the hub on Volvos lol) good spotting Gav... BUT somebody thought I was right lol ;) oh dear pmsl!
Post 548801 by Volvostorm on 2012-11-18 23:13:35
I couldn't remember, changed them in August!, still, I will have another look next time I'm up the unit :D
Post 548802 by t5steve on 2012-11-18 23:26:07
just to doubly confirm it works......................had to do this on shrecks car after gearbox change....................info once again courtesy of pedro............thanks
Post 548805 by merc85 on 2012-11-18 23:32:51
Its always handy to have hands on experience when confirming these mods as you wouldn't wanna take a 850 gearbox out twice in one day. Ta peeps very helpful as usual :)
Post 597281 by Scairns22 on 2013-04-16 23:05:10
Hi guys gona hijack this thread a little bit. I have a simiar problem. I have an obd1 car with obd2 t5 wih m59 box. The engine loom has been swapped so no plug for the gearbox sensor. Ive decided to wire direct from an abs sensor to the dash cluster. Is this possible and will it work? I have been told to use the yellow/brown wire in pin a3 of the larger plug. The car has 1995 wiring in dash but 1996 clocks from 850r. Any advice would be great thanks.
