common faults with v40s pls
Post 541401 by bucky on 2012-10-11 13:38:27
any ideas any1
Post 541417 by craigoodwood on 2012-10-11 15:43:37
vvt, weak anti roll bar mounts, headlight wiper motors....
Post 541612 by CONDYBOY on 2012-10-12 17:13:03
rust behind front indicators. listen for clicking when turning the steering wheel as the top shock bearings can be bad. also the interior blower can be faulty. it's not the motor but a small control unit that fails listen for the motor changing speeds by itself. rear bushes can fail.
Post 541623 by Jimmie on 2012-10-12 19:01:24
They are no worse than any other on the road and a lot better than most. Buy one if you fancy one as they are good for 200,000+ miles if serviced properly. Remember all mechanical equipment can break down regardless at times.
Post 542297 by nobananas on 2012-10-15 21:38:15
Rear link arm bushes go but the arms are cheap to replace, avoid the GDi (Mitsubishi gasoline injection engine) which is a 1.8 and quite noisy and prone to sludging/coking up due to poor egr design , confusingly they also did a Volvo 1.8 engine. Diesel is a 1.9 Renault unit and pretty reliable and hard to break. The 40 series was based on the Mitsubishi Carisma if memory serves.
Post 543045 by CONDYBOY on 2012-10-21 14:37:07
[QUOTE=nobananas;542297]Rear link arm bushes go but the arms are cheap to replace, avoid the GDi (Mitsubishi gasoline injection engine) which is a 1.8 and quite noisy and prone to sludging/coking up due to poor egr design , confusingly they also did a Volvo 1.8 engine. Diesel is a 1.9 Renault unit and pretty reliable and hard to break. The 40 series was based on the Mitsubishi Carisma if memory serves.[/QUOTE] I had heard that the 40 was the first vehicle to use the floorpan used in the Ford Focus, not sure how true that is though. It does share some suspension bushes with mitsis tho'
Post 543096 by lance on 2012-10-21 19:06:54
It was the mk 2 2004 on S40,C70,C30 & V50 that shared the mark 2 focus chassis. I think the s40 v50 t5s make a brilliant buy and are getting cheaper!
Post 543712 by Haizum74 on 2012-10-25 16:25:34
Definitely droplinks, rear calipers can seize , Blower resistor can go which you will notice when the blower doesnt work unless turned up to 6. If it blows slow then fast intermittantly then its dry joints/broken solder on the control module which is an easy fix. Well, replacing the resistor is also easy too just a bit of faffing under passenger foot well. Handbrake button can stick but thats nowt nor summat. Bonnet cable is another one that can go too which is a 1 1/2 job max.
