V40 diesel
Post 538587 by zoidberg on 2012-09-27 10:16:48
OK, after joining the Volvo tribe with a V70 awd, I moved onto an 850 T5.Got rid awhile back as I have a Lancia Delta project (still) on the go.Had a Golf diesel as a run around then part ex'd with a mate for a Renualt Kangoo van which I am currently using, been a god send at times with collecting bits for the Lancia. Anyway, t'other week said mate ends up off loading a V40 DIESEL on me !! Body work is very tidy as is interior. Problems............................ well the bit on top of the radiator that goes back to the expansion bottle had snapped off and pipe wouldnt stay attached once started to heat up rad. So replaced it on Saturday and it now drives fine...engine wise. However, it hops and skips all over the place at the ยงยงยงยง end when going over all the pot holes around here. One of the tyres is almost bald (rear nearside), so I'm presuming it is all rear suspension related.If I am thinking of keeping it (still got T+T), what bits would I need ?? Also it aint got an intercooler, would fitting one in the airflow line work without any other mods, or would the fuel rate etc need messing with. It's on an 'R' plate if it makes any difference. Cheers Steve.
Post 538943 by nobananas on 2012-09-29 23:11:21
The old V40's/s40's suffered from wear in the link arms on the rear suspension, this would account for the twitchy rear end and most likely the excessive tyre wear as they affect the camber and rear tracking. Not a difficult job to change but you would likely need a 4 wheel alignment afterwards.
Post 543635 by teddy241091 on 2012-10-25 01:37:50
Should have intercooler i have td v40 an there not the easyest to see they look just like a normal radiator at the front lol an there also quite big for standered also they came with 2 difrent diesel engines one of which was a renult engine an have a tendency of turbos going an thanks nobananas will av look into my rear bushs as cars seems to be getting fair bit of camber at the back prob doest help that im running 18 inch dare alloys lol an zoidberg if you know hasnt had service lately give it one they respond well from service done mine otherday an i can feel a definet power increase an smoother engine
Post 543647 by JUDGENINJA on 2012-10-25 08:06:28
Nice thing to know if that the underside has a lot in common with a Mistubushi Lancer/FTO so if you are looking at upgrades there is quite a bit out there.
Post 545111 by CONDYBOY on 2012-11-04 00:43:50
Rear bushes as already stated check shocks at the same time. but probs just the bushes given the tyre wear.
Post 557023 by teddy241091 on 2012-12-29 01:01:11
step dads just bought a v40 td renualt engine model an has difrent intercooler to mine hidden right down the front right hand side of engine bay an its also on a R reg
