Post 534217 by pv544t5 on 2012-09-01 21:29:38
Hi.last few days my t5r has taken more starting,more so when its been stood a while.takes 3-4 secs winding before it fires and starts-once running it seems to run fine.read the flash codes and that is clear,changed the idle control valve today,still no change.considering changing the flywheel sensor next.
does anyone have any insight into this type of problem.thanks
Pete
Post 534222 by JamesT5 on 2012-09-01 21:50:52
Is it not the starter motor?
Post 534253 by pv544t5 on 2012-09-02 07:57:07
no,starters fine,its just delayed at starting/firing up.
Post 534271 by JamesT5 on 2012-09-02 11:30:39
[QUOTE=pv544t5;534253]no,starters fine,its just delayed at starting/firing up.[/QUOTE]
Maybe it's a fuel pump issue?
Post 534338 by M-R-P on 2012-09-02 19:02:18
Fpr, or even fuel filter.
Also, if the battery is getting on a bit, it may be worth changing that too.
Post 534986 by pv544t5 on 2012-09-04 22:08:57
batterys fine,just changed fuel filter(due one anyway),tried different flywheel sensor-did notice when changing sensor that the dizzy cap and rotor could do with changing so got some on order ! when switching the ignition on,you can hear the fuel pump running till it gets up to pressure.
Post 537935 by pv544t5 on 2012-09-23 11:10:35
story so far-new fuel filter,dizzy cap, rotor,swapped parts from my hotrod project over including idle valve,crank sensor,fuel pressure reg and fuel pump,no flash codes show up but still taking several seconds to start.I am running lpg but i have tried starting with that switched off with no difference. any other ideas before I explode !!
Pete
Post 537994 by 960kg on 2012-09-23 17:05:01
Fpr, bad starting hot and cold or maybe CTS but will give poor running and less mpg
The FPR is down above the steering rack on drivers side, it is not the one on the fuel rail which is a pulsation damper, it could be this?
Post 538031 by pv544t5 on 2012-09-23 20:06:10
Ok,could be my mistake then as it was the fuel rail one i changed,I will have a look for the real fpr ! whats a cts ?
cheers
Pete
Post 538078 by 960kg on 2012-09-24 09:29:11
CTS = Coolant Temperature Sensor
It is screwed in under the thermostat. Effects performance including mpg, dictates fuel mix according to temp of engine.
Post 621557 by pv544t5 on 2013-06-30 21:17:04
I sorted the starting problem.when i ran out of lpg,it started fine.discovered the diaphram in the lpg vapouriser poss had hole in it,letting lpg down the vacuum pipe and into the manifold-thus flooding the engine.replaced rubber diaphram and problem was cured.
