mbc valves are the dogs
Post 45855 by craig on 2005-09-26 20:21:39
well i managed to pluk up the guts to fit my new mbc without the info id of liked but i couldnt wait , i pre set the pressure to 12psi and fitted it in about 20 minutes , i just needed an extra length of pipe acouple more jubilee clips and a washer hose t piece . took it down the road gave it some boot and FECK ME the turbo punched in and lit the tyres up in 1st 2nd and 3rd grabbed 4th and DOH over boost fuel cut out took it home and turned it down to 11 psi and its fine now and the boost gauge needle goes just off the gauge and it goes like stink. if you cant afford rica yet and want more power GET AN MBC £ 49 from reliaboost next day delivery
Post 45865 by lil_me on 2005-09-26 21:21:35
I can get MBC's cheaper I think, I'll look into it but I think they are about £30/£35, if I can get them I'll post them to peeps if they want them as I goto the stockist quite regular. Doubt postage will be more than a couple of quid. They aren't as shiney as the ones from the likes of reliaboost but do the same job and are reliable, some people have said ones from other companies have failed after time.
Post 45882 by siamblue on 2005-09-26 23:39:46
They are a great bit of kit £ per hp.
Post 45906 by jmuggali on 2005-09-27 10:57:05
how would this affect wear etc. My car has been well looked after with a 155k on the clock no oil leaks and well serviced, would like to fit an MBC but dont want to kill the engine or turbo.
Post 45912 by craig on 2005-09-27 11:41:15
heres a question for siamblue i notice youve got a mod youve called " Reverse I/C " what is this mod ? how do i do it ? and what gain in performance is it? thanks mate
Post 45914 by craig on 2005-09-27 11:49:02
[QUOTE=jmuggali]how would this affect wear etc. My car has been well looked after with a 155k on the clock no oil leaks and well serviced, would like to fit an MBC but dont want to kill the engine or turbo.[/QUOTE] in my opinion mate if you set it so as its not boosting too far off the gauge you will be ok its not as if you drive round with it on full boost all the time , besides if youve set it too high it will over boost and the engine cuts the fuel for a second and stops you before you kill it ,so JUST DO IT its amazing on a standard t5
Post 45916 by siamblue on 2005-09-27 12:01:35
[QUOTE=craig]heres a question for siamblue i notice youve got a mod youve called " Reverse I/C " what is this mod ? how do i do it ? and what gain in performance is it? thanks mate[/QUOTE] Reverse I/C was used by Volvo on the first T5's to come out, but because of frost and snow problems the T5 couldn't handle the cold weather on start up, so they went for the system where it doesn't go striaght over the engine, and routed it around the engine if you look at a standard T5 then look at my I/C pipe you will see the difference, There's a place in the States that now sells a kit, REVERSE I/C Image
Post 45944 by jmuggali on 2005-09-27 14:53:42
[QUOTE=craig]in my opinion mate if you set it so as its not boosting too far off the gauge you will be ok its not as if you drive round with it on full boost all the time , besides if youve set it too high it will over boost and the engine cuts the fuel for a second and stops you before you kill it ,so JUST DO IT its amazing on a standard t5[/QUOTE] My brother has one on a chiped RS Turbo and it just leaves me off the line so I might even the playingfeild a bit with one, do you have any web sites I could look at? thanks James.
Post 46001 by craig on 2005-09-27 18:11:18
here are a few sites you can look at ARMVAL turbo performance Joe P MBC manual boost controllers PRO MAX Reliaboost boost controller if you wanna beat your brother once youve fitted it , set it as high as you can without overboost and try racing him once your both moving other wise youl just light up the tyres in 1st (as if they dont anyway) but beleive me you wont believe the difference it makes i manually pre set mine with a foot pump to 12 psi but had to turn it down to 11 psi My mrs came back from town in it today (1st time shed driven it) and said to me WHAT HAVE YOU DONE TO THE CAR YOU TWAT I NEARLY KILLED MYSELF IN IT ,IT NEARLY LAUNCHED ME IN TO THE BACK OF A TAXI i dont know what your talking about dear ??
Post 46040 by nobananas on 2005-09-27 21:11:47
I bought an Armval MBC from Ebay for £24.99 inc del which is the same price as their website. Haven't fitted it yet but it looks a good bit of kit, plain and simple without big knobs and arrows and the words BOOST slapped all over it ! Delivery was damn quick too. Someone should do a fitting guide in the knowledge section.
Post 46047 by p fandango on 2005-09-27 21:26:26
[QUOTE=nobananas]Someone should do a fitting guide in the knowledge section.[/QUOTE] i've got fitting instructions on my computer (with pics), if you send me your email address i'll send you them. They were written with the help of an old T-5 forum which is why i'm not posting them in public (not sure on what copyright etc are on them)
Post 46053 by nobananas on 2005-09-27 21:47:14
Silly me ! You've already emailed them to me a while back ! No excuse now, roll on the weekend !
Post 46150 by p fandango on 2005-09-28 15:39:54
[QUOTE=nobananas]Silly me ! You've already emailed them to me a while back ! No excuse now, roll on the weekend ![/QUOTE] sometimes i wonder why i bother :slap: lol
Post 46177 by T5TIM on 2005-09-28 17:17:49
[QUOTE=craig]here are a few sites you can look at ARMVAL turbo performance Joe P MBC manual boost controllers PRO MAX Reliaboost boost controller if you wanna beat your brother once youve fitted it , set it as high as you can without overboost and try racing him once your both moving other wise youl just light up the tyres in 1st (as if they dont anyway) but beleive me you wont believe the difference it makes i manually pre set mine with a foot pump to 12 psi but had to turn it down to 11 psi My mrs came back from town in it today (1st time shed driven it) and said to me WHAT HAVE YOU DONE TO THE CAR YOU TWAT I NEARLY KILLED MYSELF IN IT ,IT NEARLY LAUNCHED ME IN TO THE BACK OF A TAXI i dont know what your talking about dear ??[/QUOTE] :B_rotfl: :B_rotfl:
Post 46201 by siamblue on 2005-09-28 19:00:26
I know what she meant lol.
Post 46368 by marwen on 2005-09-29 18:17:05
Have just bought a MBC from E-Bay, paid £15.99 including free delivery. Has arrived today, looks agood bit of kit, stainless steel adjuster/nut and stainless steel ball bearing and spring, Its only small and very discreet(no arrows,Boost,blasted all over it). The guy who sells them is in Australia and it took 5 days to arrive. If interested the item number is 8001961566. (sorry cant put a link to the web page, Have only just leant how to turn the PC on)!!!! P.S He also includes some instructions and states the controller is set to just above the standard boost for the car.Will let you know how it performs.
Post 46395 by jmuggali on 2005-09-29 19:46:44
[QUOTE=marwen]Have just bought a MBC from E-Bay, paid £15.99 including free delivery. Has arrived today, looks agood bit of kit, stainless steel adjuster/nut and stainless steel ball bearing and spring, Its only small and very discreet(no arrows,Boost,blasted all over it). The guy who sells them is in Australia and it took 5 days to arrive. If interested the item number is 8001961566. (sorry cant put a link to the web page, Have only just leant how to turn the PC on)!!!! P.S He also includes some instructions and states the controller is set to just above the standard boost for the car.Will let you know how it performs.[/QUOTE] Now you lot are just making it too dam easy!! I have very good instructions and I'm halfway convinced and at £15 whats to lose (engine, turbo, tyres, licence!)
Post 46401 by dicky b t5 on 2005-09-29 19:53:52
[QUOTE=jmuggali]Now you lot are just making it too dam easy!! I have very good instructions and I'm halfway convinced and at £15 whats to lose (engine, turbo, tyres, licence!)[/QUOTE] Yes i know wot you mean...!lol Might have to look into getting one ..
Post 52258 by The Flying Banana on 2005-10-24 15:41:45
http://cgi.ebay.co.uk/RTP-Nuke-manual-boost-controller-turbo-mbc_W0QQitemZ8008749496QQcategoryZ32094QQrdZ1QQcmdZViewItem http://cgi.ebay.co.uk/Precision-manual-boost-controller-turbo-mbc-etc_W0QQitemZ8008749495QQcategoryZ32094QQrdZ1QQcmdZViewItem http://cgi.ebay.co.uk/NEW-Turbo-Manual-Boost-Controller-not-Bleed-Dump-Valve_W0QQitemZ8009330565QQcategoryZ72205QQrdZ1QQcmdZViewItem After reading the differenc ethes emake think I'll get one just to see the difference... for the guys here who have one do these two chaps look OK..two different types/ methods...what do you think?
Post 53367 by gjb71 on 2005-10-29 14:32:37
this sounds to good to be true, wots the catch. and if i do get one whats the max boost i could realistically run on 1 2001 v70
Post 53378 by Mrsmopp on 2005-10-29 15:07:37
[QUOTE=gjb71]this sounds to good to be true, wots the catch. and if i do get one whats the max boost i could realistically run on 1 2001 v70[/QUOTE] And there is the catch, you cant fit them to ME7 Volvo's. Anything pre 99 should be fine if fitted with care but the ME7 just wont have it I'm afraid :( x
Post 53884 by weasel on 2005-11-01 01:47:27
anyone know performance figures for these things and won't they cause the mixture to be too lean?
