Post 531957 by J-2 on 2012-08-22 04:18:40
Hi, Any ideas on what the engine code is for the 260bhp 2.4 T5 unit? (2005-2007 S60's) I can't seem to find anything online or on Wikipedia regarding it. Thanks!
[QUOTE=J-2;531957]Hi, Any ideas on what the engine code is for the 260bhp 2.4 T5 unit? (2005-2007 S60's) I can't seem to find anything online or on Wikipedia regarding it. Thanks![/QUOTE] B5244T4 hope that helps
Thanks burchi. Where did you find that information from?
B = benzine (petrol) 5 = number of cylinders 24 = 2.4 4 = valves per cylinder T - turbo 4 no idea :)
B = benzine (petrol) 5 = number of cylinders 24 = 2.4 4 = valves per cylinder T - turbo 4 = no idea :)
Right done some digging on google & the last. Umber identifies the model
Thanks DTP, I know how the decoding works I'm just wondering which revision the 260bhp is, and if it has an engine code assigned to it? I need to know for sure when buying an replacement engine. For example they made a 250 and a 260bhp in the same year. If the 260bhp is the T4 then I'm assuming the 250bhp is the T3? And the rest are LPT's?
Hi J-2 I have a 2005 55plate V70 T5 the engine code for that is : B5244T5 Regards Ploppy
[QUOTE=ploppy;532675]Hi J-2 I have a 2005 55plate V70 T5 the engine code for that is : B5244T5 Regards Ploppy[/QUOTE] Hi Ploppy, Can you confirm if you're one is the 260bhp unit? Thanks!
[QUOTE=J-2;535558]Hi Ploppy, Can you confirm if you're one is the 260bhp unit? Thanks![/QUOTE] it is......:B_thumb: im sure the facelift 2.4 T5's were all 260bhp... my car, 2002 2.3 T5 is the 245bhp version... the last letter in the code relates to the type of turbo i believe..... the plastic panel that covers the side of your cambelt should state your engine code..??
[QUOTE=d2k;535633]the last letter in the code relates to the type of turbo i believe[/QUOTE] it can relate to any evolution of the engine, software, turbo, power level etc
[QUOTE=p fandango;535634]it can relate to any evolution of the engine, software, turbo, power level etc[/QUOTE] ah....... in steps the knowledge!! :wink: cheers mate.....
[QUOTE=J-2;535558]Hi Ploppy, Can you confirm if you're one is the 260bhp unit? Thanks![/QUOTE] Yes yes,,, its the 260bhp ex plod job...
[QUOTE=ploppy;535657]Yes yes,,, its the 260bhp ex plod job...[/QUOTE] Hi, thanks for all the replies. The only reason I'm after the 260 unit is because it shares a few things with the R engine, and is also equipped with exhaust VVT. Basically the best of both worlds :)
