Fan
Post 529349 by vaderboyo on 2012-08-07 22:39:32
went out tonight and gave the awd a good thrashing down the a55 just for 15mins. parked up and the fan stayed on for about 5 mins....thermostat is ok and water coolant levels fine. just thinking is this normal and do these engines run very hot? cheers
Post 529353 by LiamT4 on 2012-08-07 22:48:35
If the engine is very hot, then the fan can come on for a while even though the engine is off. If you do go out for a good drive try to drive slowly for a few minutes before you park up and then give it a couple of mins to cool down before you turn the engine off. Remember that turbos can get very hot.
Post 529359 by M-R-P on 2012-08-07 22:58:11
The fan being on can also be a sign of there being a problem of some sort and the ecu doing what it can to protect the engine. See if you can get the codes read, incase there was a problem at some point during your "spirited" drive.
Post 529365 by Dangerous Dave on 2012-08-07 23:15:18
Is the temperature gauge reading normal (usually about 3 o clock on the gauge)?
Post 529387 by vaderboyo on 2012-08-08 00:32:28
yes guage sits at 3pm most of the time...sometimes dips a bit but only on very long journeys...2hrs plus..
Post 529392 by Dangerous Dave on 2012-08-08 00:51:25
Really it shouldn't dip, don't think mine ever has on long journeys, only when I had a thermostat and temperature sender problem did the gauge move about. There could be a problem somewhere then. I've never had the fans stop on after I've really caned it, not even when my gasket had gone and then expansion tank was whistling.
Post 529399 by claymore on 2012-08-08 07:33:53
[QUOTE=vaderboyo;529387]yes guage sits at 3pm most of the time...sometimes dips a bit but only on very long journeys...2hrs plus..[/QUOTE] Ahhh, ther's your problem, the gauge needle should sit as 3AM :)
