Tuning info needed asap :)
Post 528842 by hybriduno on 2012-08-05 14:47:10
Ok so as some of you will know i have a large project underway, http://www.vpcuk.org/forums/showthread.php?45078-Hi-heres-my-little-project-%29 but now i need some info for whiteblock tuning. As far as im aware the main ball ache on white blocks are the rods. The standard turbo is a 15g (numbers i can find. 15g - - - - 89-01310 barcode > 9146785) The re-map is sorted as ARD tuning are interested in sponsoring my project So whats the best and easiest mods? turbo/injectors/remap/ obviously when i get the car finished i need to service her anyway so why not get building now :)
Post 528885 by LiamT4 on 2012-08-05 17:57:57
I suppose the main question is how much power do you want? The ecus on these cars aint the best for custom mapping, so if you want to go for big power then it may be best to get a Turbo tuner ecu, which costs a fair bit more than an off the shelf map but is far better when it comes to having more upgrades, but is still about half the cost of a full standalone ecu. The 15g turbo is quite small, but does boost well at low revs, though you'll definatly need a bigger turbo if you want more than 300bhp. As for injectors, again it depends on how much your looking for, most on here go for volvo green injectors (s60r) or vxr blues when going over 300bhp.
Post 528886 by hybriduno on 2012-08-05 18:01:18
i would like over 300bhp ;) thats if she can take the original amount
Post 528889 by LiamT4 on 2012-08-05 18:10:57
Rods would be a good idea when going over 300bhp. Places to start then should be a 19t turbo, vxr or volvo green injectors, larger throttle body, race cat or de-cat and also a good fmic, there are a few different manifolds from newer cars that'll help get more power(me7 or s60r manifolds). Those mods, with good mapping, should see you comfortably past 300bhp. I'm sure they'll be others with alternatives and other good tips for getting more power out of your car.
Post 528909 by p fandango on 2012-08-05 18:53:10
if ARD are sponsoring you i'd be seeing what spec Lucky recommends for his higher stage maps, he's an unbelievably knowledgeable chap (& helpful)
Post 528915 by hybriduno on 2012-08-05 19:18:31
Thanks liam. i am having a large intercooler against one of the side windows and a map from ARD i so now ill go injector and turbo hunting :)
Post 528916 by hybriduno on 2012-08-05 19:20:22
[QUOTE=p fandango;528909]if ARD are sponsoring you i'd be seeing what spec Lucky recommends for his higher stage maps, he's an unbelievably knowledgeable chap (& helpful)[/QUOTE] Yeah ive emailed him and asked him which way to go, :) i would like to find another whiteblock to be honest and get it totally done as far as i can possibly go. then onto a redblock in another project i have in mind ;)
Post 528966 by LiamT4 on 2012-08-05 21:59:45
[QUOTE=hybriduno;528915]Thanks liam. i am having a large intercooler against one of the side windows and a map from ARD i so now ill go injector and turbo hunting :)[/QUOTE] I did wonder where you would fit your intercooler, should look pretty good with it fitted there. lol
Post 528974 by hybriduno on 2012-08-05 22:28:23
[QUOTE=LiamT4;528966]I did wonder where you would fit your intercooler, should look pretty good with it fitted there. lol[/QUOTE] Intercooler one side , oil cooler the other ;) air filter in the middle :)
