Whats this Filter for....
Post 45536 by Col44 on 2005-09-25 12:11:11
.....big chap front left hand side,looking front on ,just behind bumper low down?
Post 45538 by Rufe on 2005-09-25 12:28:04
does it look like this? Image if so, its the carbon filter mate.
Post 45540 by Col44 on 2005-09-25 12:35:38
No its narrower ,its like a diesel fuel filter on an old transit. :)
Post 45541 by Rufe on 2005-09-25 12:43:42
dont know what a transit filter looks like lol, but is it more square than that one, instead of cylindrical?
Post 45542 by Rufe on 2005-09-25 12:48:59
*keeps trying* lol Image like this one then? (still a carbon filter)
Post 45543 by Col44 on 2005-09-25 12:51:10
Its the size width and lenght of two coffee(or tea) mugs on top of each other!
Post 45544 by Rufe on 2005-09-25 12:52:05
hmm, you got me thinking now? lol only other thing i can think of is the crank breather (oil trap) this? Image
Post 45545 by t5owner on 2005-09-25 13:09:57
Left as in drivers side as your looking at it i:e OFF SIDE or left as in the left of the car i:e NEAR SIDE or commonly known as the passenger side the only thing that should be hanging that low at the front is as mentioned b4 its the evap or carbon canister sits on a bracket just slightly away from the air dam and fluid cooling pipes (not radiator) i think their turbo oil cooler related Cheers stuart
Post 45546 by t5owner on 2005-09-25 13:15:47
[QUOTE=Col44]Its the size width and lenght of two coffee(or tea) mugs on top of each other![/QUOTE] Deffo sounds like the carbon filter however have you got any wires or pipes coming out Possibly it could be part of a third party alarm immobiliser installation i:e could be an additional siren Has the car got additional alarms fitted or just the standard volvo stuff Is the car explod as it could be somthing they forgot to remove when it was decomed from the fleet i:e power supply for strobes or air horns Mmmmm puzzled as well just looked under my car and there is nothing on the off side that hangs that low just behind the bumper Any chance of posting a couple of pics keep em below 97 kb so nothing hi res Cheers stuart
Post 45552 by Col44 on 2005-09-25 14:18:57
Cheers Guys,i'll get a photo up later. More pressing problem just arose,rear n/s caliper is seizing up. Took the family out for 1st wee shot 2 miles later squeeling started gets out the disc is roasting. Got it home ,the caliper frees off with a tap or two with a hammer then it get really hard again to turn disc once pedal 's pressed again. I'm away to do a search on here :jaw:
Post 45589 by Col44 on 2005-09-25 20:13:55
Post 45596 by LeeT5 on 2005-09-25 20:46:28
[QUOTE=Col44].....big chap front left hand side,looking front on ,just behind bumper low down?[/QUOTE] That is the carbon canister m8 for the exhaust gas recirculation system. :anmflower
Post 45600 by Col44 on 2005-09-25 21:10:35
Cheers Lee , is it a servicable item, it looks a bit worse for ware?
Post 45601 by audimadmike on 2005-09-25 21:19:52
If thats on the drivers side it is (and certainly looks like..) the air con filter drier..it is tatty because it can freeze up and often is covered in condensation thats why its rusty. Don't try to remove! Just to be certain, has it got two firm rubber pipes connected to the top with a large nut? If you run the air con you should notice a change in temperature on the filter.[COLOR=Red]b[/COLOR] Mike
Post 45640 by Vikingxl on 2005-09-25 23:08:10
I agree with audimadmike looks very much like the drier unit it should freeze up pretty quick with the air con on.
Post 45655 by LeeT5 on 2005-09-25 23:45:52
[QUOTE=audimadmike]If thats on the drivers side it is (and certainly looks like..) the air con filter drier..it is tatty because it can freeze up and often is covered in condensation thats why its rusty. Mike[/QUOTE] :troutslap OK maybe i was wrong (difficult to work out from piccy), but the easiest way to know is give it a tap! If it sounds like its full of granules then it is Carbon canister. Do not replace this..... as the saying goes..'IF IT AINT BROKE..DONT FIX IT'. Else trying to remove it could do damage. I have never heard of them being replaced anyway....consult main agent if not sure. Advice is free after all :)
Post 62621 by t5owner on 2005-12-05 14:50:41
Left of car as in looking from the front i:e off side or drivers side Having recently seen one of these off a car i can confirm it is the air con gas bottle / condensing unit Cheers stuart
Post 62638 by Wobbly Dave on 2005-12-05 15:29:44
[QUOTE=Col44]Cheers Guys,i'll get a photo up later. More pressing problem just arose,rear n/s caliper is seizing up. Took the family out for 1st wee shot 2 miles later squeeling started gets out the disc is roasting. Got it home ,the caliper frees off with a tap or two with a hammer then it get really hard again to turn disc once pedal 's pressed again. I'm away to do a search on here :jaw:[/QUOTE]I have 2 rear calipers going as salvage? Dunno if this is still relevant given the age of the thread
Post 64798 by Col44 on 2005-12-13 09:50:12
Thanks Dave,but yer right...all sorted :anmflower
