Post 528017 by vaderboyo on 2012-07-30 11:17:05
Hi. Before I go an mess it up, does anyone have step by step pics of how to change a door please? cheers
This on a phase 2 Vader? Front or rear?
Think its the same as the 850, which is quite easy TBH
The wiring connector is easy to do, undo the small screw in the connector and twist the connector to unlock it and pull it away from the car body.
Pull the rubber boot away from the door check strap base and undo the torx bolt.
The two hinges have large grub screws in them, loosen them off and the door should then lift off the hinge pins.
You can see the door connector and hinge grub srews in this pic
thats spot on cheers:B_thumb: its for the rear of my awd, think i have found some doors to swap over but was worried about alighments after replacement etc this is really helpful cheers
Door arrived, not as good as I was hoping but at least its a perfect colour match and better than whats already on there. Planning to change them over next week....if it stops raining lol
