K16 Turbo fitting onto an 850r
Post 524190 by evolvo on 2012-07-15 12:35:15
Hi i have a set of green injectors and i wish to fit a better turbo, so i've been looking at k16. I'll be getting a custom map as well. Mine has a t3 engine which is slightly uprated internals. Anybody done this before on here, i have seen k24's on t5d5 which are similar. Any advise would be good
Post 524250 by Rnash2002 on 2012-07-15 19:40:20
Whats the spec on the k16 cmpared to the k24?
Post 524510 by GregE102 on 2012-07-16 14:37:43
I am pretty certain that a K16 is of a Porsche 996 turbo they are supposed to be good for about 550 BHP on a Porker engine that is! As for a T5 engine I can't see it being any good? even though the porker guys claim it spools up early! I prefer smaller turbos like my Hybreed 16T its just has a light weight wheel fitted by Owens and ported & polished by Tim Williams. The other weekend at the the T5D5 track day I had the chance to have some flat out 3rd gear pulls against Black beast side by side and i was not very far behind him at all! I also drove His car on track and I have to say where my Turbo runs out of Puff his just keeps on pulling amazing! Even though I would love a big turbo, I love how my little turbo delivers its power! But thats also down to the mapping from Ben & Tim! PS 13.8 is quite quick for a T5!
Post 524521 by nosh on 2012-07-16 15:10:00
[QUOTE=evolvo;524190]Hi i have a set of green injectors and i wish to fit a better turbo, so i've been looking at k16. I'll be getting a custom map as well. Mine has a t3 engine which is slightly uprated internals. Anybody done this before on here, i have seen k24's on t5d5 which are similar. Any advise would be good[/QUOTE] hi, i am running a k16 hybrid turbo on my s40 t5 geartronic & it is epic!!!
Post 524523 by GregE102 on 2012-07-16 15:15:28
Is this turbo from a 4WD 996 porker then? or am I wrong? Cheers Greg
Post 524527 by nosh on 2012-07-16 15:18:44
[QUOTE=GregE102;524523]Is this turbo from a 4WD 996 porker then? or am I wrong? Cheers Greg[/QUOTE] no its from a focus mk2 rs 500.
Post 524529 by GregE102 on 2012-07-16 15:25:15
Ok thanks I did look up the turbo with Google and found this on a porker forum have a read: Product Information Alot of us have the K16 turbos on our Porsche 996 Turbo and like the quick spool. Not looking to break speed records, there is way to squeeze alittle more power from the K16's to pass their stock efficiency. The factory turbine wheel moves about 30lbs/min. With the 16G upgrade, you will see a gain of about 10lbs/min. Basically saying, the stock K16 turbos are good (based on turbo parts) for 550 crank horsepower. Of course depending on types of dyno's, boost settings, fuel tuning, etc, we would say at a 20% drivetrain loss for the AWD that it is more like 540 crank horsepower. This upgrade would increase the power output of your stock Porsche 996 Turbo K16's by (again based on turbo parts) about 60-80 crank horsepower. Maintaining quick spool with an OEM fit and headache free upgrade, you will see a large increase in mid to top end horsepower. By running the same amount of boost you do now on a flashed K16 car (1.0-1.1bar), you will make more power since you are moving more volume of air. This upgrade only requires more fueling from an OEM 5 bar fuel pressure regulator sold seperately. It does require doing an ECU Flash. SoftronicTuning.com has been doing ECU tuning for more then 15 years. Having done some of the first K16/16G upgrades, they have pump gas and race gas files ready to get your car going! To upgrade your K16 turbos, you will need to remove them from your vehicle and ship them to our Turbo Builder which we will supply you with the address and instructions. Please contact us first before shipping any products. Once we receive the turbos, we will modify them to the K16G level and clean up your stock turbos to be like new. All upgraded turbos include new 1.0bar wastegate actuators. This process is about 7-10 days once they are received. You are responsible for shipping to and from. If you have any technical questions, consult one of our Porsche Specialists. So made me think they where from Porsche Cheers Greg
Post 524539 by nosh on 2012-07-16 15:41:06
[QUOTE=GregE102;524529]Ok thanks I did look up the turbo with Google and found this on a porker forum have a read: Product Information Alot of us have the K16 turbos on our Porsche 996 Turbo and like the quick spool. Not looking to break speed records, there is way to squeeze alittle more power from the K16's to pass their stock efficiency. The factory turbine wheel moves about 30lbs/min. With the 16G upgrade, you will see a gain of about 10lbs/min. Basically saying, the stock K16 turbos are good (based on turbo parts) for 550 crank horsepower. Of course depending on types of dyno's, boost settings, fuel tuning, etc, we would say at a 20% drivetrain loss for the AWD that it is more like 540 crank horsepower. This upgrade would increase the power output of your stock Porsche 996 Turbo K16's by (again based on turbo parts) about 60-80 crank horsepower. Maintaining quick spool with an OEM fit and headache free upgrade, you will see a large increase in mid to top end horsepower. By running the same amount of boost you do now on a flashed K16 car (1.0-1.1bar), you will make more power since you are moving more volume of air. This upgrade only requires more fueling from an OEM 5 bar fuel pressure regulator sold seperately. It does require doing an ECU Flash. SoftronicTuning.com has been doing ECU tuning for more then 15 years. Having done some of the first K16/16G upgrades, they have pump gas and race gas files ready to get your car going! To upgrade your K16 turbos, you will need to remove them from your vehicle and ship them to our Turbo Builder which we will supply you with the address and instructions. Please contact us first before shipping any products. Once we receive the turbos, we will modify them to the K16G level and clean up your stock turbos to be like new. All upgraded turbos include new 1.0bar wastegate actuators. This process is about 7-10 days once they are received. You are responsible for shipping to and from. If you have any technical questions, consult one of our Porsche Specialists. So made me think they where from Porsche Cheers Greg[/QUOTE mine came off an rs 500 and AET TURBOS hybrid it for my s40... i have found it alot smoother & quicker than my previous hybrid stock turbo.
Post 524541 by GregE102 on 2012-07-16 15:43:00
Cheers Greg[/QUOTE mine came off an rs 500 and AET TURBOS hybrid it for my s40... i have found it alot smoother & quicker than my previous hybrid stock turbo.[/QUOTE] Sounds like a good turbo!
Post 524579 by nosh on 2012-07-16 17:26:42
yeah mate it seems to suit the t5
