quick shift fitted :D
Post 519202 by theflyingbrick on 2012-07-01 01:39:00
as above,i got these from martin peachey a while back but finally fitted it today (to my dads car anyway im yet to do mine) and ive got say....wow....its totally transformed the driving experience,theres alot less throw between gears and it just feels so much more positive and tight!! well i thought id share my findings as ive not seen much on here about quick shift kits,its hard to beleive when looking at it in your hand that its gonna do anything but trust me when its fitted you wont be dissapointed ;)
Post 519208 by p fandango on 2012-07-01 06:47:28
they do make an excellent difference, drilling the gear-selector arm compliments the short-shift plate very well (don't go closer than 50mm from pivot point) Image
Post 519210 by local-looney on 2012-07-01 06:52:59
Is that on ur s60 Pedro,or bt??????
Post 519213 by p fandango on 2012-07-01 08:01:54
[quote=850-shane;519210]Is that on ur s60 Pedro,or bt??????[/quote] BT. I'm sure Snabb did a plate for the newer M56 box (they have bigger cable bushes) so still should be able to do it mate
Post 519229 by theflyingbrick on 2012-07-01 09:30:31
[QUOTE=p fandango;519208]they do make an excellent difference, drilling the gear-selector arm compliments the short-shift plate very well (don't go closer than 50mm from pivot point) Image[/QUOTE ok i just realised im still rookie :o so what would this do??
Post 519252 by p fandango on 2012-07-01 10:31:55
[quote=theflyingbrick;519229]ok i just realised im still rookie :o so what would this do??[/quote] moving the pivot point of the other gearselector arm/cable shortens the side throw of the gearlever. The plate you've done only shortens the forward & back throw
Post 519257 by t5 stealth on 2012-07-01 10:40:02
iv had one of these for a long time too,finally fitted it yesterday lol, makes a big improvement :)
Post 519260 by oblark on 2012-07-01 10:56:57
I made mine own quick shifter plate. http://www.vpcuk.org/forums/showthread.php?t=40925 And yes what a difference it makes :D
Post 519271 by M-R-P on 2012-07-01 11:44:57
The o2 stuff uses a ball and socket rather than a pin and circlip. This means you have to remove the ball bit from the selector arm and drill it to M10, then fit 100mm bush inside the end of the rod where the socket used to be. This is very expensive to put back to stock, and the exact reason I didn't do mine. Grrrr.
Post 519278 by V70 Graham on 2012-07-01 12:27:13
Forgot about these, save me one Martin if it'll fit my P1.....another little job for ya, me thinks another trip to Poole soon lol (Brian needs his choccie lol)
Post 519284 by M-R-P on 2012-07-01 12:45:25
Will do mate ;)
Post 519548 by Aydenapp on 2012-07-01 22:51:28
Ive just made a handful of these at work. Any guides on how to fit them ?
Post 519551 by oblark on 2012-07-01 22:57:58
[quote=Aydenapp;519548]Ive just made a handful of these at work. Any guides on how to fit them ?[/quote] Here`s a clip from you tube [ame]http://www.youtube.com/watch?v=14gmpnwvUyI&feature=player_detailpage[/ame]
