C70 Exhaust Diameter??
Post 517509 by andybrown on 2012-06-27 10:42:21
Hi, i want a new tail pipe, but im not sure of the diameter of the pipe at the back. is it 60mm or larger? Thanks, Andy
Post 517560 by Wobbly Dave on 2012-06-27 12:44:50
Assume you are talking about a new tip? you can just measure the circumference if you don't have calipers & work out the radius. Circumference of a circle = PI x diameter = 2 PI [SIZE=-2]x[/SIZE] radius where PI = Image = 3.141592... Hence diameter is C / PI
Post 517571 by andybrown on 2012-06-27 13:31:36
[quote=Wobbly Dave;517560]Assume you are talking about a new tip? you can just measure the circumference if you don't have calipers & work out the radius. Circumference of a circle = PI x diameter = 2 PI [SIZE=-2]x[/SIZE] radius where PI = Image = 3.141592... Hence diameter is C / PI[/quote] Thanks Dave, just had a look, its 2.5" meaning the one i wanted wont fit!! :(
Post 517578 by vaderboyo on 2012-06-27 13:55:16
It will be important to get the correct measurement....as you see I cant count.. Image :biggrin:
Post 517587 by andybrown on 2012-06-27 14:15:11
[quote=vaderboyo;517578]It will be important to get the correct measurement....as you see I cant count.. Image :biggrin:[/quote] Love it!!! Just found an Etech one from Larkspeed that fits upto 65mm :)
