Brake cooling
Post 516374 by claymore on 2012-06-24 13:26:39
After the problems at Malory park, I've been thinking of ways to cool the disks down, my thoughts are either water cooling or even co2, has to be a cheaper option to bbk.
Post 516375 by daza-b on 2012-06-24 13:27:35
[quote=claymore;516374]After the problems at Malory park, I've been thinking of ways to cool the disks down, my thoughts are either water cooling or even co2, has to be a cheaper option to bbk.[/quote] will more air feeds to the brakes not work?
Post 516377 by oblark on 2012-06-24 13:29:29
[quote=claymore;516374]After the problems at Malory park, I've been thinking of ways to cool the disks down, my thoughts are either water cooling or even co2, has to be a cheaper option to bbk.[/quote] Cant you put some ducts in to direct fresh air onto the discs ? It works on F1 cars :D
Post 516379 by claymore on 2012-06-24 13:32:16
Duct's are fine on a track where there is plenty of forward momentum, but I'm thinking about prescott in August which is short straights and heavy braking.
Post 516383 by oblark on 2012-06-24 13:36:11
[quote=claymore;516379]Duct's are fine on a track where there is plenty of forward momentum, but I'm thinking about prescott in August which is short straights and heavy braking.[/quote] How about compressed air ?
Post 516386 by deathrider311271 on 2012-06-24 13:41:23
what pads and brake fluid you running?
Post 516388 by claymore on 2012-06-24 13:43:10
[quote=oblark;516383]How about compressed air ?[/quote] I have no way of compressing the air, I do have everything from my old co2 intercooler spray bar. Image
Post 516390 by claymore on 2012-06-24 13:45:11
[quote=deathrider311271;516386]what pads and brake fluid you running?[/quote] Mintex pads and dot 5.1 fluid
Post 516395 by deathrider311271 on 2012-06-24 14:04:53
[quote=claymore;516390]Mintex pads and dot 5.1 fluid[/quote] might be worth trying some either mintex 1166s or ferodo ds 3000 pads with Castrol React SRF Racing Brake Fluid none of this stuff is cheap but should improve the braking at high temps.
Post 516396 by t5 stealth on 2012-06-24 14:16:47
would spraying water or co2 on the discs not cause them to warp or crack as you will be trying to change the disc temps from hot to cold in split seconds , expansion and contraction of the metal may result in early failure,and even whilst being driven ? i understand what you meen about air flow, f1 did some thing on the external side of the wheel forcing air through the wheel to cool brakes,but again,as you say, not sure you would achieve much in the distance your driving,
Post 516397 by claymore on 2012-06-24 14:17:24
Problem is they're best part of £150, I know you get what you pay for, but I like to think out of the box, :)
Post 516398 by claymore on 2012-06-24 14:19:03
[quote=t5 stealth;516396]would spraying water or co2 on the discs not cause them to warp or crack as you will be trying to change the disc temps from hot to cold in split seconds , expansion and contraction of the metal may result in early failure,and even whilst being driven ? i understand what you meen about air flow, f1 did some thing on the external side of the wheel forcing air through the wheel to cool brakes,but again,as you say, not sure you would achieve much in the distance your driving,[/quote] I know it was common on rally cars and truck racing,
Post 516404 by T4Rick on 2012-06-24 14:57:58
[quote=claymore;516390]Mintex pads and dot 5.1 fluid[/quote] There is a blue brake fluid that i was told about last year and this was surposed to be the best its expensive though,and what about vents in the wings or bumper like the porsches do
Post 516409 by p fandango on 2012-06-24 15:17:29
have you binned the stone guard from behind the discs
Post 516417 by LiamT4 on 2012-06-24 15:34:43
I think that using something like water or c02 will cause cracking because of the sudden extreme temperature change, although i do think there are possibilties out there. I'm sure you'll come up with something. My garage always thought it was a bit stupid having the brake fluid reservoir sat right above the turbo.
Post 516428 by claymore on 2012-06-24 16:04:29
[quote=p fandango;516409]have you binned the stone guard from behind the discs[/quote] hell, yes, they went in the bin years ago.
