Fuel Cap & Boot Not Opening
Post 511872 by andybrown on 2012-06-13 23:58:40
Hi Guys! Ok, went to the out this evening, when we went back to the car, the alarm had been set off (no sound, its disconnected apparently!!) thought nothing of it, but shortly after i went to fill up as the fuel light was on, but the boot release button did not work, and it won't open the boot either. the key fob did open the boot a few times, but now that doesn't work either. Iv managed to hack my way in thanks to a large spanner, so i can fill up at least! Any ideas whats broken? I have tried an old boot / fuel cap switch as well, both dont work. And :)
Post 512160 by t5 stealth on 2012-06-14 18:58:11
what model is this............p2 v70 ? wait i just seen it.c70 lol.........sorry :)
Post 512174 by foammanmark on 2012-06-14 19:43:00
Similar happened to my C70, but it was the switch and I simply changed it. Could it be a fuse?
Post 512384 by Wobbly Dave on 2012-06-14 23:53:34
If you can get into the boot then you can use the manual release to open the fuel flap.
Post 512444 by andybrown on 2012-06-15 08:56:16
Update... The fuel cap now opens, but i cant get into the boot still, and it wont open with the key fob either :/
Post 512451 by t5 pete on 2012-06-15 09:28:52
[quote=andybrown;512444]Update... The fuel cap now opens, but i cant get into the boot still, and it wont open with the key fob either :/[/quote] If you use the key in the boot lock it will open the boot
Post 512453 by andybrown on 2012-06-15 09:47:48
[quote=t5 pete;512451]If you use the key in the boot lock it will open the boot[/quote] Unfortunately not in this case :(
Post 512455 by Wobbly Dave on 2012-06-15 09:55:46
I have spares to repair the fuel flap mechanism. Have you tried opening & closing the bonnet. Does the fob operate the central locking?
Post 512466 by andybrown on 2012-06-15 10:34:35
[quote=Wobbly Dave;512455]I have spares to repair the fuel flap mechanism. Have you tried opening & closing the bonnet. Does the fob operate the central locking?[/quote] Yeah the fob opens and locks the car fine, what can opening and closing the bonnet do for the boot? lol
Post 512468 by Wobbly Dave on 2012-06-15 10:42:21
I was wondering if your key fob /central locking system was working. Sometimes due to an incorrect closure of the bonnet - the key fob/ CLS stops.
Post 512469 by M-R-P on 2012-06-15 10:43:40
Isn't there a hidden keyhole in the boot lid, near the number plate light, like on some V70s?
Post 512474 by Wobbly Dave on 2012-06-15 10:48:31
There are only 2 methods of getting into the boot of a C70 - using the key - or using the fob. Well as far as I know - & I have done extensive surgery in that area. If the fuses are ok & the CLS is working the only other thing would be to push down on the lid to ensure that the lock is fully engaged & work it from there. This may result in the drilling out of that lock & its subsequent replacement.
Post 512482 by andybrown on 2012-06-15 11:04:46
[quote=Wobbly Dave;512468]I was wondering if your key fob /central locking system was working. Sometimes due to an incorrect closure of the bonnet - the key fob/ CLS stops.[/quote] Well it stopped opening after i had been at the fuse box in the engine bay, il have a look on my dinner break :)
Post 513955 by andybrown on 2012-06-18 13:20:53
FIXED! I replaced the fuse, the original wasnt blown, but the contacts were all crappy, so all is good. Just need to take the fuel cap off now and bend it back into shape :/ lol!
Post 513958 by Porcine_Aviator on 2012-06-18 13:44:18
[quote=andybrown;513955]FIXED! I replaced the fuse, the original wasnt blown, but the contacts were all crappy, so all is good. Just need to take the fuel cap off now and bend it back into shape :/ lol![/quote] Going to use your head to do that then ?:biggrin::hidesbehi
Post 513959 by V70 Graham on 2012-06-18 13:45:31
[quote=andybrown;513955]FIXED! I replaced the fuse, the original wasnt blown, but the contacts were all crappy, so all is good. Just need to take the fuel cap off now and bend it back into shape :/ lol![/quote] Glad it turned out to be a simple fix.
Post 513960 by Wobbly Dave on 2012-06-18 13:48:44
I have spare flaps in black & silver if you need them?
Post 513968 by M-R-P on 2012-06-18 14:41:35
Flaps :D
Post 513974 by andybrown on 2012-06-18 14:57:56
[quote=Porcine_Aviator;513958]Going to use your head to do that then ?:biggrin::hidesbehi[/quote] Haha, i think i need to!!! I might end up needing the Bracket Dave, depends how much i bent it!
Post 514004 by Wobbly Dave on 2012-06-18 16:00:46
small things amuse small minds eh Martin?
