Failing ETM Video
Post 511059 by JamesT5 on 2012-06-12 17:28:59
Hi I discovered this whilst doing some ETM cleaning reearch on ebay. Someone has put up a video showing the symptoms of a failing ETM. It might be useful for anyone who wants to have a look.... http://www.youtube.com/watch?NR=1&v=1hNDr0WgVQM&feature=endscreen Regards James
Post 511092 by M-R-P on 2012-06-12 18:47:32
So glad i have a bosch etm.
Post 511202 by JamesT5 on 2012-06-12 21:31:10
Well as we established, mine is still a Magneti Marelli unit so it could go again. I'm hoping some routine cleaning will reduce the risk of this.
Post 511236 by M-R-P on 2012-06-12 21:56:21
Unfortunately, the bit you'll be cleaning isn't the bit that goes wrong and i would strongly recomend you leave the internal gubbins well alone, one mistake could be a costly one :( You have a repaired unit so you should be ok for some time yet :) at 220k with no problems, I don't think there will be any problems. ;)
Post 511642 by local-looney on 2012-06-13 19:34:04
Aaarrrrrggggghhhhhh!!!!! Lol
