Post 509624 by pompeyphil on 2012-06-09 19:56:13
Hi all as title says best tyres to run on 18's on a t5r, lowered at least -40mm
225/35/18's would be best, anything 40 profile will rub on full lock.
[quote=Tomcat;509628]225/35/18's would be best, anything 40 profile will rub on full lock.[/quote] Thanks tomcat having dh make me some 6 pot brakes already got the 18s Are you making anymore splitters?
Im running 215/40/18 with probably a 40mm ish drop and yes they do rub on full lock but i just dont use full lock simples :)
use 215/35/18's if i were you, i run 215/35/19's and they dont rub
Or failing that you could just buy some C70 stop locks, it'll stop them rubbing but it will also reduce your turning circle.
[quote=Tomcat;509678]... but it will also reduce your turning circle.[/quote] to that of an even bigger barge!
True....but it's still an option and it would save the arch liners,lol.
I'll get them done in anthracite first, then sort tyres thanks
215's dont rub even with 19's so 18's will be fine
Ultrac Sessantas have a very stiff sidewall if you want it to feel direct too.
