headlight loom
Post 508889 by lillico on 2012-06-07 14:56:13
hi all, right im modifying the headlight loom to take ph2.5 headlights and was wondering if you can tell exactly the four plugs do on each side. obviously ones is indicators, another headlight lamps..just the other 2..
Post 508903 by LeeT5 on 2012-06-07 15:20:07
What's a phase 2.5?? What year is yer car? If it's from 1997 - 2000 then it will be phase 1, 2 or 3. 2001 > are P26 models.
Post 508905 by lillico on 2012-06-07 15:23:31
I may have madeva mistake.. Mines a2003 v70. I'm putting a complete facelift front on it. Hence 2.5.. Apologies if I'm mistaken
Post 508913 by LeeT5 on 2012-06-07 16:30:46
[quote=lillico;508905]I may have madeva mistake.. Mines a2003 v70. I'm putting a complete facelift front on it. Hence 2.5.. Apologies if I'm mistaken[/quote] No probs. Your car is a P26. The wiring should be the same for the facelift regards the lights.
Post 509098 by JamesT5 on 2012-06-08 00:13:58
[quote=LeeT5;508913]No probs. Your car is a P26. The wiring should be the same for the facelift regards the lights.[/quote] Yeah, I think they just put clear glass fronts on the headlight cluster didn't they? I did think about doing a facelift on my 2001 model but to be honest, it'll be the last thing I do as I'd rather get the mechanical side sorted out first. Regards James
Post 509208 by lillico on 2012-06-08 16:01:34
Unfortunately it doesn't appear that simple.. None of the multi plugs match... This weekend is going to be taken up by modifying the loom I think.. Im only doing it as needed some bits and its having a full respray so seemed like a good idea at the time
