Recirc Blank off plate
Post 508628 by deathrider311271 on 2012-06-06 21:18:14
i just put high temp silicone on mine and it seems fine
Simon
Post 508629 by claymore on 2012-06-06 21:18:17
the gasket needs to be made so that you have to bolt through it, if you understand me.
how thick is your plate, if it's not thick enough it will blow out.
Post 508638 by daza-b on 2012-06-06 21:24:23
i want one of these lol
Post 508660 by Brett855tdi on 2012-06-06 21:40:10
[quote=claymore;508629]the gasket needs to be made so that you have to bolt through it, if you understand me.
how thick is your plate, if it's not thick enough it will blow out.[/quote]
Yes i was thinking that the gasket should be full sized...... the plates not very thick, but was all i had.... it did bend the 3 corners as i tightened it up but looking around the top of it the rubber is compressed.
I dont have any goo to put on it, so im going to have to find some thicker plate and make a new gasket i think
Post 508662 by T5frankie on 2012-06-06 21:42:47
or just buy a proper one like mine lol
Post 508663 by daza-b on 2012-06-06 21:43:38
[quote=t5frankie;508662]or just buy a proper one like mine lol
[/quote]
how much n where from?
Post 508664 by T5frankie on 2012-06-06 21:44:34
[quote=daza-b;508663]how much n where from?[/quote]
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=160201&product=FMBPVRM
£26.78
Post 508666 by daza-b on 2012-06-06 21:46:00
[quote=t5frankie;508664]http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=160201&product=FMBPVRM
£26.78[/quote]
cheers mate be having one of them i think lol
Post 508668 by Brett855tdi on 2012-06-06 21:46:13
[quote=daza-b;508638]i want one of these lol[/quote]
Colin will probably cus me for this ... i can make you one if you like lol
Once ive found some good thick plate (wished a hadnt scrapped an old amp case i used for this sort of thing):bricks:
Post 508670 by Brett855tdi on 2012-06-06 21:47:24
[/quote]
Im not going to buy it if my amazing hands can make one as good :lol: waste of moneys
Post 508671 by daza-b on 2012-06-06 21:48:05
you know what funny bit is not sure where it goes fully, think i got a good idea but what u do with the recirc valve? also it says on the website: (Only recommended when installing an alternative valve.) that important n whats it mean?
Post 508673 by T5frankie on 2012-06-06 21:48:56
[quote=Brett855tdi;508670]Im not going to buy it if my amazing hands can make one as good :lol: waste of moneys[/quote]
not gonna be as good though is it lol on the opposite side is a rubber circular seal too lol
Post 508675 by T5frankie on 2012-06-06 21:50:16
[quote=daza-b;508671]you know what funny bit is not sure where it goes fully, think i got a good idea but what u do with the recirc valve? also it says on the website: (Only recommended when installing an alternative valve.) that important n whats it mean?[/quote]
you just swap it, it bolts directly onto the turbo 3 bolts, undo the three and the re-circ will pull out and just swap it for the blanking plate then fit a dump valve
Post 508681 by Brett855tdi on 2012-06-06 21:55:08
[quote=t5frankie;508673]not gonna be as good though is it lol on the opposite side is a rubber circular seal too lol[/quote]
Hmm im feeling under estimated here, this isnt exactly the hardest thing ive ever engineered
[quote=deathrider311271;508628]i just put high temp silicone on mine and it seems fine
Simon[/quote]
I take it this was a manufactured piece?
Post 508687 by daza-b on 2012-06-06 21:58:40
[quote=t5frankie;508675]you just swap it, it bolts directly onto the turbo 3 bolts, undo the three and the re-circ will pull out and just swap it for the blanking plate then fit a dump valve[/quote]
do you "have" to fit a dump valve? i hate the sound of them lol
Post 508692 by claymore on 2012-06-06 22:01:23
[quote=daza-b;508687]do you "have" to fit a dump valve? i hate the sound of them lol[/quote]
not if you don't want one ;)
Post 508693 by p fandango on 2012-06-06 22:01:58
[quote=daza-b;508671]you know what funny bit is not sure where it goes fully[/quote]
Post 508694 by daza-b on 2012-06-06 22:04:04
[quote=claymore;508692]not if you don't want one ;)[/quote]
wooohooo sorted! lol
Post 508696 by daza-b on 2012-06-06 22:04:38
[quote=p fandango;508693]
[/quote]
nice one bud thought it was there :)
Post 508699 by Brett855tdi on 2012-06-06 22:08:08
They say having turbo stall puts strain on the turbo, but ive known cars to be fine with them just blocked off for thousands of miles with no troubles, however the stall isnt such a great thing, i can feel the turbo having to spool up again.
I am looking at fitting a dump valve once the plates sorted.
You can get dump valves that dont make so much noise but keep you spooled up.
Post 508702 by T5frankie on 2012-06-06 22:09:17
A dump valve is there for a reason if you take the original out you should fit another Imo
Post 508703 by daza-b on 2012-06-06 22:09:34
[quote=Brett855tdi;508699]They say having turbo stall puts strain on the turbo, but ive known cars to be fine with them just blocked off for thousands of miles with no troubles, however the stall isnt such a great thing, i can feel the turbo having to spool up again.
You can get dump valves that dont make so much noise but keep you spooled up.[/quote]
its the wastegate chatter that i love lol cant be doing with sounding like a bus lol
Post 508705 by deathrider311271 on 2012-06-06 22:10:01
[quote=Brett855tdi;508681]
I take it this was a manufactured piece?[/quote]
a member on here made them up a couple of months ago now
Simon
Post 508710 by Brett855tdi on 2012-06-06 22:15:10
[quote=daza-b;508703]its the wastegate chatter that i love lol cant be doing with sounding like a bus lol[/quote]
Its the air blowing back out past the turbo that makes the noise in this instance, but yeah does sound sweet
[quote=t5frankie;508702]A dump valve is there for a reason if you take the original out you should fit another Imo[/quote]
I agree there frankie, the recirculation valve was there to stop the stall.... i can feel the car doesnt really like it, however im not going to bother fitting the valve until the plates right, its not really a big problem with the way i drive it.
Post 508712 by p fandango on 2012-06-06 22:15:45
[ame]http://www.youtube.com/watch?v=fmNucK8712M[/ame]
Post 508714 by daza-b on 2012-06-06 22:20:18
[quote=p fandango;508712]http://www.youtube.com/watch?v=fmNucK8712M[/quote]
gotta love it lol
Post 508723 by Brett855tdi on 2012-06-06 22:41:25
[ame="http://www.youtube.com/watch?v=HblCEQXQ8Q4"]http://www.youtube.com/watch?v=HblCEQXQ8Q4[/ame]
Post 508724 by daza-b on 2012-06-06 22:44:51
[quote=Brett855tdi;508723]http://www.youtube.com/watch?v=HblCEQXQ8Q4[/quote]
im lost??? lol
Post 508728 by Brett855tdi on 2012-06-06 22:58:02
[quote=daza-b;508724]im lost??? lol[/quote]
Thats the dump valve (blow of valve BOV) im looking at...
Post 508767 by t5steve on 2012-06-06 23:37:12
i just cut a 2mm plate and slid it under recirc valve...............works a treat........
Post 508800 by Brett855tdi on 2012-06-07 00:47:10
[quote=t5steve;508767]i just cut a 2mm plate and slid it under recirc valve...............works a treat........[/quote]
did you do this without removing the engine mount or leaning the turbo back?
it was so tight just getting the plate on... dred to think what it would b like putting the valve back on lol
Post 508815 by claymore on 2012-06-07 07:14:46
you shouldn't feel any difference in spool time on the 15g or 16t, you might feel it with an 18 or 19t.
Post 508818 by p fandango on 2012-06-07 07:21:25
[quote=claymore;508815]you shouldn't feel any difference in spool time on the 15g or 16t, you might feel it with an 18 or 19t.[/quote]
i fitted the plate on my 19t before i got the turbo fitted, but no problems with it spooling at all
Post 509053 by t5steve on 2012-06-07 22:18:26
[quote=Brett855tdi;508800]did you do this without removing the engine mount or leaning the turbo back?
it was so tight just getting the plate on... dred to think what it would b like putting the valve back on lol[/quote]
yes, nothing else removed only recirc valve..........use a 10mm ratchet spanner as access is a little tight................have a couple of spare bolts handy as its easy to drop them when refitting and as usual you can never find the one you drop
Post 509075 by Brett855tdi on 2012-06-07 23:08:04
[quote=t5steve;509053]yes, nothing else removed only recirc valve..........use a 10mm ratchet spanner as access is a little tight................have a couple of spare bolts handy as its easy to drop them when refitting and as usual you can never find the one you drop[/quote]
Tell me about it lost 2 twice! nightmare, ive got quite big hands and it was so fiddly. couldn't get any other bolts to catch a thread, so had to find the originals
Ive made a new one today with some 3mm better grade plate (bartered the local engineering shop for a big piece for 3 quid if anyone wants one)
and made a new gasket. its definitely going to be sorted now.
Driving it today with less boost was crap.
