RIP kit, whats required???
Post 507440 by kfc on 2012-06-04 19:54:00
Been looking at fitting a rip kit to the beastie, but am getting confused with to go about it. So could any of you point me in the right direction as in whats required and how you go about fitting said thingy. Cheers in advance guys.
Post 507442 by daza-b on 2012-06-04 19:55:08
p fandango has a decent diagram for this..
Post 507446 by p fandango on 2012-06-04 19:58:26
Turbo to Intercooler Image Image Intercooler to Throttle body Image Image
Post 508075 by leeboy on 2012-06-05 19:01:43
aslong as you not got an me7 engine.
Post 508115 by merc85 on 2012-06-05 19:48:35
All from the existing pipe work, except the black silicone straight across the engine. this was a mock up before i got some silicone hoses. Attachment
Post 508135 by AcidicDavey on 2012-06-05 20:23:55
[quote=p fandango;507446]Turbo to Intercooler Image Image Intercooler to Throttle body Image Image[/quote] Would it be possible to find a place for a dump valve in here?
Post 508138 by p fandango on 2012-06-05 20:25:59
[quote=AcidicDavey;508135]Would it be possible to find a place for a dump valve in here?[/quote] a dump valve can be T'd in, you want it as near to the throttle body as possible. I also forgot you need a 19mm port welding in by the throttle body to connect the pipe for the idle control valve
Post 508144 by merc85 on 2012-06-05 20:34:16
No need to weld a 19mm port with the home made R I P. Although the alloy ones look nice
Post 508160 by daza-b on 2012-06-05 20:59:15
can someone tell me the bore sizes thats needed for all the RIP kit please? cheers
Post 508168 by merc85 on 2012-06-05 21:12:09
[quote=daza-b;508160]can someone tell me the bore sizes thats needed for all the RIP kit please? cheers[/quote] i think the standard pipework is 2.25"
Post 508246 by oblark on 2012-06-05 23:13:22
I built mine out of 2.5inch steel tube and sprayed it silver. Image Image
Post 508371 by kfc on 2012-06-06 12:52:08
thamks for the help so far chaps, do you know what size the silcon hoses need to be at car attaching ends. Ta
Post 511826 by tattoo101 on 2012-06-13 22:40:47
has anyone got any info on a me7 rip kit? ive got a standard volvo one on my 850 can that be modded?
Post 516955 by kfc on 2012-06-25 21:13:04
Hi chaps, I,ve been taking bits to peaces to get sizes but cant the size os the spigot/outlet tube thingy on the bottom of the intercooler. Can any body help please? Ta Dean
Post 517012 by oblark on 2012-06-25 22:44:21
[quote=kfc;516955]Hi chaps, I,ve been taking bits to peaces to get sizes but cant the size os the spigot/outlet tube thingy on the bottom of the intercooler. Can any body help please? Ta Dean[/quote] My 850 intercooler lower outlet is 57 m/m, hope that helps.
