Post 504101 by Kevthescaff on 2012-05-28 08:08:38
Hi can anyone help me , I was out yesterday in my Volvo 940 estate, but when I came back to my car it had immobilised itself but iv never had a fob for the car, the RAC guy told me it could of been a radio frequency that activated the alarm. Can it be bypassed in any way, iv sent for a fob off the Internet but can this be paired the car while the alarm is activated. Would be grateful for any advice.
Post 504133 by barkster1971 on 2012-05-28 10:11:45
Check the connection that next to the +'ve terminal on the battery as the alarm needs a constant 12V feed. If there's a bit of corrosion on the contact it makes it behave weirdly. You can only get a new fob connected at a Volvo garage.
Post 504212 by smithy on 2012-05-28 16:27:31
[quote=barkster1971;504133]Check the connection that next to the +'ve terminal on the battery as the alarm needs a constant 12V feed. If there's a bit of corrosion on the contact it makes it behave weirdly. You can only get a new fob connected at a Volvo garage.[/quote]
You can use the 850 fobs they work Nd you don't need a Volvo garage to recode it for you I did mine no probs
Post 504223 by Steve 940 Estate on 2012-05-28 16:48:27
Hi
You can quite easily bypass the early Volvoguard alarms if the immobilise the car and leave you stranded.
Do you know which one you have ?
Post 504557 by Kevthescaff on 2012-05-29 10:20:08
I'll check which alarm it is steav when I get home. Just got a fob off eBay , I'll let you know how I get on thanks for all your help.
Post 504558 by Kevthescaff on 2012-05-29 10:25:17
[quote=smithy;504212]You can use the 850 fobs they work Nd you don't need a Volvo garage to recode it for you I did mine no probs[/quote]Can you explain how I Recode the alarm. Thanks smithy.
Post 504559 by Kevthescaff on 2012-05-29 10:27:26
Hi smithy can you explain how I go about recoding the alarm. Thanks smithy.
Post 504603 by Kevthescaff on 2012-05-29 16:39:35
[quote=Steve 940 Estate;504223]Hi
Do you know which one you have ?[/quote]
Hi Steve all I know that it's the Volvo guard it's an NReg can you help. It the one with the light on the drivers side post , hope this help . Any advice steve
Post 504619 by smithy on 2012-05-29 17:20:20
[quote=Kevthescaff;504559]Hi smithy can you explain how I go about recoding the alarm. Thanks smithy.[/quote]
if i can remember right you hold the button on the fob next to the car and the fob will pickup the signal off the car then when it has picked up the signal it will lock the doors and then let go of the button and press again to see if it opens the doors hey presto sorted.then start the car.
Post 504647 by Steve 940 Estate on 2012-05-29 18:21:09
It sounds like it's got a Volvoguard 1 if it has you can do like I did and unplug it all and then sort out the immobiliser.
Is the light you have in a triangular housing with buttons on it. If it is all the alarm gubbins are under the steering column.
I'm trying to help someone on the VOC forum with their later guard 2 alarm. I hate the things, any faults render the car nothing more than a pile of scrap metal.
