Standard sub?
Post 493903 by kfc on 2012-05-02 18:18:56
Hi guys im going to change the HU in the beastie, so popped it to have a quick look at whats what, and noticed that there is a lead coming from the standard HU SC-801 i think. is there a standard fitted sub in the car and if so where is it? or is is this a pre instaled lead if you had one fitted at time of buying? Ta
Post 494138 by LeeT5 on 2012-05-03 13:36:56
[quote=kfc;493903]Hi guys im going to change the HU in the beastie, so popped it to have a quick look at whats what, and noticed that there is a lead coming from the standard HU SC-801 i think. is there a standard fitted sub in the car and if so where is it? or is is this a pre instaled lead if you had one fitted at time of buying? Ta[/quote] Assuming you have a V70 classic then the answer is no, you don't have a sub. Sub woofers were not fitted until P2 cars in 2001> If you have a C70 then you may have the too large speakers in the rear seats, it may supply the amp to drive these.
Post 494248 by kfc on 2012-05-03 20:26:55
no its an S70R. thanks
Post 494257 by LiamT4 on 2012-05-03 21:02:36
Are you sure its not the sc-901, with the pro-logic center speaker?
Post 494268 by kfc on 2012-05-03 21:39:19
no mate, no center speaker.
Post 494272 by LiamT4 on 2012-05-03 21:46:09
Could it be a lead that would go to a cd changer in the boot?
Post 494289 by Cubes on 2012-05-03 22:35:40
I think the S/V70 classics were pre wired for a changer in the boot, so it might be that. Go too the point where the mountings are for a changer and look for the other end to the lead. It should be clearly visible. If it is, you know what it's for :)
Post 495186 by Wally Dog on 2012-05-06 20:32:51
I have fitted a 12" sub and amp into the back of my T5 estate and I have the same HU - the SC 801. While poking around, I found the 6 pin socket marked "amp" on the back, separate from the CD changer wire. Sextons in Portsmouth advised me that some Volvos have an in-built amplifier (not for a sub, just to power the speakers better), which is what this is for. Mine doesn't have this extra amp, so they made a cable up for me to plug into this slot, which gave me a left and right feed for the amp I have fitted for the sub. I took my own hugh power cable straight from the battery (fused, of course) and took the amp control from the cigarette lighter, through a switch next to the gear knob and through to the amp - so that I can have the stereo on with the sub off (if at work or Missus is in car!!) So to summise, you might have this extra amp for the speakers and not have a sub. I might be wrong, this is just what I was told when I was looking about. Hope it helps.
Post 495187 by Wally Dog on 2012-05-06 20:36:03
oh, in the 850, i believe that the amp is located behind the dash, somewhere near the heater gubbins, if fitted.
Post 495670 by kfc on 2012-05-07 20:22:57
Howdi, had another wee look andf the HU is a 901, i was awear of the changer lead but the port marked sub is next to the ariel port. i've changed my HU for someting a little more modern. but to honest the O/E one sounds better for some reson. just not as deep sounding, and yes i have played with the loudness, bass and all that. but wee'll see what happens with a little more playing.
Post 495845 by Wally Dog on 2012-05-08 00:04:01
I have to admit, the sound in my 850 is pretty good from the standard HU - comparable to if not better than the Alpine 9812 HU I used to have in my Golf. I spent HOURS tweaking the sound round the car (you can actually move it front to back and side to side) to get the best depth and clarity and was amazed how good it is. I only did it as a quick fix to start off with and now plan to leave it as is.
Post 503486 by Brett855tdi on 2012-05-26 15:47:53
[quote=kfc;495670]Howdi, had another wee look andf the HU is a 901, i was awear of the changer lead but the port marked sub is next to the ariel port. i've changed my HU for someting a little more modern. but to honest the O/E one sounds better for some reson. just not as deep sounding, and yes i have played with the loudness, bass and all that. but wee'll see what happens with a little more playing.[/quote] The 901 is what i have in my c70 and runs a standard 400w amp, plugs into AMP on the HU, the extra centre speaker when fitted goes into a small green socket in the back of the HU. once fitted its "pro-logic" The four 8" subs run off the amp, the other 6 tweeters, im not sure... The "SUB" socket is for an extra substitute ariel that was a factory extra Think is im not too sure how similar the S70r and C70 systems are, i would have thought that the R would run the extra amp from factory.
Post 503488 by Brett855tdi on 2012-05-26 15:52:06
[quote=LeeT5;494138] If you have a C70 then you may have the too large speakers in the rear seats, it may supply the amp to drive these.[/quote] Only the rag tops had the subs in the seats (and was an extra) , and the coupe GT s had subs in the shelf
