How many issues at once???
Post 488398 by iamawookiee on 2012-04-18 19:01:12
Hi looking for some help please! On my drive home in VERY wet conditions today the car lurched at one point and I got the orange warning triangle with the errors STC service required and reduced power (went into limp mode). Got home and the rad fans were on (strange I thought - as they don't usually kick in on this journey) but the temp looked normal. Left it for a bit once home and then started it again, errors went away but now have an engine service light on and the rad fans kicked in straight away. I only have a generic code reader, which shows "Mass or Volume Air Flow Circuit Low Input" Currently going to disconnect the battery to try and clear everything and see what happens, but any suggestions will be gratefully welcomed (I am going to get the codes read properly btw) Cheers.
Post 488405 by volvokid on 2012-04-18 19:04:33
Does that code not just say it all. A new MAF?? Im no mechanic but thats my guess
Post 488411 by iamawookiee on 2012-04-18 19:08:05
I know that seems obvious, but I've had the same error before on an S40 and it was nothing to do with the MAF, but I can't remember what it was. Before I restarted it and was reading up on the STC error I was thinking it was a fault with the ABS ECU (requiring the well documented service), but now the fault has jumped elsewhere, I'm confused to say the least!
Post 488422 by volvokid on 2012-04-18 19:16:06
Its a shame because I have a MAF you could try but im not at home at the moment. Get it looked at and if it is I could do a deal with my MAF they are 200 new, i changed mine because I fitted a AMS and that caused all sorts of grieve Volvo thought it was my MAF and changed it but it wasn't.
Post 488427 by iamawookiee on 2012-04-18 19:21:34
[quote=volvokid;488422]Its a shame because I have a MAF you could try but im not at home at the moment. Get it looked at and if it is I could do a deal with my MAF they are 200 new, i changed mine because I fitted a AMS and that caused all sorts of grieve Volvo thought it was my MAF and changed it but it wasn't.[/quote] Cheers Martyn, I'll let you know if I require it once I've had someone shaft me for reading the codes!
Post 488429 by volvokid on 2012-04-18 19:25:19
[quote=iamawookiee;488427]Cheers Martyn, I'll let you know if I require it once I've had someone shaft me for reading the codes![/quote] Post on here if anyone has a DICE and can help you out. People on here do try and help when they can, Im just so far away I cant be helped when I need it lol I need a guy from a toyota forum that my dad uses to help me lol
Post 488451 by iamawookiee on 2012-04-18 20:22:15
[quote=volvokid;488429]Post on here if anyone has a DICE and can help you out. People on here do try and help when they can, Im just so far away I cant be helped when I need it lol I need a guy from a toyota forum that my dad uses to help me lol[/quote] Is that one of the DICE / Honda / Toyota all in ones unit? I have been meaning to upgrade my generic thing for a while and those don't cost a great deal on eBay, but I was never sure if they were as good as the DICE only units?
Post 488521 by iamawookiee on 2012-04-18 21:49:40
Reconnected the battery 2 hours ago, took it out and gave it some beans, seemed ok, but still wasn't confident it was. Just been outside again to go for another spin and before I got a chance to go anywhere the engine light is back on and fan kicked in well before it's anywhere near normal running temperature - balls!!!
Post 488562 by deathrider311271 on 2012-04-18 22:35:25
i know on a P1 V70 ME7 engine when the MAF is knackered the fan kicks in and stays on after locking the car
Post 488592 by iamawookiee on 2012-04-18 23:02:18
Well it is doing that! I might see if I can get a maf from a scrappy as an intrim measure too test with, as it's quite a hefty outlay if I buy a new one and it's not that!
Post 488663 by LeeT5 on 2012-04-19 01:09:55
Might help if you start by telling us what car your having the problem with? Does your generic code reader have the ability to clear the codes? If so, clear them and drive the car again. Check codes after 50 or so miles and see what you get. A faulty MAF does not always throw a EML! You also should check 'live readings' to see what coolant temps your getting in relation to coolant temperature guage reading. If the CTS is faulty then the cooling fans will come on no matter what the temperature of the car.
Post 488664 by M-R-P on 2012-04-19 01:15:04
On ME7, I know the engine management can "panic" and put the fan on as a means of protection. Mine did it when it popped a coil pack and when it blew a charge-air gose off the engine. Also, a failing VVT position sensor can give weird readings on generic code readers.
Post 488679 by iamawookiee on 2012-04-19 08:17:24
[quote=LeeT5;488663]Might help if you start by telling us what car your having the problem with? Does your generic code reader have the ability to clear the codes? If so, clear them and drive the car again. Check codes after 50 or so miles and see what you get. A faulty MAF does not always throw a EML! You also should check 'live readings' to see what coolant temps your getting in relation to coolant temperature guage reading. If the CTS is faulty then the cooling fans will come on no matter what the temperature of the car.[/quote] Sorry, signature updated :P Issues are on my S60 T5 (2001). I have cleared the codes with the reader and it pops back after 60 seconds or so. The live temp readings from my code reader are the same as what the temp gauge shows on the car. I started the it this morning before leaving for work just to see if anything had changed and within about 20 seconds the fans kicked in.
Post 488715 by LeeT5 on 2012-04-19 09:57:31
[quote=iamawookiee;488679]Sorry, signature updated :P Issues are on my S60 T5 (2001). I have cleared the codes with the reader and it pops back after 60 seconds or so. The live temp readings from my code reader are the same as what the temp gauge shows on the car. I started the it this morning before leaving for work just to see if anything had changed and within about 20 seconds the fans kicked in.[/quote] When you start the cold from cold do the revs instantly raise to between 1200 - 1500rpm and stay there for about 30 seconds before settling to around 1000 rpm and then once the car is warmed up 750 - 800rpm. if not, its definately MAF.
Post 488718 by iamawookiee on 2012-04-19 10:12:49
[quote=LeeT5;488715]When you start the cold from cold do the revs instantly raise to between 1200 - 1500rpm and stay there for about 30 seconds before settling to around 1000 rpm and then once the car is warmed up 750 - 800rpm. if not, its definately MAF.[/quote] Can't remember from when I started it this mornign tbh, it just seemed to start normally and idle was fine, could have just dropped straight down to around 750rpm rather than doing the usual warm up thing???!! I'm back visiting me folks in Norfolk this weekend, so I may nip and pull a MAF from a scrappy to see if this works ok and then look at a new one if it does.
