Post 478110 by andybrown on 2012-03-26 23:18:02
Sorry, i must be doing everyone's head in now with the million questions!
I got a smashed front fog, and I'm having a right time getting it off (drivers side) anyone else noticed there is sod all room to get even the smallest spanner to the bolt?! or am i doing it wrong??!!!
short of introducing it to a lump hammer - i dont know what else to try!
Andy :)
Post 478120 by Wobbly Dave on 2012-03-27 01:16:38
the glass IIRC is only really accessible with the front bumper off.
To do that you have to under the 6 torx screws (t25) in the front half of each wheel arch (3 per side). Remove the headlamp wipers (8mm) - undo the plastic under guard (more torx screws). There are 2 large bolts either side holding it on. you need to undo this. With a friend you should then be able to remove the front bumper. access to repair the broken lens should be relatively simple.
