Clock & Gear number display
Post 476523 by WATCHMAN on 2012-03-22 00:44:06
The section on the display that shows the time and the gear number (geartronic) has gone dim. Just that part of the display. Any chance this is an easy repair? V70.
Post 476561 by WATCHMAN on 2012-03-22 10:41:30
Is it likely just a bulb replacement?
Post 476575 by Al115 on 2012-03-22 11:23:47
What year is the car?
Post 476590 by WATCHMAN on 2012-03-22 11:52:15
2000. Newer shape.
Post 476592 by WATCHMAN on 2012-03-22 11:53:27
I had a 480 ...
Post 478990 by LeeT5 on 2012-03-29 21:02:32
[quote=WATCHMAN;476561]Is it likely just a bulb replacement?[/quote] YES. :B_thumb:
Post 479078 by Porcine_Aviator on 2012-03-29 22:22:30
Ours is a 2000 and we are having problems with the display. Missing numbers and odd messages, like "Brake Failure Stop Safely ASAP, 9999 to an Empty Tank and so on.
Post 479097 by LeeT5 on 2012-03-29 23:19:11
[quote=Porcine_Aviator;479078]Ours is a 2000 and we are having problems with the display. Missing numbers and odd messages, like "Brake Failure Stop Safely ASAP, 9999 to an Empty Tank and so on.[/quote] Thats a different fault altogether! That will be the DIM failing, speak to Martinpeachey about that one. A dim display is normally the bulbs failed. Random messages that don't make sense is the DIM failing.
