V70r bumper paint remover??
Post 472196 by willi on 2012-03-09 17:01:16
Hi Guys.. I have a problem!! Took my front and rear v70r bumpers to be painted today and was told that whoever had painted them before didnt prep the surface so that is why the paint is coming off in sheets. To save loads of money they said either high pressure wash them or use high pressure air and watch the paint peel off. I did this with a jet washer and loads of paint has come off, but there are a lot of large areas where it wont budge. Does anyone know of any other method please?? eg:- can a stripper be used ?? or not.. Would very much appreciate any advice plz.
Post 472233 by T5frankie on 2012-03-09 17:59:01
heat gun if you are careful
Post 472332 by willi on 2012-03-09 19:54:24
[quote=t5frankie;472233]heat gun if you are careful[/quote] Yes i do have a heat gun.. Thanks, will give it ago tomoz..
Post 472333 by T5frankie on 2012-03-09 19:55:16
[quote=willi;472332]Yes i do have a heat gun.. Thanks, will give it ago tomoz..[/quote] not too close though mate, and try to use a plastic scraper not metal
Post 472391 by willi on 2012-03-09 21:28:47
[quote=t5frankie;472333]not too close though mate, and try to use a plastic scraper not metal[/quote] Ok ta i will do that.. Just out of curiosity is a chemical like nitro mors a no no then??
Post 472409 by T5frankie on 2012-03-09 22:01:40
[quote=willi;472391]Ok ta i will do that.. Just out of curiosity is a chemical like nitro mors a no no then??[/quote] never used it on a car mate
