Post 461870 by Haizum74 on 2012-02-11 22:40:19
Looks like me turbo is jiggered so been looking for recon and came across this ebay seller. Anyone used them before? Link
for that price i would send mine to turbo technics, used the quite a few times always good service
[quote=Haizum74;461870]Looks like me turbo is jiggered so been looking for recon and came across this ebay seller. Anyone used them before? Link[/quote] Was that it on it's way out the day we met up.
[quote=Haizum74;461870]Looks like me turbo is jiggered so been looking for recon and came across this ebay seller. Anyone used them before? Link[/quote] i would get the 14t hybrided and it will be rebuilt at the same time 14t/16t hybrid works well.
[quote=smithson007;461877]Was that it on it's way out the day we met up.[/quote] From sorting the orp and o ring etc yeh it looks like it. [quote=smithy;461925]i would get the 14t hybrided and it will be rebuilt at the same time 14t/16t hybrid works well.[/quote] For the same price and would I need to upgrade injectors or anything else?
If you just have the 14t hybrid then then you should be fine as long as you get bigger injectors, as a few have said, the normal injectors are almost maxed on the standard 14t at 230bhp. As long as the rest of your car is good, then you shouldn't need much else. Problems could happen if, for example, your standard intercooler, fuel pump, leads, boost hoses, etc (which are up to the job when brand new), are on the way out.
[quote=Haizum74;461928]From sorting the orp and o ring etc yeh it looks like it. For the same price and would I need to upgrade injectors or anything else?[/quote] going for a hybrid does not mean you have to run bigger injectors it all depends what boost you want to run.but i think that the standard injectors are 312 cc so you can normally go 30 percent bigger something like me7 blues would put you up to 350cc on a 3 bar fpr.im fitting the same hybrid to my mates t4 and he wants to run 1.4 bar so he might be using my vxr injectors witch are 470cc.but we will be able to confirm this when we put it on the rollers if we need injectors or not.i have 630cc injectors for my 940 so i will be selling the vxr 470cc injectors.
[quote=smithy;462010]going for a hybrid does not mean you have to run bigger injectors it all depends what boost you want to run.but i think that the standard injectors are 312 cc so you can normally go 30 percent bigger something like me7 blues would put you up to 350cc on a 3 bar fpr.im fitting the same hybrid to my mates t4 and he wants to run 1.4 bar so he might be using my vxr injectors witch are 470cc.but we will be able to confirm this when we put it on the rollers if we need injectors or not.i have 630cc injectors for my 940 so i will be selling the vxr 470cc injectors.[/quote] I wouldn't risk it though, as there are only 4 on a t4 they are going to be working a lot harder than a t5 would running similar power. Fair enough if your not going run much boost, but weres the fun in that! lol
[quote=LiamT4;462012]I wouldn't risk it though, as there are only 4 on a t4 they are going to be working a lot harder than a t5 would running similar power. Fair enough if your not going run much boost, but weres the fun in that! lol[/quote] its not all about high boost mate it the way the car drives and also the t5s run a different ecu system .im not saying dont put bigger injectors in im saying check the afrs before you do.because the hydrid im talking about is not a massive turbo ,it will just push abit more air at the same rpm .as said before depends on boost he will run.also slightly bigger injectors are very cheap like 50 pounds for me7 blues,witch i ran in my 940 at 19 psi on a t35 and the fueling was spot on.
[quote=smithy;462015]its not all about high boost mate it the way the car drives and also the t5s run a different ecu system .im not saying dont put bigger injectors in im saying check the afrs before you do.because the hydrid im talking about is not a massive turbo ,it will just push abit more air at the same rpm .as said before depends on boost he will run.[/quote] I know what you mean but i look at it like this - going down this route you would be running similar power to a vxr but you would be using much smaller injectors to fuel it. We'll know for sure, when you do your mates car as i'm just going on theory and what other people have said.
[quote=LiamT4;462021]I know what you mean but i look at it like this - going down this route you would be running similar power to a vxr but you would be using much smaller injectors to fuel it. We'll know for sure, when you do your mates car as i'm just going on theory and what other people have said.[/quote] as you say we will see what happend when we put the car on the rollers but i have the vxrs ready anyway and they are too much then get a set of me7 blues/or greens.
I have a t4 turbo body.It boosted really well on my t4,it has some play nothing heavy and it didnt smoke.
[quote=smithy;462026]as you say we will see what happend when we put the car on the rollers but i have the vxrs ready anyway and they are too much then get a set of me7 blues/or greens.[/quote] So, price wise what are we looking at? If its going to be easier going down the recon route for a 14t rather than a hybrid then I may just do that. While I see the benefits of upgrading if it then means more expense on the injectors plus upgrading all bits and pieces just for an additional 30hp then is it worth the extra moolah in the long run? Personally I am more interested in getting to 70,80,90 than all out top speed. Also I seen some 440cc bosch greens for £40 a pop
[quote=Haizum74;462052]So, price wise what are we looking at? If its going to be easier going down the recon route for a 14t rather than a hybrid then I may just do that. While I see the benefits of upgrading if it then means more expense on the injectors plus upgrading all bits and pieces just for an additional 30hp then is it worth the extra moolah in the long run? Personally I am more interested in getting to 70,80,90 than all out top speed. Also I seen some 440cc bosch greens for £40 a pop[/quote] arund 350 to 400 + vat mate i think you could proberly get a recon for around 300 though.
