Any engine bay cleaning tips,
Post 456724 by shepbomb on 2012-01-30 13:13:58
Hi all, now im off work for the next week on paternity leave, I thought I would make a start on detailing my engine bay, any hints/tips on how to do this as it looks like it has never been cleaned since coming out of the factory, It is a ME7 t5, if this opens up any possible problems....
Post 456729 by M-R-P on 2012-01-30 13:23:09
Mainly, don't go firing a pressure washer at it! If you can take bits off and clean them, do so - charge air and inlet pipes (all the big, black plastic ones) come off easily and look good for a good scrub, or even a coat of paint from a rattle can. While the pipes are off, you could remove the cover on top of the head and give it a scrub or again, a coat of paint (body colour goes well) the paint on the strut turrets is a pig to clean because of some coating that gets put on it in the factory. Rubber hoses come up nicely with engine oil or boot polish. Image I'll finish mine one day lol!
Post 456740 by I want a T5 on 2012-01-30 14:33:08
As Martin says, avoid dousing with the jet washer! I used a good degreaser which I sprayed where I needed it and then agitated with a suitable sized old paint brush. After leaving a while, I poured very hot water from an old kettle to rinse it down (not boiling but more than hand hot). This worked a treat. Soon after rinsing, I wiped with rags to dry and remove final residue so didnt leave water pooled anywhere. I think I am about 80% clean now and then just used a cheapo Halfords style vinyl dresser to make the plastics look better; something I will re do when the better weather is here. Just take your time and concentrate on a manageable area at a time rather than try to attack the whole bay in one go. I can see me takeing many hours to get the bay looking absolutely mint but its getting there!
Post 456754 by Porcine_Aviator on 2012-01-30 16:03:42
If you have a steam cleaner with a small brush on it you can heat up the greasy oily bits and wipe them off without leaving any water. But remember that if you do degreese an area where it's meant to have greese then you will need to replace it. But new greese always looks better than old.
Post 456839 by Peanut1 on 2012-01-30 18:25:06
Only thing i ever say is make sure you have a nice strong degreaser!! http://www.vpcuk.org/forums/showthread.php?t=39270 Thats what i did! Never had an issue using a jet washer, just be careful where you aim it!!! And, always have your engine running once you have degreased and scrubbed everything before you wash!!!
Post 457095 by MIKESC70T5 on 2012-01-30 22:23:06
[quote=I want a T5;456740]As Martin says, avoid dousing with the jet washer! I used a good degreaser which I sprayed where I needed it and then agitated with a suitable sized old paint brush. After leaving a while, I poured very hot water from an old kettle to rinse it down (not boiling but more than hand hot). This worked a treat. Soon after rinsing, I wiped with rags to dry and remove final residue so didnt leave water pooled anywhere. I think I am about 80% clean now and then just used a cheapo Halfords style vinyl dresser to make the plastics look better; something I will re do when the better weather is here. Just take your time and concentrate on a manageable area at a time rather than try to attack the whole bay in one go. I can see me takeing many hours to get the bay looking absolutely mint but its getting there![/quote] Seriously, you don't need to spend more than 20 minutes doing your engine bay. Spray Autoglym engine degreaser over everything, agitate with a brush if really dirty then using your hose pipe lightly spray over with water. While it's wet spray everything with Autoglym vinyl and rubber care and just shut the bonnet, job done. Come back an hour later, open your bonnet and be greeted with a lovely clean engine bay :smile: Image
Post 457102 by Wobbly Dave on 2012-01-30 22:30:29
Degreasers - I recommend Carlack Special Cleaner. Agitation is a great word. I use a variety of small & large brushes. to get into the nooks & crannies. Halfords have a little pack of 3 almost toothbrush-like detailing brushes, with nylon, brass & steel bristles, perfect for that kinda thing. And yes I do rinse the degreaser with a jet wash - but sparingly so. I use a drying towel to remove the water. Use Aerospace 303 protectant as a finishing touch on plastics (brings 'em up lovely). check out my bling... http://www.vpcuk.org/forums/dto_garage.php?do=viewvehicle&vehicle_id=1052
Post 457133 by Porcine_Aviator on 2012-01-30 23:07:33
Having seen Wobbly's engine bay and being dazzled by it, I can say his method seems to work really well.
Post 457134 by Wobbly Dave on 2012-01-30 23:08:51
I use AG metal polish for the shiny bits.
Post 457189 by volvokid on 2012-01-31 09:30:21
Daves way is the easiest dont believe in the no pressure washer myth i was shown how to clean the engine by polished bliss, if it works on super cars it will work on our old Volvo's. Get any good spray on degreaser but defo buy 303 i have used lots of products for the plastics but this runs rings round them
Post 457190 by volvokid on 2012-01-31 09:37:39
Read this http://www.polishedbliss.co.uk/acatalog/caring-for-modern-engines.html Everything they use is what i use
Post 457194 by M-R-P on 2012-01-31 10:01:45
[quote=Porcine_Aviator;457133]Having seen Wobbly's engine bay and being dazzled by it, I can say his method seems to work really well.[/quote] 'Tis true, Wobbly "the bonnet magpie" Dave does seem to have a certain skill when it comes to a clean bay... Image Although, it does tend to try and eat him from time to time...Image
Post 457475 by shepbomb on 2012-01-31 20:41:18
thanks, for all the tips everyone, Looks my weekend project, after this aerial gets sorted
Post 457504 by claymore on 2012-01-31 21:00:29
[quote=MIKESC70T5;457095]Seriously, you don't need to spend more than 20 minutes doing your engine bay. Spray Autoglym engine degreaser over everything, agitate with a brush if really dirty then using your hose pipe lightly spray over with water. While it's wet spray everything with Autoglym vinyl and rubber care and just shut the bonnet, job done. Come back an hour later, open your bonnet and be greeted with a lovely clean engine bay :smile: Image[/quote] Somehow, I don't see that method working on mine....lol Image
Post 457511 by M-R-P on 2012-01-31 21:02:56
Colin, I reckon, if you pour a packet of peanuts in that engine bay, not one of them will hit the ground!
Post 458380 by mas on 2012-02-02 19:11:31
I just love the fact that you're on paternity leave and still think to work on your Volvo .................... Respect that man :worship: Mas
Post 458614 by shepbomb on 2012-02-02 22:42:24
have no choice, its that ir public transport lol,
Post 462040 by shrekblackR on 2012-02-12 13:27:59
Image good de greaser take your time and maybe some chrome plasticoate for the manifold
Post 462274 by Wobbly Dave on 2012-02-12 20:42:11
Good shinyness
