service light query
Post 449023 by saffronman on 2012-01-14 10:59:56
Ive had a look via the search function but could find anything about this. My P1 70r's service light comes on when i start the car up? after ive driven for about 5-10 mins it goes off, it doesnt matter if i have been driving for two hours or fifteen mins it happens everytime. i tried the service light clear thing using the ingnition and mileometer thing on the clocks but that made no difference, its only been doing about 6 weeks, oh sometimes the tracs light is lit aswell. Are they controlled by the same ecu?. Can anybody give me any pointers
Post 449049 by t5 stealth on 2012-01-14 12:52:44
i cant remember properly but i think you hold down the trip button on the clocks, turn on ignition while holding button down,hold for 10 seconds and it flashes ,then release button within 4 seconds and turn off ignition and its reset. something like that,someone else will know and correct me,been a while since i had to do one of them lol
Post 449075 by PHIL V70R on 2012-01-14 15:52:52
[COLOR="Blue"]hi mate had this one on my R...end up takein 2 my mates garage and used there code reader that sorted it the time b4 went 2 the local steelers the did it for tener...but all the little tricks never work for me mate...[/COLOR]
Post 449101 by willi on 2012-01-14 17:42:21
Hahaha.. No the little tricks never work for me either..
Post 449125 by Brighty123 on 2012-01-14 18:48:50
Light comes on when the car is due a service based on time and mileage. Think the button/ignition trick only works on 850's, i have a 98 V70 T5 and have been told it won't work on that, you need a draper tool that is about £25 on ebay, model 69007 i believe, can then reset it yourself every year. Tracs light is a seperate issue Brighty
Post 449346 by t5 stealth on 2012-01-15 00:54:30
its worked for me on a couple of p1 v70s iv done. there is a tool to reset them too.
Post 449617 by saffronman on 2012-01-15 17:18:20
i thought the service light stayed on, when the car was due a service, so this is not the case then?
Post 450839 by tim15888 on 2012-01-17 19:39:23
[quote=t5 stealth;449049]i cant remember properly but i think you hold down the trip button on the clocks, turn on ignition while holding button down,hold for 10 seconds and it flashes ,then release button within 4 seconds and turn off ignition and its reset. something like that,someone else will know and correct me,been a while since i had to do one of them lol[/quote] I'm pretty sure this is right. This is what I used to do on my ME7 late P1 I had and always worked for me.
Post 453243 by kim on 2012-01-22 19:23:06
[quote=tim15888;450839]I'm pretty sure this is right. This is what I used to do on my ME7 late P1 I had and always worked for me.[/quote] Must be the electronic Me7s on then because I have found my 1998 2.5LPT P1 Will not reset as P2s, you need the draper tool model 69007 you can find it on the draper web site http://www.drapertools.com/b2c/b2cbrowse.pgm I bought mine last week followed the clear instruction's done in less than 30seconds http://www.justoffbase.co.uk/Draper-Expert-Volvo-Service-And-Airbag-Indicator-Reset-Tool-69007-Draper-OSR-VOLVO They also had it to me in a couple of days . Best of luck Kim
Post 453261 by AndysR on 2012-01-22 19:59:17
[quote=saffronman;449617]i thought the service light stayed on, when the car was due a service, so this is not the case then?[/quote] Service light will come on and stay on for around 2 minutes after every ignition cycle when the car has calculated that it is due for a service. It will need to be reset to clear it.
