Post 432586 by M-R-P on 2011-12-04 19:07:24
Hells bells, that iron x is a bit evil! What does it do to bare bodywork like a stone chip or deep scratch?
Post 432601 by Peanut1 on 2011-12-04 19:29:44
No damage at all, its PH neutral but stinks like rotten eggs big time!! Also used it on alloys and its amazing!! Forgot to do photos but basically the inners were black and sprayed it wound the inside and used my meguiars wheel brush and must have got about 80% of the muck off!!! Highly recommend the stuff!!!
Post 432604 by M-R-P on 2011-12-04 19:35:06
Cool, if mine wasn't so ruff I'd try harder lol. Those amelthea wheels look good when they get a good clean dont they ;)
Post 432608 by Peanut1 on 2011-12-04 19:37:27
Mine are knackered to be honest but it still improves them with a good clean! Well worth having and makes life so much easier when your claying too!!
Post 432627 by M-R-P on 2011-12-04 19:54:43
Eeerrgh, claying! I.work next to the ryvita factory - makes all the worlds ryvita, jordans cerial etc. I gotta clay my car every 2 weeks because of the crap that comes from their vents.
Post 432628 by AndysR on 2011-12-04 19:56:52
Another job well done, you have been busy this weekend! :)
Post 432644 by Peanut1 on 2011-12-04 20:16:02
Dead on the sofa now though and being forced to listen to x factor!!!
Post 432645 by daza-b on 2011-12-04 20:17:30
[quote=Peanut1;432644]Dead on the sofa now though and being forced to listen to x factor!!![/quote]
haha i know that one lol
Post 432693 by Wobbly Dave on 2011-12-04 21:01:28
I have used both the IronX & tardis with great success. Certainly cuts down on the claying effort required.
What mix do you use in your snowfoam - I put 4 parts snowfoam to 1 CG hyperwash
Post 432699 by p fandango on 2011-12-04 21:06:59
i was expecting something about games workshop v's Dr Who with that title lol. Cars came out well, but i'll still stick to the £3 Kos'o'wash round the corner ;)
Post 432815 by Peanut1 on 2011-12-05 12:30:36
[quote=Wobbly Dave;432693]I have used both the IronX & tardis with great success. Certainly cuts down on the claying effort required.
[/quote]
On a general wash i use about 1 part Britemax foam to 4 water in the bottle but if starting out on a car that needs full everything i will use 1 part snow, 1 APC and 3 water. Tend to find snow only good if you have already detailed the car before as it oulls the dirt off if you have decent wax on and reduces chances of swirling massively!
Post 432816 by volvokid on 2011-12-05 12:37:38
I do like iron x but to get good results from it is quite costly due to the amount you need, there is a newproduct out now cant remember the name of it but apparently its more of a gell so it works longer.
Post 432822 by Wobbly Dave on 2011-12-05 12:59:07
The reason I use the prewash on Betsy is precisely that I am trying to avoid any physical contact until at least some of the dirt has been loosened off - to effectively reduce the risk of long term swirling & the need for additional full details.
These days I tend to restrict myself to just the odd glaze & seal. The paint is pretty good.
Post 432823 by Wobbly Dave on 2011-12-05 12:59:48
[quote=volvokid;432816]I do like iron x but to get good results from it is quite costly due to the amount you need, there is a newproduct out now cant remember the name of it but apparently its more of a gell so it works longer.[/quote]
Agreed - I find the soap rather than the spray is just a good & you don't use as much.
Post 432831 by Peanut1 on 2011-12-05 13:35:20
Like you, i tend to prefer snow foam so reducing contact etc after ive done the car if that makes sense and would only use the iron x as part of a full decontamination before machine polishing which if the cars looked after, should only be about once a year or every two really. Plus also, if you deiced that you do have contaminants and no evidence of swirling it saves you claying and running the risk of scratching which in the long run would be more expensive!
Post 432833 by Flatout Phil on 2011-12-05 13:47:17
[quote=martinrpeachey;432627]Eeerrgh, claying! I.work next to the ryvita factory - makes all the worlds ryvita, jordans cerial etc. I gotta clay my car every 2 weeks because of the crap that comes from their vents.[/quote]
I'm really peckish right now...so hungry I could eat that wholefood car!
Post 432834 by Porcine_Aviator on 2011-12-05 13:48:28
I think I mentioned to you when we met that I used to work there and I know what you mean. Rye flour both cooked and uncooked seemed to get everywhere. Mind you it wasn't as bad as when Bluebird/Caravans International used to build there units next door, the whole area used to get covered in sawdust.
