An 850 GLT IN A SCRAP YARD WITH ONLY 43K!!!!!
Post 424678 by daza-b on 2011-11-12 14:13:48
Just been going through the yard and noticed this volvo in there, been in for ages just never really took much notice, though why not have a look, its an 850GLT with the 20v engine and with only 43k on the clock, the leather looks like its never been sat in, its an auto and is unfortunatly being broken by us, been sat for 3 years so wont be worth trying to get it on the road!! Image Image Image Image
Post 424680 by M-R-P on 2011-11-12 14:17:02
It's disgraceful, the way some pink cars het treated! ;)
Post 424683 by daza-b on 2011-11-12 14:18:46
[quote=martinrpeachey;424680]It's disgraceful, the way some pink cars het treated! ;)[/quote] haha i was just going through some of the cars we have and noticed it sat at the back, so pulled it out and could not believe what i was seeing!!
Post 424693 by AndysR on 2011-11-12 14:41:35
What's wrong with the car or was it just sat around for far too long?
Post 424706 by daza-b on 2011-11-12 14:46:53
[quote=AndysR;424693]What's wrong with the car or was it just sat around for far too long?[/quote] its been sat for around 3 years which is a shame or i would have had it for myself lol
Post 424710 by AndysR on 2011-11-12 14:48:17
[quote=dazab;424706]its been sat for around 3 years which is a shame or i would have had it for myself lol[/quote] Why would someone just leave it parked up for 3 years, in fact why would someone park it up in the first place with such low miles, was the owner seriously ill and unable to drive it or something?
Post 424719 by daza-b on 2011-11-12 14:51:15
[quote=AndysR;424710]Why would someone just leave it parked up for 3 years, in fact why would someone park it up in the first place with such low miles, was the owner seriously ill and unable to drive it or something?[/quote] yea from what i was told he was an old bloke and did not use it much at all, at least we know the engine is basically like new lol
Post 424723 by AndysR on 2011-11-12 14:53:17
[quote=dazab;424719]yea from what i was told he was an old bloke and did not use it much at all, at least we know the engine is basically like new lol[/quote] True but the fact it's stood around for that lenght of time not being run means it might only be good for scrap if it's started without being stripped and cleaned first...
Post 424728 by daza-b on 2011-11-12 15:00:50
veru true, ill see about maybe starting it on monday and see what happens lol
Post 424729 by AndysR on 2011-11-12 15:05:01
[quote=dazab;424728]veru true, ill see about maybe starting it on monday and see what happens lol[/quote] If you want to keep the engine I'd suggest you don't start until at the very least spraying some wd40 down the bores and winding the engine over on the starter motor without the plugs fitted for at least a min to get oil up to the head.. In an ideal world, if you wanted to do the best for the engine, you'd remove the head remove the pistons, free the piston rings, apply a smearing of engine oil to the sides of the pistons and cylinder walls, refit the pistons, refit the head with new gaskets appling oil to the camshaft bearings and lobes
Post 424733 by daza-b on 2011-11-12 15:12:33
[quote=AndysR;424729]If you want to keep the engine I'd suggest you don't start until at the very least spraying some wd40 down the bores and winding the engine over on the starter motor without the plugs fitted for at least a min to get oil up to the head.. In an ideal world, if you wanted to do the best for the engine, you'd remove the head remove the pistons, free the piston rings, apply a smearing of engine oil to the sides of the pistons and cylinder walls, refit the pistons, refit the head with new gaskets appling oil to the camshaft bearings and lobes[/quote] haha ill let someone else do that, got enough of a job doing that on the 2.4t engine thats going into my v70 and then doing a complete rebuild on a t5 engine soon too lol
Post 424734 by AndysR on 2011-11-12 15:13:51
Is it a 2.0 or 2.5?
Post 424735 by p fandango on 2011-11-12 15:15:28
if your breaking it i'm interested in the cams ;)
Post 424736 by daza-b on 2011-11-12 15:25:35
[quote=AndysR;424734]Is it a 2.0 or 2.5?[/quote] not sure can find out on monday, i think its the 2.5 if memory serves
