straight outlet from turbine?
Post 419315 by heyes on 2011-10-27 18:09:45
What is the difference between " straight outlet from turbine" and " conic outlet from turbine"
Post 419316 by p fandango on 2011-10-27 18:11:57
[quote=heyes;419315]What is the difference between " straight outlet from turbine" and " conic outlet from turbine"[/quote] the conical outlet uses a loose flange on the downpipe to compress it into the turbo making the seal. The normal straight outlet is fixed onto the downpipe. Conical is found on the very early T-5's, they then changed to the straight outlet which changed to the larger angled outlet when they went ME7
Post 419318 by heyes on 2011-10-27 18:16:34
[quote=p fandango;419316]the conical outlet uses a loose flange on the downpipe to compress it into the turbo making the seal. The normal straight outlet is fixed onto the downpipe. Conical is found on the very early T-5's, they then changed to the straight outlet which changed to the larger angled outlet when they went ME7[/quote] Which is better and can you change if necessary .
Post 419319 by p fandango on 2011-10-27 18:20:15
[quote=heyes;419318]Which is better and can you change if necessary .[/quote] you can change the exhaust housing on the turbo by splitting it, the best is the angled outlet. Straight is 2.5" & angled is 3" diameter
