Auto box
Post 413493 by V70 smith on 2011-09-30 18:54:49
Hey all I'm new to here only jst got my 2000 plate v70 estate off my dad but iv got a lil problem with the auto box on cold start if u fnt let it negotiate gear long enuf it clunks into drive cud anyone shed sbit of light on this plz ta Marcus
Post 413494 by dalhousie2008 on 2011-09-30 19:01:48
Maybe check your geabox oil, see If it's black, if so maybe big probs on the horizon
Post 413497 by Porcine_Aviator on 2011-09-30 19:23:27
Change the gearbox oil, and if you do it yourself check the colour of the fluid and also the amount. Volvo say the box is sealed for life, that's a load of bull, they need a change of fluid. If the amount of fluid that comes out is more than 4 litres then you could have a leak into the box from the cooling system. The forum also has this about the Geartronic Box http://www.vpcuk.org/forums/showthread.php?t=15954
Post 414183 by V70 smith on 2011-10-03 22:25:22
Ok then thanks slot iv had a chat with a local mechanic he said iv also gota ave the gb ecu reprogrammed is this treu or jst bull aswell thanks again marcus
Post 414698 by V70 smith on 2011-10-05 20:29:41
Bump
Post 416226 by V70 smith on 2011-10-13 08:49:13
Can anyone let me kno if iv got to put volvos own gearbox oil in my auto box or can I get it else where dnt really want to pay £80 a litre from them robbing ****s thanks Marcus
Post 416228 by Al115 on 2011-10-13 09:16:19
There is an alternative (non-Volvo) oil you can use, try searching on the Forum, it's been discussed a few times.
Post 416230 by Redbrick on 2011-10-13 09:21:19
I don't have an auto box in mine however I've read you must only use the Volvo fluid as the box is programmed to slip in a different way to the same box in other makes. Put another way you could go out and buy Toyota fluid as its the same box but that doesn't mean the Volvo box behaves in the same way as the Toyota box. The gear box will need adapting to the new fluid and there is a strict procedure on how to do this on VIDA - it will need to be plugged into a computer. You'll need 12 litres and change it by dilution. Have a search round on the various Volvo forums and you will find posts on how its done. As I said all second hand information, be careful of people preaching that they are correct as it's your box and your #### up if you end up causing more damage!! Try 'Rufe' on here or MRG for mail order Volvo parts.
Post 416232 by M-R-P on 2011-10-13 09:25:10
Dextron III ATF should do it, drain, fill, run for a few miles then drain, fill. run for a few miles, drain and fill and see how you get on. Like Mr. PA said, check the quantity of fluid that comes out of the box, as the coolant rad and tranny rad are integrated and if one leaks into the other, you've got BIG problems - Porcine Aviator knows this problem well, 3 gearboxes in 4 years wasn't it Chris?
Post 416862 by V70 smith on 2011-10-15 21:15:31
Ok then thank you everyone who has shed abit of light into my small problem lol o and wot about alarm after fiting a audio system keeps going off now even tho it's been fited by a shop thanks again a big help
