98 c70 t5 manual dump valve question
Post 391737 by big shrek on 2011-07-03 16:44:57
i want a nice loud dump valve for my t5 gt c70,which one should i go for? its got a bailey one fitted at the min but for some reason its not working,there is a thin rubber tube coming out the top of the dump valve about 4-5 inches long with a screw stuffed in the end.....dont know why or if its meant to be like that
Post 391744 by deathrider311271 on 2011-07-03 17:10:09
the screw is why its not working, its not connected to anything
Post 391754 by big shrek on 2011-07-03 17:43:29
[quote=deathrider311271;391744]the screw is why its not working, its not connected to anything[/quote]
i took the screw out and it still didnt work it looks like that thin rubber pipe has been cut like i say its only 4-5 inches long coming out the top of the dump valve,why would someone stuff a screw into the end of that pipe? sorry for dumbass questions but i dont know about dump valves
Post 391757 by dps1973 on 2011-07-03 17:50:22
It need's to be connected to the vac tree
Post 391758 by big shrek on 2011-07-03 17:52:31
[quote=dps1973;391757]It need's to be connected to the vac tree[/quote]
the what? it doesnt look like its long enough to connect to owt mate,where is this vac tree thing?
Post 391760 by dps1973 on 2011-07-03 17:56:41
It needs to be extended then, it is near the throttle body. There will be 3/4 pipes connected to it and 2 blanked off
Post 391761 by big shrek on 2011-07-03 17:59:40
[quote=dps1973;391760]It needs to be extended then, it is near the throttle body. There will be 3/4 pipes connected to it and 2 blanked off[/quote]
sounds like its been bodged up then dont it,dont know what im gonna do know then......ggrrrrrrr just want that bbbrrrraaaaapppppp.....ttttsssssshhhhh sound
Post 391764 by deathrider311271 on 2011-07-03 18:12:37
u also need to make sure the recirculation dump valve has been replaced with a blanking plate
Post 391766 by big shrek on 2011-07-03 18:15:49
[quote=deathrider311271;391764]u also need to make sure the recirculation dump valve has been replaced with a blanking plate[/quote]
ok how do i do that? looks like im gonna have to buy a brand new dump valve and fitting kit and start again
Post 391770 by Jamest5r on 2011-07-03 18:21:57
The vac tree is under the throttle cable cover that is a curved bit of plastic about 6" long, take that off and you will see a small plastic pipe sitting verticaly with little tubes sticking out the side's, if it will reach plug the pipe from the dv to one of these.
Post 391773 by big shrek on 2011-07-03 18:24:32
[quote=jamest5r;391770]The vac tree is under the throttle cable cover that is a curved bit of plastic about 6" long, take that off and you will see a small plastic pipe sitting verticaly with little tubes sticking out the side's, if it will reach plug the pipe from the dv to one of these.[/quote]
where in the bay is this mate? just had a scout round ebay and i can buy the rubber pipe in meter lengths just need to know if its 4,5 or 6 mm
Post 391776 by T5frankie on 2011-07-03 18:27:58
its under the plastic cover toward the front of the engine on the right side it has one torx screw to undo its where the throttle cable is
Post 391779 by Jamest5r on 2011-07-03 18:30:44
If you look at your engine it's at the right hand side at the end where the pipe enters from your intercooler.
Need some clever person to post a pic :) Where's bloody Fandango when you need him lol
Post 391782 by big shrek on 2011-07-03 18:31:28
[quote=t5frankie;391776]its under the plastic cover toward the front of the engine on the right side it has one torx screw to undo its where the throttle cable is[/quote]
ok will have a butchers 2moro see whats what,how do i tell if the Recirculation valve has been blocked off?
will i experience problems when dump valve is fitted and working properly?
Post 391784 by T5frankie on 2011-07-03 18:32:39
[quote=jamest5r;391779]If you look at your engine it's at the right hand side at the end where the pipe enters from your intercooler.
Need some clever person to post a pic :) Where's bloody Fandango when you need him lol[/quote]
is your car done yet james?
Post 391788 by Jamest5r on 2011-07-03 18:43:32
[quote=t5frankie;391784]is your car done yet james?[/quote]
It was :) RMS failed (brand new volvo part) so block came out again stripped down and lots of oil was found in the bores so rings no good, 0.4 oversized pistons arriving from volvo on tuesday and will be rebuilt again and put back in next weekend :)
Sorry for the hijack Shrek
Post 391790 by T5frankie on 2011-07-03 18:48:23
[quote=jamest5r;391788]It was :) RMS failed (brand new volvo part) so block came out again stripped down and lots of oil was found in the bores so rings no good, 0.4 oversized pistons arriving from volvo on tuesday and will be rebuilt again and put back in next weekend :)
Sorry for the hijack Shrek[/quote]
hope so mate want to get mine done missing the noise lol
Post 391801 by claymore on 2011-07-03 19:22:31
Does this help?
Post 391802 by claymore on 2011-07-03 19:28:13
This might be better
Post 391806 by big shrek on 2011-07-03 19:53:47
[quote=claymore;391801]Does this help?
[/quote]
cheers but why have you drawn a red line to show where the pipe connects to but your blue pipe doesnt go there?
that vac tree has 5 nipples off it 3 on the front and 2 on the back (one of which has a thin pipe coming off it) which one do i connect my dump valve pipe to and do i have to remove the pipe thats connected to the vac tree at the min?
also how do i tell if the recirclulating valve has been blanked off?
Post 391809 by claymore on 2011-07-03 20:00:44
[quote=big shrek;391806]cheers but why have you drawn a red line to show where the pipe connects to but your blue pipe doesnt go there?
also how do i tell if the recirclulating valve has been blanked off?[/quote]
If you look closly at that picture the blue pipe gose to the manifold (which is also fine) but I didn't want to confuse you.
as for the recirc valve, I'll se if I can find some pics for you now.
Post 391813 by claymore on 2011-07-03 20:06:41
OK, if your turbo has this, then the dump valve wont work, this bit should be replaced with a flat plate.
Post 391828 by big shrek on 2011-07-03 21:03:05
ok will have a look 2moro,the turbo is at the back of the block is it not?
if it fit a pipe to that vac tree does it matter which nipple i use and does the one thats currently used need to be disconnected?
Post 391979 by big shrek on 2011-07-04 17:47:40
aybody?
if i fit the rubber pipe from the top of the dump valve to the vac tree do i need to disconnect the rubber pipe thats currently on it? does it matter which one of the 5 nipples i use?
Post 391981 by claymore on 2011-07-04 17:52:41
are you talking about the pipe on the dump valve? if so just pull it off and replace it with a longer pipe.
Post 392010 by big shrek on 2011-07-04 20:36:14
[quote=claymore;391981]are you talking about the pipe on the dump valve? if so just pull it off and replace it with a longer pipe.[/quote]
yes but i dont know what size pipe to order 4,5,6 mm
what i want to know is when i have fitted the new longer pipe to the dump valve and i go to fit it to the vac tree do i need to remove the rubber pipe thats already connected to the vac tree and does it matter which of the 5 connections on the vac tree do i connect my dump valve up 2?
Post 392020 by Jamest5r on 2011-07-04 20:44:58
Just plug it into anyone of the outlet's just make sure the rest are covered with the little rubber caps and leave what ever is pluged in there :)
Post 392023 by big shrek on 2011-07-04 20:47:41
[quote=jamest5r;392020]Just plug it into anyone of the outlet's just make sure the rest are covered with the little rubber caps and leave what ever is pluged in there :)[/quote]
right will do,just need to see if my turbo has the blanking plate fitted from the original valve
Post 392029 by Jamest5r on 2011-07-04 20:56:19
[quote=big shrek;392023]right will do,just need to see if my turbo has the blanking plate fitted from the original valve[/quote]
Pretty easy to tell if there is a pipe on the end its got the recirc if not just blank :)
Post 392030 by big shrek on 2011-07-04 20:57:17
[quote=jamest5r;392029]Pretty easy to tell if there is a pipe on the end its got the recirc if not just blank :)[/quote]
yeah i know what im looking for just cant see from above the engine
Post 392051 by Jamest5r on 2011-07-04 21:14:44
[quote=big shrek;392030]yeah i know what im looking for just cant see from above the engine[/quote]
You should be able to mate it's fairly clear, if you are standing by your nsf wheel looking at the turbo it's the closest part of the turbo to you.
Post 392052 by big shrek on 2011-07-04 21:17:28
[quote=jamest5r;392051]You should be able to mate it's fairly clear, if you are standing by your nsf wheel looking at the turbo it's the closest part of the turbo to you.[/quote]
well i cant see for looking,its up on a ramp wednesday having the oil changed so will look underneath then
Post 392053 by LiamT4 on 2011-07-04 21:18:20
Would the heat shield be in the way though? As this covers a lot of the turbo when its on.
Post 392055 by big shrek on 2011-07-04 21:21:30
[quote=LiamT4;392053]Would the heat shield be in the way though? As this covers a lot of the turbo when its on.[/quote]
yes.......yes it is....gggrrrrrr
Post 392058 by big shrek on 2011-07-04 21:24:04
i hope it is blanked off cos i aint got a clue where to get a blanking plate from
Post 392059 by LiamT4 on 2011-07-04 21:24:43
[quote=big shrek;392055]yes.......yes it is....gggrrrrrr[/quote]
If you take it off, most don't bother putting it back on, as it makes things easier when checking things like the turbo actuator.
Post 392061 by T5frankie on 2011-07-04 21:29:13
you can see the dump valve with the heat shield on
Post 392066 by LiamT4 on 2011-07-04 21:33:28
[quote=t5frankie;392061]you can see the dump valve with the heat shield on[/quote]
he's talking about the turbo, on that post.
Post 392076 by claymore on 2011-07-04 21:41:26
Post 392080 by big shrek on 2011-07-04 21:44:55
[quote=claymore;392076]
[/quote]
is that taken from the passenger side? is that the actuator next to it?
Post 392081 by T5frankie on 2011-07-04 21:45:47
[quote=big shrek;392080]is that taken from the passenger side? is that the actuator next to it?[/quote]
yes
Post 392089 by big shrek on 2011-07-04 21:54:26
right just looked and no mine is not blanked off.........bastard
do i have to use a blanking plate specific to a c70 t5 or can i use one for any td04 turbo?
Post 392092 by T5frankie on 2011-07-04 21:56:43
[quote=big shrek;392089]right just looked and no mine is not blanked off.........bastard
do i have to use a blanking plate specific to a c70 t5 or can i use one for any td04 turbo?[/quote]
a t5 engine is a t5 engine mate they are all the same
Post 392093 by claymore on 2011-07-04 21:58:26
Does it still have the vac pipe going to it, if so, you could just put a one way valve in the line.
Post 392095 by big shrek on 2011-07-04 22:03:48
[quote=claymore;392093]Does it still have the vac pipe going to it, if so, you could just put a one way valve in the line.[/quote]
yes still got a pipe attached to it
a what?
Post 392098 by big shrek on 2011-07-04 22:08:54
will this fit even tho its for a 850 t5? cant find owt for the c70
http://forgemotorsport.co.uk/content.asp?inc=product&cat=250301&product=FMBPVRM
Post 392159 by claymore on 2011-07-05 07:36:38
[quote=big shrek;392098]will this fit even tho its for a 850 t5? cant find owt for the c70
http://forgemotorsport.co.uk/content.asp?inc=product&cat=250301&product=FMBPVRM[/quote]
Yes that't fine, you need to forget your car is a c70, your engine is a t5, all pre me7 (me7 has no throttle cable) t5 engines are the same.
Post 392362 by big shrek on 2011-07-05 19:12:38
[quote=claymore;392159]Yes that't fine, you need to forget your car is a c70, your engine is a t5, all pre me7 (me7 has no throttle cable) t5 engines are the same.[/quote]
ok will do :)
how hard is it to fit that blanking plate? 5 min job or complete ball ache
Post 392374 by T5frankie on 2011-07-05 19:25:48
[quote=big shrek;392362]ok will do :)
how hard is it to fit that blanking plate? 5 min job or complete ball ache[/quote]
easy job if you have a ratchet spanner otherwise its a pain in the arse
Post 392375 by claymore on 2011-07-05 19:26:06
Not to bad, but make sure you've got a 10mm ratchet spanner.
EDIT: That bloodey Frankie beat me to it again
Post 392384 by T5frankie on 2011-07-05 19:28:58
read post 50 mate lol
Post 392420 by big shrek on 2011-07-05 20:05:08
[quote=t5frankie;392374]easy job if you have a ratchet spanner otherwise its a pain in the arse[/quote]
can it be fitted while its still on the car or does the turbo need to come off?
Post 392422 by T5frankie on 2011-07-05 20:06:53
[quote=big shrek;392420]can it be fitted while its still on the car or does the turbo need to come off?[/quote]
it just need 3 10mm bolts undoing whilst still on the car best to take the turbo hose off first
Post 392423 by Jamest5r on 2011-07-05 20:07:25
15 min job mate as long as already been said with a 10mm ratchet :) but you will lose skin from your knuckes :)
Edit... bloody Frankie is quick lol :)
Post 392424 by dps1973 on 2011-07-05 20:07:32
Stay on the car just use a ratchet spanner makes l;ife soooo much easier
Post 392439 by big shrek on 2011-07-05 20:16:41
right last question
when i remove the standard valve what do i do with the end of the pipe that i pull off it?
does it go to the vac tree?
can i use it to connect to my bailey dump valve if it is connected to the vac tree?
Post 392441 by claymore on 2011-07-05 20:20:10
normaly, you would pull the pipe off the vac tree, but in your case i would take it off the recirc valve and put it on the dump valve, (that would save you having to get a new pipe for the dump valve.)
