Ho Ho Ho
Post 3657 by Bracer on 2004-12-08 10:24:53
My Mechanic Is Going To Have A Happy X-Mass Once He's Finished With Me :eek: Just booked SAM in for a few bits and bobs :cry: 1 Cambelt 2 Aux Belt 3 Hydraulic tensioner 4 Idler pulley 5 Water pump 6 Camshaft oil seals 7 Crankshaft oil seal 8 Turbo return oil seal 9 Dip stick oil seals 10 Crankcase breather system 11 Oil filter 12 Oil 13 Drive shaft oil seals 14 Gear box oil Errrrrr think that every thing :eek: :help:
Post 3670 by Bracer on 2004-12-08 16:37:13
Well I just got the prices back for just the parts from Volvo. 1 Cambelt (pn 272327) £39 2 Aux Belt (No air con) (pn 9146973) £15.40 3 Hydraulic tensioner (pn 9146693) £61 4 Idler pulley (pn 8630590) £37 5 Water pump (pn 30684432) £64 6 Camshaft oil seals (front) X2 (pn 6842273) £6.30 each 7 Crankshaft oil seal (front) (pn 9458178) £11.40 8 Turbo return oil seal (pn 30637866) £0.75 9 Turbo return gromet (pn 3514546) £1.10 10 Dip stick oil seals (both top and bottom) (pn 30637865 & 947114) £0.95 & £1.25 11 Crankcase breather system (Oil separator and piping) (pn 1271988 & 1271653) £15.80 & £3.35 12 Engine Oil filter (pn 3517857) £6.20 13 Sump gasket (pn977751) £0.85 14 Inlet manifold gasket (pn 9146266) £6.60 15 Drive shaft oil seals X2 (pn 684348) £6.60 each 16 Oil cooler bottom hose clip (pn 983730) £1.80 17 Lock nuts X2 (pn 971100) £1.40 each 18 Lock nuts X4 (pn 971098) £1.05 each 19 Drive shaft lock nuts X2 (pn 9157371) £4.40 each So that comes to a grand total of £308.05 exc the VAT :eek: So looks like I'll be doing it myself then :cry: :crazy:
Post 3671 by Mrsmopp on 2004-12-08 16:44:06
Better get your hands dirty then boyo! x
Post 3672 by lance on 2004-12-08 16:58:55
That will keep yer busy
Post 3684 by C70T5 on 2004-12-08 17:39:17
[QUOTE=lance]That will keep yer busy[/QUOTE] You mean out of trouble ;)
Post 3687 by Markzx on 2004-12-08 18:07:47
It could be worse. :shifty: Good luck
Post 3802 by Bracer on 2004-12-13 10:03:05
Just wanted to give you the latest update. On Friday I got a quote back from a local garrage to the sum of.............. [COLOR=Red][SIZE=7]£1000 min[/SIZE][/COLOR] :eek:
Post 3803 by lance on 2004-12-13 10:08:58
[QUOTE=Bracer]Just wanted to give you the latest update. On Friday I got a quote back from a local garrage to the sum of.............. [U][COLOR=Red][SIZE=7]£1000 min[/SIZE][/COLOR][/ :eek:[/QUOTE] Ouch I take it you will DIY it then
Post 3804 by Bracer on 2004-12-13 10:11:44
Yeah If all goes well and I get the parts and time off Friday is `D' day :hidesbehi Might have to polish and port the intake while its off thou :eek: :shifty: :wink:
Post 3856 by Bracer on 2004-12-15 11:15:16
Right dropped SAM off at a local garage I've used for years on general maintance and my other halfs cars and Mots and stuff. And he's come back with a Price for doing the following; 1 Cambelt (pn 272327) £39 exc vat from Volvo 2 Aux Belt (No air con) (pn 9146973) £15.40 exc vat from Volvo 3 Hydraulic tensioner (pn 9146693) £61 exc vat from Volvo 4 Idler pulley (pn 8630590) £37 exc vat from Volvo 5 Water pump (pn 30684432) £64 exc vat from Volvo 6 Camshaft oil seals (front) X2 (pn 6842273) £6.30 each exc vat from Volvo 7 Crankshaft oil seal (front) (pn 9458178) £11.40 exc vat from Volvo All fitted for [SIZE=7][COLOR=Red]£235[/COLOR][/SIZE] :thewave: Theres some good will left in the world still I see :wink: I'll be fitting the remainder of the list myself :dgrin:
Post 3870 by Tomcat on 2004-12-15 22:05:27
Think I'd still do it myself, but then again I'm a tight git! :dgrin:
Post 3873 by Bracer on 2004-12-16 08:47:02
[QUOTE=tomcat]Think I'd still do it myself, [COLOR=Red]but then again I'm a tight git![/COLOR] :dgrin:[/QUOTE] Dont make sence buddy :crazy: The parts alone would cost me £284.47 inc the vat so getting the whole job done for £235 parts and labor included is saving me money :rolleyes:
