Post 34037 by audimadmike on 2005-07-26 19:15:29
I'd like more power on my 850 T5, does anyone know the easiest and cheapest mod available?
I've previously had TDi cars and a simple box connects in the system for around £400.
I'm looking for 20% + BHP otherwise not really worth bothering with.
Post 34043 by p fandango on 2005-07-26 19:33:01
MBC (manual boost controller) is by far the cheapest way to get a noticable chunk of power out of pre-ME7 T-5's, believe they are about £40 now & let you adjust the boost to what you want (have to be sensible tho as your not upping fuel to match)
not sure what percentage increase you get but it certainly turns them into a right beast :sinner:
Post 34047 by audimadmike on 2005-07-26 20:04:36
Sounds quite good...where do you get them from and are they straightforward to fit?
thanks
Post 34052 by p fandango on 2005-07-26 20:17:54
i got mine from DBS motorsport (01522 856045/07961 973382)
basically its an adjustable pressure release valve that you put in-line to the actuator replacing the BCS (boost control solenoid) taking control of the boost off the ecu (including limp home mode tho) so the turbo boosts to whatever you've set the valve at
Post 34061 by Goof on 2005-07-26 20:59:50
[QUOTE=audimadmike]I'd like more power on my 850 T5, does anyone know the easiest and cheapest mod available?
I'm looking for 20% + BHP otherwise not really worth bothering with.[/QUOTE]
Try Volvo Tuning - http://www.volvotuninguk.com/Disclaimer_-_This_web_site_is_not_affiliated_with_Volvo_Car_Corporation/index.htm - well respected and very popular amongst us lot!
Post 34124 by Wobbly Dave on 2005-07-26 23:46:19
VT a summer special on in August - which gives you extra tuning bits for free on top. Check out the Member Discounts board for details
Post 34148 by audimadmike on 2005-07-27 08:15:24
Thanks for the above..very useful information, will start checking it all out.
Mike
