Sc805 - "off"
Post 363234 by jdavis on 2011-02-27 14:49:52
Guys, put the code in wrong 3 times on my SC805. now instead of displaying "code" it just says "off" and wont let me put in right code. Help
Post 363236 by Dan850r on 2011-02-27 14:59:28
think you have to leave it turned on with the ignition in pos 2 for 10 mins, then it should reset. It says in the handbook if you have it
Post 363260 by Vikingxl on 2011-02-27 17:12:33
You need to leave it alone for a while but i cant remember how long im sure someone will be along soon with the right info
Post 363268 by jdavis on 2011-02-27 17:52:33
done a bit of research. 2 hours with ignition on to clear it back to "code". great. is it possible to drive a T5 for two hours without needing fuel? lol!
Post 363319 by Vikingxl on 2011-02-27 20:36:35
I thought it was longer than 10 mins
Post 363341 by p fandango on 2011-02-27 21:15:05
although not a Volvo radio when i locked mine out i removed the radio & powered it up using an old Scalextric transformer instead of leaving the car battery going flat
Post 363426 by Dan850r on 2011-02-28 08:09:23
[quote=Vikingxl;363319]I thought it was longer than 10 mins[/quote] I was close lol
Post 363450 by Flatout Phil on 2011-02-28 13:46:07
[quote=p fandango;363341]although not a Volvo radio when i locked mine out i removed the radio & powered it up using an old Scalextric transformer instead of leaving the car battery going flat[/quote] Oh Duane! Only you would have an old Scalextric transformer kicking around for this eventuality! 11/10 for initiative though ;)
Post 363476 by p fandango on 2011-02-28 16:51:02
[quote=Flatout Phil;363450]Oh Duane! Only you would have an old Scalextric transformer kicking around for this eventuality! 11/10 for initiative though ;)[/quote] i used to race them in a proper club, i specialised in the modified class. Made one with tubular aluminium space frame chassis, another with twin engine & all sorts of weird stuff surprisingly lol
Post 363488 by jdavis on 2011-02-28 17:30:35
2 hours on the dot and it unlocked! was a major mission to plan so i kept car running for 2 hours though!
Post 363943 by Rufe on 2011-03-02 10:43:40
The time delay increases each time it locks without getting a good code. Some cars we have had here have taken a lot longer to open from OFF mode. Simon
Post 472033 by AdyT5 on 2012-03-08 23:09:46
[quote=jdavis;363268]done a bit of research. 2 hours with ignition on to clear it back to "code". great. is it possible to drive a T5 for two hours without needing fuel? lol![/quote] yeah if it runs on lpg lol:hilarious
Post 477559 by dinky on 2012-03-25 14:26:51
didnt know you had that much money,lol
