Post 362497 by RICA340 on 2011-02-23 10:17:14
Is their anything i would need to change to make a T5R engine fit in my car that had a T5S engine in it ? they are the same year and look identical but is their something that i dont know ? thanks
The block/engine itself is the same. It shouldsay on the engine stamp and plastic timing cover B5234T on your engine and the T5 will be the same bar the last digit.
so it should just bolt straight in and work techincally then ?
they are the same engine the "t5" is the engine name
[quote=RICA340;362497]Is their anything i would need to change to make a T5R engine fit in my car that had a T5S engine in it ? they are the same year and look identical but is their something that i dont know ? thanks[/quote] are you thinking of changing because you'v got a problem with yours?
yeah mine is dead so iv found a reasonable price t5r lump just wanted to check all would be ok before i bought it lol
They are the same engines, one will fit each other.
think they have stronger rods iirc, dont hold me on that
[quote=leet5r;362571]think they have stronger rods iirc, dont hold me on that[/quote] no they are the same engine a t5 engine is a t5 engine
are you sure , they have differnt numbers
B5234T is the t5 engine B5234T5 is the t5r engine and the 850 r auto engine B5234T4 is the 850r manual engine
They had different sized turbos depending on what gearbox there were connected to
[quote=Pault5estate;362661]They had different sized turbos depending on what gearbox there were connected to[/quote] only on the manual R which had a 16t, the others had 15g's on that list
Knew it was something along those lines.
cheers for your help guys looks like the estate will finally be coming back on the road after 7 months of being broken :D
