Post 361921 by Crazy_C on 2011-02-20 00:06:35
I need some help here!!! Not a damsel in distress, but a Volvoer (is that the term for us Volvo drivers??) My fuel pump isn't priming on my 1997 940 when I turn the ignition on, and I believe that this is due to the immobilizer as it's been a bit funny at times. I know there is the common problem of the fuel pump relay, but I am looking to just bypass this and do my own set up on it and have the fuel pump on a switch on the dashboard or wire it up into the ignition barrel. The help I need though, is where are the wires that go to the fuel pump that give it the +12V signal? I need to tap into these wires to make it work again. Cheers in advance for any help :)
